Accelerator cable hell
Mudpump
Mudpump is offline
PostPosted: Tue Sep 02, 2008 7:45 am    Post subject: Accelerator cable hell Reply with quote
Maybe I'm doing something wrong. I've have now bought 2 accelerator cables for a 73 Super and both have been about 1/4 inch too long. In order for me to get the right pedal I have to screw it into the cable itself. If I screw it into they metal end of the cable the pedal is too low. What's up??
Matt Wilson
Matt Wilson is offline
PostPosted: Tue Sep 02, 2008 8:27 am    Post subject: Reply with quote
I have experienced this with cables too. Make sure you have the rubber tube from the chassis to the fan shroud tube in place. If it is still too long, get a cable shortening kit. You simply clip off the existing cable end and tightly bolt on the little metal adapter, and voila! the cable is the right size.
1972 Standard Beetle
1969 Baja Beetle
bon2198
bon2198 is offline
PostPosted: Tue Sep 02, 2008 12:43 pm    Post subject: Reply with quote
if your going to be changing your cable. Check out this site:
http://huelsmann.us/bugman/SummerPart54.html
1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it.
Mudpump
Mudpump is offline
PostPosted: Wed Sep 03, 2008 6:46 pm    Post subject: Reply with quote
That cable kit looks like the way to go. So this is the one?
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D2569
BUGGED11111
BUGGED11111 is offline
PostPosted: Wed Sep 03, 2008 6:51 pm    Post subject: Reply with quote
Not if your cable is too long. That's for extending it. You need this one if it's too long:
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D2566
