allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Sat Sep 06, 2008 4:22 pm Post subject: Easiest way to add keyless entry to the vanagon? |
Has anyone done this Any kits out there? My wife is demanding keyless entry What can I do? _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
foodeater Samba Member
Joined: July 13, 2007 Posts: 1318 Location: Newburgh, NY
Posted: Sat Sep 06, 2008 4:40 pm Post subject: |
Just leave the windows open so you can reach in and unlock it with out using the key.
Alternately you could look through the Jegs or Summit catalogs to see if any of the kits they sell for hot rods/customs might work for the vanagon. I've never checked but those kits are made to fit on cars that were not equipped with power locks from the factory, so they may work. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Sat Sep 06, 2008 4:53 pm Post subject: |
_________________ -- 1987 Westfalia automatic (Captain Vino) |
Posted: Sat Sep 06, 2008 5:14 pm Post subject: |
I think it would be easier to just leave the windows open especially if they've got power windows then they dont even have to waste all that energy cranking them down, let alone throwing a brick. _________________ 89 Bluestar-2.5 Subaru Powered-RIP
Posted: Sat Sep 06, 2008 5:19 pm Post subject: |
True, but if she keeps the brick in her purse, it can double as protection from muggers. An added security feature, say no more, say no more! _________________ -- 1987 Westfalia automatic (Captain Vino) |
stevey88 Samba Member
Joined: January 16, 2008 Posts: 1317 Location: Fremont, SF Bay Area
Posted: Sat Sep 06, 2008 5:28 pm Post subject: |
The first thing I did after I bought mine is to add a Clifford alarm bought from ebay for $60. The purpose of the alarm is to get remote door locks. As my van did not have power door locks, I have to add the moter driven actuators ( not the stock units ) to the two front doors and the sliding door. The only difficult part is to run the wires to the actuators. If your Vanagon already have power door locks, it will be much easier. You need to tap into the two control wires from the driver side and program the alarm unit for vacuum type door lock actuators so the actiivation signal will be on for a longer time. _________________ Steve |
Posted: Sat Sep 06, 2008 6:26 pm Post subject: |
hmm I dont mind running wires. I will start to browse ebay for it. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
pushkick Samba Member
Posted: Sat Sep 06, 2008 7:32 pm Post subject: door locks |
i added this alarm system to my van. it seems to work ok. had to make some brackets for actuators and run wires. alarm and 4 door locks including side and rear hatch. has remote start plus extra inputs and outputs.
http://www.commandocaralarms.com/itemdetails.asp?ProductID=496 |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80627 Location: Sneaking up behind you
Posted: Sat Sep 06, 2008 7:34 pm Post subject: |
Twisted minds think alike. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Dogpilot Samba Member
Posted: Sun Sep 07, 2008 8:57 am Post subject: |
I put this system in, keyless and alarm was not a huge increase in price over just keyless. The big expense is the rear hatch uses a different lock mechanism if it is electric.
http://www.a1electric.com/Merchant2/merchant.mvc?S...W02F-B6000 _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
riceye Samba Member
Joined: March 09, 2006 Posts: 1716 Location: Caledonia, WI
Posted: Sun Sep 07, 2008 11:13 am Post subject: |
Double duty as cruise control. _________________ '87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig |
Crughy Samba Member
Joined: July 12, 2004 Posts: 576 Location: Montreal, Qc
Posted: Sun Sep 07, 2008 11:55 am Post subject: |
And van-leveler/ air-ride suspension for flat camping .
JP |
larrytrk Samba Member
Joined: July 22, 2007 Posts: 377 Location: Central NJ & MA
Crughy Samba Member
Posted: Sun Sep 07, 2008 12:45 pm Post subject: |
I never looked much into it.
But the one DP mentions
is kind of nice.
(or same minus alarm for 10$ less).
One of my actuator is broken. (I think. I need to put time on this)
I am pretty the other ones will eventually mess someday.
With this system, I can prevent that with 4 new actuators. (we have 4 doors, including hatch, so that's great).
I could even sell my actuator and make some money out of it!
My only concern is the wiring. If one or more of my wires is messing, (I am not sure of that yet), I simply may be down to step 1 again.
From what I see, it's the old centralized system again (different) but using the same wiring...
JP |
Posted: Sun Sep 07, 2008 1:37 pm Post subject: keyless and remote |
| the a1 electic that dp mentioned. yep thats a good price and has all the stuff. same actuators that i have installed. if you want i could send you my wiring diagram. i have made some brackets so you could use existing rear hatch lock mechanism and side door. i will post some pics if you want. maybe tomorrow. if you send me email i will send drawings via email |
Zero419 Samba Member
Posted: Sun Sep 07, 2008 3:42 pm Post subject: |
just out of curiosity, how would you wire the sliding door? _________________ 1987 Westy Auto Bostig 2.0 Ztec |
Posted: Sun Sep 07, 2008 6:52 pm Post subject: sliding door |
i installed a slide switch in the door and in the door frame this switch was spring loaded so the contacts would make when the door was closed. the alarm unit i installed is programable and has options to automatically lock doors and turn lights out.
i used a sliding door contact kit from a1 electric
http://www.a1electric.com/Merchant2/merchant.mvc?S..._Code=CONT
vwlovr Samba Member
Joined: May 21, 2006 Posts: 1122 Location: on the road
Posted: Mon Sep 08, 2008 8:58 am Post subject: |
Thanks everyone this will make the install a snap. I didnt have central locking to begin with so It does make it a bit harder. But it doesnt look to bad. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
