Easiest way to add keyless entry to the vanagon?
allsierra123
allsierra123 is offline
PostPosted: Sat Sep 06, 2008 4:22 pm    Post subject: Easiest way to add keyless entry to the vanagon? Reply with quote
Has anyone done this Any kits out there? My wife is demanding keyless entry What can I do?
95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold
Steelhead
Steelhead is offline
PostPosted: Sat Sep 06, 2008 4:29 pm    Post subject: Reply with quote
gowesty sells this one. obviously requires electric locks. looks pretty straightforward.
http://www.gowesty.com/ec_view_details.php?id=4187&search_phrase=keyless&start=
'77 Bay Window / '89 Caratsburg (aka. the Stormtrooper)
foodeater
foodeater is offline
PostPosted: Sat Sep 06, 2008 4:40 pm    Post subject: Reply with quote
Just leave the windows open so you can reach in and unlock it with out using the key.
Alternately you could look through the Jegs or Summit catalogs to see if any of the kits they sell for hot rods/customs might work for the vanagon. I've never checked but those kits are made to fit on cars that were not equipped with power locks from the factory, so they may work.
89 Bluestar-2.5 Subaru Powered-RIP
'84 Westy Tiico-daily driver-sold
'82 Caddy diesel-sold
'87 Vanagon Syncro-RIP
'81 diesel rabbit-sold
'82 Vanagon auto-RIP
Perales
Perales is offline
PostPosted: Sat Sep 06, 2008 4:53 pm    Post subject: Reply with quote
-- 1987 Westfalia automatic (Captain Vino)
foodeater
PostPosted: Sat Sep 06, 2008 5:14 pm    Post subject: Reply with quote
Perales wrote:
I think it would be easier to just leave the windows open especially if they've got power windows then they dont even have to waste all that energy cranking them down, let alone throwing a brick.
Perales
Perales is offline
PostPosted: Sat Sep 06, 2008 5:19 pm    Post subject: Reply with quote
True, but if she keeps the brick in her purse, it can double as protection from muggers. An added security feature, say no more, say no more!
stevey88
stevey88 is offline
PostPosted: Sat Sep 06, 2008 5:28 pm    Post subject: Reply with quote
The first thing I did after I bought mine is to add a Clifford alarm bought from ebay for $60. The purpose of the alarm is to get remote door locks. As my van did not have power door locks, I have to add the moter driven actuators ( not the stock units ) to the two front doors and the sliding door. The only difficult part is to run the wires to the actuators. If your Vanagon already have power door locks, it will be much easier. You need to tap into the two control wires from the driver side and program the alarm unit for vacuum type door lock actuators so the actiivation signal will be on for a longer time.
Steve
87 Westfalia full camper 4 speed
allsierra123
PostPosted: Sat Sep 06, 2008 6:26 pm    Post subject: Reply with quote
hmm I dont mind running wires. I will start to browse ebay for it.
pushkick
pushkick is offline
PostPosted: Sat Sep 06, 2008 7:32 pm    Post subject: door locks Reply with quote
i added this alarm system to my van. it seems to work ok. had to make some brackets for actuators and run wires. alarm and 4 door locks including side and rear hatch. has remote start plus extra inputs and outputs.
http://www.commandocaralarms.com/itemdetails.asp?ProductID=496
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sat Sep 06, 2008 7:34 pm    Post subject: Reply with quote
Perales wrote:
Twisted minds think alike.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Dogpilot
Dogpilot is offline
PostPosted: Sun Sep 07, 2008 8:57 am    Post subject: Reply with quote
I put this system in, keyless and alarm was not a huge increase in price over just keyless. The big expense is the rear hatch uses a different lock mechanism if it is electric.
http://www.a1electric.com/Merchant2/merchant.mvc?S...W02F-B6000
Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G
riceye
riceye is offline
PostPosted: Sun Sep 07, 2008 11:13 am    Post subject: Reply with quote
Perales wrote:
Double duty as cruise control.
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
Crughy
Crughy is offline
PostPosted: Sun Sep 07, 2008 11:55 am    Post subject: Reply with quote
And van-leveler/ air-ride suspension for flat camping .
JP
larrytrk
larrytrk is offline
PostPosted: Sun Sep 07, 2008 12:03 pm    Post subject: Reply with quote
Do you have existing electric locks? If so, it will cost you about $50 to add ketyess remote.
http://www.buy.com/prod/valet-712t-keyless-entry-system/q/loc/111/90148065.html
It's all in your mind.
I Hate BAMBI!
87 Westy full camper "Bluie" aka-"busturd"
JUST SOLD HER, WESTYLESS!
Good by cruel world!
Crughy
Crughy is offline
PostPosted: Sun Sep 07, 2008 12:45 pm    Post subject: Reply with quote
I never looked much into it.
But the one DP mentions
is kind of nice.
(or same minus alarm for 10$ less).
One of my actuator is broken. (I think. I need to put time on this)
I am pretty the other ones will eventually mess someday.
With this system, I can prevent that with 4 new actuators. (we have 4 doors, including hatch, so that's great).
I could even sell my actuator and make some money out of it!
My only concern is the wiring. If one or more of my wires is messing, (I am not sure of that yet), I simply may be down to step 1 again.
From what I see, it's the old centralized system again (different) but using the same wiring...
JP
pushkick
pushkick is offline
PostPosted: Sun Sep 07, 2008 1:37 pm    Post subject: keyless and remote Reply with quote
the a1 electic that dp mentioned. yep thats a good price and has all the stuff. same actuators that i have installed. if you want i could send you my wiring diagram. i have made some brackets so you could use existing rear hatch lock mechanism and side door. i will post some pics if you want. maybe tomorrow. if you send me email i will send drawings via email
Zero419
Zero419 is offline
PostPosted: Sun Sep 07, 2008 3:42 pm    Post subject: Reply with quote
just out of curiosity, how would you wire the sliding door?
1987 Westy Auto Bostig 2.0 Ztec
pushkick
pushkick is offline
PostPosted: Sun Sep 07, 2008 6:52 pm    Post subject: sliding door Reply with quote
i installed a slide switch in the door and in the door frame this switch was spring loaded so the contacts would make when the door was closed. the alarm unit i installed is programable and has options to automatically lock doors and turn lights out.
i used a sliding door contact kit from a1 electric
http://www.a1electric.com/Merchant2/merchant.mvc?S..._Code=CONT
vwlovr
vwlovr is offline
PostPosted: Sun Sep 07, 2008 7:52 pm    Post subject: Reply with quote
i did a write up on an install into my 87 GL syncro that had power door locks using the kit from A1....
http://www.thesamba.com/vw/forum/viewtopic.php?t=261047
allsierra123
PostPosted: Mon Sep 08, 2008 8:58 am    Post subject: Reply with quote
Thanks everyone this will make the install a snap. I didnt have central locking to begin with so It does make it a bit harder. But it doesnt look to bad.
