Notching the rods
1961bluebug
1961bluebug is offline
PostPosted: Mon Sep 15, 2008 5:36 am    Post subject: Notching the rods Reply with quote
any information and opinions on this mod? The purpose is to improve piston cooling. I cannot add oil squirters to my already prepped case (I don´t have the tools and know how) so I´m collecting info if notching my H-Beams will serve the same purpose.
Link: http://www.youtube.com/watch?v=7wuNuuEoN7Y
(notching 911 rods)
I´m afraid if it will not bleed to much oil from my system (26 mm schadeck pump, Berg´s mod on lifters)
Hophead
Hophead is offline
PostPosted: Mon Sep 15, 2008 6:54 am    Post subject: Reply with quote
I did a similar modification back in the eighties to some rods on a 1776 motor I had built. I did not do this as a piston squirter though. What I did was to cut four or six (can't remember) notches with a chain saw file on each side of the rod in a star pattern. It was soley for rod main bearing oiling.... it did work well but you better run a deep sump so you do not run low.
Looks like an interesting mod.... just make sure to knock down any stress risers.... show us some picts when you are done.
70' Beetle Pan off Resto
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA
josh
josh is offline
PostPosted: Mon Sep 15, 2008 11:52 am    Post subject: Reply with quote
VW actually put out a service bulletin to do this on type 4 engines. I don't see why it wouldn't work on a type 1.
This thread has some good photos of the mod the way it's done on type 4 rods.http://www.shoptalkforums.com/viewtopic.php?t=95506&postdays=0&postorder=asc&start=30
I'm curious as to why they are doing this mod on 911 engines. I believe all 911 engines built after 1971 had a piston squirter system built into the engine. As I recall combustion chamber temps on the engines with the squirters are on average about 50* cooler than on an earlier engine, all other things being equal.
modok wrote:
...If If stoner A takes a hit and then stoner B goes right away(not waiting two seconds), he's trying to suck on it while it's still got a vaccum, doesen't get much of a hit at all! Cause it hasn't filled back up all the way yet.
Stoner A is cylinders #2/4 B is #1/3 The plugged bowl is the throttle, the bong is the manifold
1961bluebug
PostPosted: Tue Sep 16, 2008 1:29 am    Post subject: Reply with quote
thank you very much!
enghof rambeling.
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold)
Lionhart94010
Lionhart94010 is offline
PostPosted: Tue Sep 16, 2008 4:02 pm    Post subject: Reply with quote
Great Post,
Looks like just the thing for a hard working T1 bus motor with a 30mm oil pump; any idea if and if so how much it would lower the oil pressure on the con rod bearings?
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
Hophead
Hophead is offline
PostPosted: Tue Sep 16, 2008 10:34 pm    Post subject: Reply with quote
I was running a 26mm pump and I had two to three times the notching as the 911 mod and the only time I had oil pressure problems was from starvation in tight turns getting on the freeway..... a deep sump took care of that.
I do not believe that pressure drop is that bad.... the benefit is more flow through the conrod bearings and that would be good. That was what I was looking for when I did it.
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA
1961bluebug
PostPosted: Fri Dec 19, 2008 6:53 am    Post subject: Reply with quote
found a pic of this mod on Pauter website. If this is provided by The Man himself, it will be good enough for me on my H-beams.
this pic is a courtesy of Pauter Machine
enghof rambeling.
|82x94|
stoneloco808
stoneloco808 is offline
PostPosted: Fri Dec 19, 2008 10:49 am    Post subject: Reply with quote
I had these mods done on my Carrillo rods.
Lionhart94010
PostPosted: Fri Dec 19, 2008 11:03 am    Post subject: Reply with quote
I Notched my 5.5 CB Rods for my 78.8x90.5 Bus engine, looking forwards to cooler running pistons, and longer P&C life :0)
manxracer1
manxracer1 is offline
PostPosted: Fri Dec 19, 2008 11:54 am    Post subject: oiling Reply with quote
I did this to my Rimco super rods 26 years ago. If it was not for the NOS I would have the same pistons & cyl on there.
1960 vw Manx
My photo's & video's
http://s263.photobucket.com/albums/ii131/manxracer1/
dubman67
dubman67 is offline
PostPosted: Mon May 11, 2020 5:18 pm    Post subject: Reply with quote
Old thread (I searched, yay!)
Do the grooves go on both sides of the connecting rod?
67 Bug
62 Double Cab
[url=https://www.vw-mplate.com/mplate2-54829.png]Click to view image[/URL]
"At 17 got my first Volkswagen...and mastered the life long art of dragin...." Ice Cube
modok
modok is offline
PostPosted: Mon May 11, 2020 5:25 pm    Post subject: Re: Notching the rods Reply with quote
yes
UK Luke 72
UK Luke 72 is offline
PostPosted: Tue May 12, 2020 2:37 am    Post subject: Re: Notching the rods Reply with quote
I notched mine.
Still got more oil pressure than I can shake a stick at with the hvx mods and a 26mm oil pump...
2276 Beetle build https://www.thesamba.com/vw/forum/viewtopic.php?t=670744&highlight=2276+beetle+daily
2276 EFI Conversion https://www.thesamba.com/vw/forum/viewtopic.php?t=689172
oprn
oprn is offline
PostPosted: Tue May 12, 2020 4:00 am    Post subject: Re: Notching the rods Reply with quote
Again educate me here, I fail to see how those little notches could have an effect on oil pressure. The clearance between the crank and the rod dictate the pressure, by the time the oil gets to the edge it has already had it's kick at the ball and is leaving the arena anyway. All you are doing is showing it which exit to take.
Ohio Tom
Ohio Tom is offline
PostPosted: Tue May 12, 2020 6:50 am    Post subject: Re: Notching the rods Reply with quote
Has exactly zero affect on oil pressure.
Rather it channels the oil seeping out all around the rod into one or two places to exit.
So, you are taking oil that was leaking all around and directing it to an exit.
Hopefully, it gets thrown onto the rods and pistons.
Dan Ruddock
Dan Ruddock is offline
PostPosted: Tue May 12, 2020 7:35 am    Post subject: Re: Notching the rods Reply with quote
Drilling a hole in the rod and brg that lines up with rod journal feed hole is more effective. The Porsche 911 system is even better as it sprays 100% of the time if the oil pressure is above the nozzle valve threshold (will still have good pressure at idle). I did the 911 system on a VW once, worked well. Dan
raygreenwood
raygreenwood is online now
PostPosted: Tue May 12, 2020 7:46 am    Post subject: Re: Notching the rods Reply with quote
Be careful here.....what you say ...because you do not know what condition teh parts are of the person you are speaking to:
and....
In a perfect world and engine you would both be dead on and I totally agree.
However bear in mind when you speak to a general audience in these forums....that far too many are not experts always employing every technique available to build their engine....and most importantly not everyone is using brand new, aftermarket rods or a new or welded crank...even when they should.
One of the biggest losses of oil pressure ....is at the rods....when bearing clearance is excessive....even .001" larger than ideal....especially when ADDED with excessive rod side clearance.
The vast majority of stock cranks laying around these days when coupled with a set of stock rods....will generally have rod side clearances that are up near the top of the...overly generous range listed in most books for VW. Too many people take what are really a wear limit ....as a usable spec....and figure if the rod side clearances are within that wide range....everything is peachy! And it will run just fine....but with a good bit of oil pressure loss.
However in an engine like I just described has oil notches added in....that can be quite bit of oil pressure loss. Then we see people getting into adding larger oil pumps....and then piddling with the oil pressure relief valve....etc...etc...etc.
Ray
oprn
oprn is offline
PostPosted: Tue May 12, 2020 7:54 am    Post subject: Re: Notching the rods Reply with quote
And then they have to use tar for oil to compensate...
GARRICK.CLARK
GARRICK.CLARK is offline
PostPosted: Tue May 12, 2020 8:15 am    Post subject: Re: Notching the rods Reply with quote
The notch has to be a semi circle. If its a V notch cracks can form.
oprn
oprn is offline
PostPosted: Tue May 12, 2020 8:58 am    Post subject: Re: Notching the rods Reply with quote
A chainsaw sharpening file works well. I have never seen it discussed but I assume both sides need to be done. That's what I do anyway.
