Cox dune buggy..
EMPIImp69
EMPIImp69 is offline
PostPosted: Sun Sep 28, 2008 9:21 am    Post subject: Cox dune buggy.. Reply with quote
Picked up a cool Cox dune buggy this weekend. Anyone know what tires fit like the originals? The buggy has 2 flats in the rear, otherwise all intact. Maybe hobby shop or anyone have some originals they want to sell me? thanks.
1963 Ragtop Bug
1966 Vert Bug
Check out my ads, Thanks!
Manxdude
Manxdude is offline
PostPosted: Sun Sep 28, 2008 11:07 am    Post subject: Reply with quote
http://cgi.ebay.com/REAR-REPLACEMENT-TIRES-FOR-COX...286.c0.m14
Dale M.
Dale M. is offline
PostPosted: Sun Sep 28, 2008 11:38 am    Post subject: Reply with quote
Search HOBBY MARKET.... Off road - RC CARS- if you know dimensions in hub that may be a off the shelf option that will be close enough to match original...
For example...
http://www.amainhobbies.com/index.php?manufacturer...agodbmWnFQ
had the Beetle version years ago and actually put a radio control unit into it so it was steerable... Also seem to remember something like using a syringe to inflate tires, something like needle and valve in sports balls (basket ball- volley balls - etc)
Dale
EMPIImp69
PostPosted: Sun Sep 28, 2008 4:48 pm    Post subject: Reply with quote
Cool, thanks guys. Do you remember how the rear wheels come off? I put a small 1/4in. socketdriver on there, and the nuts won't budge, thanks.
1963 Ragtop Bug
1966 Vert Bug
Flat4Tom
Flat4Tom is offline
PostPosted: Mon Sep 29, 2008 9:25 am    Post subject: Reply with quote
Hey Empi,
There is a very small 'C' clip on the end of the axle shaft that holds the wheels on. One on each end of the axle. Take a look at the front tires, it's the same as the back.
I use a very small blade screwdriver (jewelers) and dig around back there until you find it. It is hard to find usually because of all of the old dirt and gunk left over from running it, but it should be in there. Later after you get the clip off, you may find that you'll have to pound out the axle from the wheels. I used a center punch and took my time.
I'm restoring one as well. I found an original cox dune buggy that is radio control from the factory. Mine used a separate plastic fuel tank that is cracked so I'm hung up trying to locate a replacement.
They're cool little projects. Good luck with your.
Regards,
Tom
'69 Fastback - automatic - 'Flamer'
MEANIRISHMOFO wrote:
The whole Patina thing has gone way too far. A beat up piece of shit does not have patina. It's a beat up piece of shit. That car is a good base for a restoration, Not a coat of wax.
EMPIImp69
PostPosted: Mon Sep 29, 2008 9:36 am    Post subject: Reply with quote
Oh that makes sense about the clips on the inside of the rear wheels, thanks Tom. I'll have to take a look when I get home. Yea mine is pretty much all intact (not RC like yours though Crying or Very sad ) but when I lift the body part and look underneath I don't see a fuel cell at all? Do you have a pic of what its supposed to look like and where it is supposed to sit in there? I need to clean or soak the engine in Seafoam or something like that to get all the gunked up fuel off the motor, thanks
1963 Ragtop Bug
1966 Vert Bug
Dale M.
Dale M. is offline
PostPosted: Mon Sep 29, 2008 9:54 am    Post subject: Reply with quote
Regards,
Tom
A small 1 or 2 oz "CLUNK" style fuel tank for model airplanes or gas powered RC cars may do the job..... We used to drill hole through original .049 tank (one on back plate of motor) to get access to fuel line nipple in back plate to extend line to "extended range" tank we put in them....
Not sure what style mount you motor may have , but if you can get to suction inlet to needle valve almost any tank will work....
Dale
Flat4Tom
Flat4Tom is offline
PostPosted: Mon Sep 29, 2008 1:47 pm    Post subject: Reply with quote
Regards,
Tom
Dale
Hi Dale,
Heh, that's funny Laughing - I used to do the same thing! Modify the alum. tank so I could use a larger external one - great minds must think alike!!
That is what is different about this RC dune buggy version. It does not have the tank built into the engine. It has one of Cox's 'firewall' mount type engines in it and it already uses an external fuel tank. I just need to find something to use in place of the original tank as the original tank was plastic and the tiny little 'nipple' the fuel line connected to broke off with the fuel line.
The RC receiver and servo are made as a single unit and mount to the 'pan'. It takes up most of the 'pan' so space for a different type of fuel tank is a bit limited - that's why I'm having a hard time finding a working alternative.
Sorry Empi, I did not mean to hijack your thread...
If you can post of pic of your engine I can tell you where your fuel tank is. It is usually at the back end of the engine - alum. tank with a brass back plate.
Regards,
Tom
EMPIImp69
PostPosted: Mon Sep 29, 2008 5:33 pm    Post subject: Reply with quote
Hey Tom its looks just like this below with the little pull starter, thanks Razz
1963 Ragtop Bug
1966 Vert Bug
Flat4Tom
Flat4Tom is offline
PostPosted: Wed Oct 01, 2008 9:33 am    Post subject: Reply with quote
Hey Empi,
Good picture. See the little round alum. part behind the crankcase? That is your gas tank. You will have two small holes, one on each side of the needle valve in the brass backplate, those are your fuel fill and vent holes.
That tank will give you about 2 to 3 minutes of run time, that is why Dale and I both said we had modded our tanks to allow for the use of an external tank - for longer run times.
Have fun!
Tom
EMPIImp69
PostPosted: Wed Oct 01, 2008 12:14 pm    Post subject: Reply with quote
Oh cool, thanks Tom, good to know.
1963 Ragtop Bug
1966 Vert Bug
HPjunkie
HPjunkie is offline
PostPosted: Thu Oct 09, 2008 7:03 pm    Post subject: Reply with quote
I love those Cox dune buggys. and the movie the computer that wore tennis shoes. My Grandfather bought me a purple cox dune buggy when I was about 8 years old. It was purple and now my real dune buggy is purple! i would love to have a cox buggy again. Keep up the thread ...any photos? Greg
EMPIImp69
PostPosted: Fri Oct 10, 2008 5:50 pm    Post subject: Reply with quote
Here's one pic..I have the other headlight somewhere just need to find it..
1963 Ragtop Bug
1966 Vert Bug
