tazm Samba Member
Posted: Sun Oct 26, 2008 4:13 am Post subject: Air cleaner from 1953? |
Is this aircleaner correct for 53 ??
Thanks in advance ?
IN2VWS Samba Member
Joined: January 29, 2006 Posts: 2557 Location: Australia
Posted: Sun Oct 26, 2008 4:15 am Post subject: |
That is good for 54/55 cars. _________________ ( ⫏ ⫐ )
(ọ\ ¡ /ọ)¹⁹⁵⁴ ¹⁹⁵¹ ¹⁹⁵⁸
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
Heb623 Samba Member
Posted: Sun Oct 26, 2008 6:34 am Post subject: |
In Australia maybe, but in Belgium the one pictured is the one and only good one to put on a 1953 car!
ET |
EverettB  Administrator
Joined: April 11, 2000 Posts: 72043 Location: Phoenix 602
tazm Samba Member
Posted: Sun Oct 26, 2008 11:35 am Post subject: |
| Thanks John and Everett ! |
passoa55  Samba Member
Posted: Sun Oct 26, 2008 11:46 am Post subject: |
53 bugs had them also, they used both T-aircleaner and strapcleaner. _________________ 1950 Hebmuller #458
1952 Azure blue crotch cooler ragtop
1953 original paint oval ragtop
1955 lowlight lizard green
1955 original paint oval
1956 1600 super V-sunroof Porsche
1958 lowlight ghia black
1967 SO42 westy
1969 original paint Westy
1970 one owner 1300L bug |
tazm Samba Member
Posted: Sun Oct 26, 2008 11:49 am Post subject: |
The left one is a 53 pascal the other one the same as mine is 54 |
Posted: Sun Oct 26, 2008 11:52 am Post subject: |
Thanks Guido!
I'm still learning every day!
I will check mine! _________________ 1950 Hebmuller #458
1967 SO42 westy
IN2VWS Samba Member
Posted: Sun Oct 26, 2008 1:07 pm Post subject: |
| Heb623 wrote: |
ET |
no, not just in Australia. It was world wide.  _________________ ( ⫏ ⫐ )
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
53 0val Samba Professor
Joined: July 03, 2003 Posts: 11396 Location: Irvine, CA
Posted: Sun Oct 26, 2008 1:53 pm Post subject: |
| Heb623 wrote: |
ET |
Not a chance............  _________________ "What a fool believes he sees, no wise man has the power to reason away." Dobee, Dobee, Do |
tazm Samba Member
Posted: Sun Oct 26, 2008 2:04 pm Post subject: |
When did they start to use the 54 model??
I found out that the oil bath aircleaner already was used from 20/8/52 on some models! So they are also correct for a zwitter
Edit
I found some pictures from that 53 air cleaner , but only in a bus not in a beetle, could it be that they where specific for a bus ! |
splitjunkie Samba Member
Posted: Sun Oct 26, 2008 3:36 pm Post subject: |
the oil bath cleaners were a huge improvement over the coffee can felt filter from a maintenance stand point. I would suspect that the coffee can filter was not available as a spare part for long so they would get tossed and replaced with a oil bath air cleaner.
The first version of the strap filter was open around the sides and would allow water to drip into the oil. The solution was to add the little deflector rim.
Most zwitters and 53 ovals that I have seen have the coffee can filter but I think there was some cutover during the 53 model year to the strap without the deflector. Most of this is based on period magazine reviews that show pictures of the engine. _________________ Chris
IN2VWS Samba Member
Posted: Sun Oct 26, 2008 3:42 pm Post subject: |
| tazm wrote: |
Edit
Yes Guido, you are correct. If you look in a Zwitter owners manual, it shows 2 types of air cleaners used, the coffee can and an oil bath air cleaner.
In 53 there were 2 types of oil bath air cleaners used. There was the type pictured above (not the 54 type), and another that was similar but it did not have the strap on the top. Instead it used a wing nut to hold the top on.
There is pictures somewhere on TheSamba showing these 2 types of oil bath filters. _________________ ( ⫏ ⫐ )
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
73sports Samba Member
Joined: September 26, 2004 Posts: 2107 Location: Warrington, PA
Posted: Sun Oct 26, 2008 4:18 pm Post subject: |
My zwitter has the oil bath filter, and it has the wing nut on top, no strap. _________________ I will never lie, but sometimes the truth changes.
Central Jersey VW Society |
IN2VWS Samba Member
Posted: Sun Oct 26, 2008 7:27 pm Post subject: |
PR lists an oil bath "now fitted in a number of cases" on 20th August 1952.
Then on the 2nd January 1953 the oil bath air cleaner is "now fitted with strap".
Then on the 21st of December 1953 the oil bath air cleaner is "standard equipment for all models", and I suspect this is when the 54 style was introduced.
The first 2 pics are from a September 1952 owners manual, and it shows the coffee can air cleaner and the oil bath aircleaner with the wing nut.
The third pic is from a March 1953 instruction manual showing the early strap type oil bath air cleaner.
⨴⨵--⊗--⨴⨵ 𝕊ℙ𝟚¹⁹⁷³ |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9418 Location: Northwood, NH USA
Posted: Sun Oct 26, 2008 8:04 pm Post subject: |
So the wing nut cleaner is the earliest oil bath device used on Beetles? I'd guess they are pretty rare...... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Heb623 Samba Member
Posted: Mon Oct 27, 2008 2:11 am Post subject: |
Australia 1 - Belgium 0 (specific part of Belgium)
ET |
tazm Samba Member
Posted: Mon Oct 27, 2008 5:01 am Post subject: |
Thanks John,
For the information !
A few years ago , I trow one of these air cleaners with wingnut away because I thought is was a home made part !
Never to old to learn, thanks again for the great information !!
Now I can sell the 54 air cleaner and not giving people the wrong information because I thought it was correct for a 53 !
Best regards,
Guido |
ZwitterND Samba Member
Joined: September 08, 2005 Posts: 1453 Location: Fargo, ND
Posted: Mon Oct 27, 2008 10:50 am Post subject: |
Guido, don't feel bad I thought the same thing about the wing nut air cleaner on my zwitter, I thought someone replaced the coffe can with a newer style, but I remember contacting Claus Jacobsen and he informed me of the rarity. And confirmed it recently on another thread on here. The hard part is having to explain to other split owners that yes it is correct air cleaner.
Bill _________________ Bill |
Posted: Mon Oct 27, 2008 11:17 am Post subject: |
Nothing beats Bill Collins old story, of the first Split he was restoring.
Doing body work, he "hammered flat a round-ish dent just above the windshield, in the middle...." _________________ John Henry
'57 Deluxe
'56 Single Cab |
