meyervw Samba Member
Joined: January 29, 2006 Posts: 468 Location: Chico, California
Posted: Tue Nov 04, 2008 9:20 pm Post subject: Installed the NGK BP6ET (NGK 1263) plugs... |
| WOW what a difference. The idle is better, taking off from a stop is smoother and no more misfires. Gustav LOVES these plugs. The ones that were in there were the Bosch heavy duty with Uranium. Well the sucks from the start. I finally found a place locally that had the NGK plugs. I put them in last night and I am impressed. Thanks for the tip on these plugs. |
wgargan Samba Member
Joined: September 21, 2002 Posts: 871 Location: Dreaming of the Rockies
Posted: Tue Nov 04, 2008 9:30 pm Post subject: |
who had them? _________________ Current ride:
1983.5 Watercooled Vanagon 'L' Automatic transmission |
Posted: Tue Nov 04, 2008 9:32 pm Post subject: |
| The last place I thought of.... NAPA auto parts. |
Posted: Tue Nov 04, 2008 9:35 pm Post subject: |
good to know thanks. _________________ Current ride:
presslab Samba Member
Joined: September 29, 2008 Posts: 1730 Location: Sonoma County
Posted: Tue Nov 04, 2008 9:59 pm Post subject: |
Your spark plugs are glowing green!
I've tried the Bosch Platinum plugs and I was not impressed at all. They might last longer but the performance is not good. I only use NGK plugs, lately I've been using the BPR6EY type (with the forked center electrode) with good results. |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10163 Location: Abiquiu, NM, USA
Posted: Wed Nov 05, 2008 8:43 am Post subject: |
I turned my back on exotic electrode metals for this particular ignition system many years ago; never seemed to work too smoothly with platinums. Copper core electrodes seem to have the right discharge characteristics to work smoothly with it. The BP6ET's have been my preferred plug for many years now, even though they're a bit hard to find. Toldja you'd like 'em!
The triple grounding electrodes offer certain advantages for long-term wear so they do perform well for a lot of miles. The sharpness of the upper edge of the center pole is where the spark is focused, so sharing the load round and round makes that limited resource go farther before it all rounds off. I've found the same true for the Bosch tri-electrode ones, which are a good substitute, but also hard to find sometimes. I slightly prefer NGK, though, but not for any real objective reasons, I've just preferred that brand for years.
Thanks for the tip on NAPA; I'll check to see if my local stores stock these. As it is I order several sets at a time from some unknown online supplier, can't even remember their name right now. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Please don't PM here, I will not reply. |
swmontana Samba Member
Posted: Wed Nov 05, 2008 9:23 am Post subject: |
I looked at the NGK website and they are saying that the BR6ES plug is specified for 2.1 litre Vanagons. Does anyone know what the difference is between the ET and the ES suffix? (And don't say "Call home") _________________ 1987 Wolfsburger
1997 F-250 Powerstroke
2002 ZX-5
2000 Fleetwood 737
Gone but not forgotten: 57 Bug, 66 Westy, 67 Bug, 71 Bus, 72 SQBck, 84 Westy, 87 Van, 90 Golf |
Perales Samba Member
Joined: May 07, 2007 Posts: 2046 Location: Nova Scotia
Posted: Wed Nov 05, 2008 9:37 am Post subject: |
If you go to this site:
http://www.ngk.com/sparkplug411.asp
and scroll down to the very bottom of the left sidebar, there is a link for a pop-up window that explains the NGK sparkplug numbering system. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Wed Nov 05, 2008 10:36 am Post subject: |
Nice, I think I want to order a set.
Noobie question, maybe for tencent:
Can one install these plugs out of the box, or should the gap be set?
Mssr. Bentley says on Section 28.41:
"Gap = 0.7mm =/- 0.1 mm"
PS - some online sellers are here:
http://frugalmechanic.com/auto-part/772645-ngk-bp6et-multi-ground-spark-plug _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Posted: Wed Nov 05, 2008 10:41 am Post subject: |
They've aways been correctly gapped right out of the box, which is a good thing since the tri-electrodes are difficult to adjust manually. Nonetheless, you always need to confirm with at least a visual check, as you should with any new plugs. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Posted: Wed Nov 05, 2008 11:11 am Post subject: |
Tencent,
That was a 5 minute response time, most impressive!
Thanks for your help, as always. _________________ '86 Westy, 2.5 Subaru power
Posted: Wed Nov 05, 2008 11:31 am Post subject: |
Caught me still in bed, enjoying my coffee and 'puker brought to me by my lovely wifelet. Even though it's stormy and cold outside here, we're basking in the sunshine of a new, new day. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4642 Location: East Kootenay, British Columbia
Posted: Wed Nov 05, 2008 11:34 am Post subject: |
| tencentlife wrote: |
| Even though it's stormy and cold outside here, we're basking in the sunshine of a new, new day. |
Cheers to that! _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Wed Nov 05, 2008 1:36 pm Post subject: |
| Just a question to see if anyone has the answer. Why did original W7CCO plugs work so well? They looked and worked like new at 80K miles whereas W7CC and various other plugs I have run lasted no where near as long. |
Posted: Thu Nov 06, 2008 7:50 am Post subject: |
| Wildthings wrote: |
The build materials and quality are different. Back in the 80's VW BMW MB all seemed to have a better quiality since they were fighting harder to be in the American market. So it seems to me. _________________ Spelling in my post may or may not be correct.
Gustav 1987 Wolfsburg Edition |
Posted: Mon Nov 17, 2008 11:20 am Post subject: |
Just wondering what recommendations anyone might have for an oil burner. My 83 1/2 with a worn out Canadian VW rebuild uses a quart of oil with every tank of gas. I don't get oil fouling per say, but get more than normal of the hard whitish deposit covering the negative electrode over time. The plugs will still run a good 10,000 miles (and maybe more) without having any noticeable missing or power loss.
This engine just flat out will not run right with a new set of BR6ES plugs, bottom end torque disappears instantly when they are installed. I presently have a very high mileage set of W7CCO in it and it runs A-1, but would really like something not quite so old.
I have no idea why the engine doesn't run with the BR6ES, I am open for suggestions there as well. |
FNGRUVN Samba Member
Joined: October 27, 2007 Posts: 2237 Location: Fort Collins, CO
Posted: Mon Nov 17, 2008 7:57 pm Post subject: |
| Have you tried more than one set? You could have one bad plug. |
Posted: Tue Nov 18, 2008 2:41 am Post subject: |
| FNGRUVN wrote: |
Its done exactly the same with three sets of NGK's. Think that some of them were BR6ES's and others were BP6ES's. Driven this rig most of the 60K miles I have had it with the a set of W7CC's in it, but they were extremely worn so I took them out before a trip to Mexico last year and put in a new set of NGK's. It didn't seem quite right from the start and began dying after 1000 miles or so, so I put in another new set of NGK's these made it another 1000 or so until the engine wouldn't rev from idle at all, almost undrivable. Pulled the old set of W7CC's out of the glove box and put them back in and it has run fairly well for another 15,000 or so, but they were now really shot and gas mileage was falling so I tried another set of NGK's and it wouldn't pull away from a stop without a lot of reving and clutch slipping. Stripped a set of W7CCO's from an old engine regapped them and it runs A-1 like I said. All the NGK's looked fine on removal, minimal light tan build up. Each set was bought from a different location over a one year period, so they wouldn't be from a single bad lot. |
snoop Samba Member
Posted: Sat Jan 03, 2009 2:41 pm Post subject: |
Very impressed. Just a couple of hours into 'em, but no doubt about it...an improvement relative to the Bosch plugs that came with my GW 2.4. I noted the same things that djs did.
Thanks for another great tip fellas! I like it even more than the headlight switch+high beam switch=power window function without ignition key tip  _________________ 87 Westy Camper |
