RAAAID Samba Member
Joined: January 31, 2008 Posts: 99 Location: Hamilton,Ontario,Canada
Posted: Wed Nov 05, 2008 8:49 am Post subject: pics of 1600 turbo build |
heres a few pics of the progress ive made on the 1600 turbo build im doing.im still waiting for parts but its going along real well so far.yesterday i welded up the t-section intake,it curves a bit to clear the alt.i also welded up the dump pipe and im fitting everthing to go out for chrome hopefully this week.i had a local guy cnc the flanges for the dump on the turbo and the compressor side.theres also a pic of the aeromotive fuel pressure regulator(boost sensitive)that im using and other parts.the header and intake that bolts to the carb are pieces from brothers vw shop.the carb is a dell that i got from tkisner a while back.the shroud is getting replaced with one without the duct cutouts.the turbo is a gt25 from garrett.ill keep you posted as to the progress.
BigHerc Samba Member
Joined: November 26, 2006 Posts: 809 Location: sierra madre, CA
RAAAID Samba Member
Posted: Wed Nov 05, 2008 9:57 am Post subject: |
its an aeromotive piece that i picked up from a friend that owns a performance shop in town.i paid about 140 with the gauge if i remember right.another friend runs one for FI on his blown mustang and he recommended it. |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Wed Nov 05, 2008 10:25 am Post subject: |
Cool build! Looks nice. I take it you're going with the stock cam and ratio rockers. You're gonna have some fun!
Are you going to run a locked 009 or other ignition? Electric fuel pump or stock pump? |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Nov 05, 2008 10:52 am Post subject: |
Whatever you do, ditch that distributor cap with the quickness. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Stuggi Samba Member
Joined: October 16, 2007 Posts: 1208 Location: Jakobstad, Finland
bon2198 Samba Member
Joined: August 04, 2008 Posts: 1969 Location: Nashville, GA
Posted: Wed Nov 05, 2008 11:38 am Post subject: |
Stuggi wrote: |
Is there ANY real downside of having a transparent dissy cap, or are they just all poorly made? And can you see the sparks when it's running? ^^ |
you can see some spark in the dark. i have a blue transparent one and i've noticed no difference. i keep the bosch in the car just in case. _________________ 1970 VW Beetle 1776cc MOFOCO w/hydraulic lifters, 042 heads and dual dellorto's
"It's better to be hated for what you are than loved for what you are not"
At the end of the day it's YOUR car so do what YOU want to it. |
Koyote Samba Member
Joined: March 31, 2008 Posts: 193 Location: Dijon, home of the mustard.France
Posted: Wed Nov 05, 2008 1:21 pm Post subject: |
bon2198 wrote: |
i keep the bosch in the car just in case. |
That's a good idea !
I have seen many burned, cracked, etc... stocks are way better.
RAAAID : nice build !
what are the engine specs? exhaust tubing size (15/8 ?) seems a bit to big for a 1600. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15600 Location: Deep in the 405
Posted: Wed Nov 05, 2008 5:18 pm Post subject: |
Stuggi wrote: |
They are junk, pure junk, and nothing but junk. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
manxcraig Samba Member
Joined: November 12, 2006 Posts: 617 Location: pendelton (indianapolis) indiana
Posted: Wed Nov 05, 2008 5:33 pm Post subject: |
vwracerdave wrote: |
Stuggi wrote: |
They are junk, pure junk, and nothing but junk. |
X2, The only good use for one is to install it upside down on the workbench as an ashtray. _________________ 69 Meyers Manx II on 65 pan, 1 owner !
WANTED, Meyers Manx license plate frames, repo OK, don't like the new smiles per miles ones. |
RAAAID Samba Member
Posted: Wed Nov 05, 2008 6:31 pm Post subject: |
the headers are 1 5/8 and ya they are on the larger size but i intend on building something a little bigger down the road to use it on.the turbo is a ballbearing unit (as per performance shop and #)so it should hopefully spool up a little quicker to offset the larger exhaust.ignition is going to be a petronix set up in the dist. and an msd 6al btm that im trading a friend for(he needs a 6al). |
RAAAID Samba Member
Posted: Wed Nov 05, 2008 6:34 pm Post subject: |
oh ya the fuel pump is a blue holley unit.i figure that since im going to build a bigger motor eventually id buy the better/bigger stuff once and restrict it ,rather than buy something that is border line usable or not good later on. |
bugninva Samba Member
Joined: December 14, 2004 Posts: 8858 Location: sound it out.
Posted: Wed Nov 05, 2008 7:10 pm Post subject: |
manxcraig wrote: |
X2, The only good use for one is to install it upside down on the workbench as an ashtray. |
i use old beat up pistons(usually from dropped valves, but only use the ones that didn't get ventilation hole put in them) for ashtrays.... easy to mount when you just push the pin almost out... slides over a nail easily.  _________________
[email protected] wrote: |
With a show of hands, who has built over 1000 engines in the last 25 years? Anyone? |
GEX has. Just sayin |
dunebuggydrifter Samba Member
Posted: Sat Nov 08, 2008 10:47 am Post subject: |
what size carb is that?? A buddy and I are working on a turbo set up for his rail. I will post some pics later. |
Posted: Sat Nov 08, 2008 10:50 am Post subject: |
45DHLA?? My guess. |
HERC Samba Member
Posted: Sat Nov 08, 2008 3:27 pm Post subject: |
Stuggi wrote: |
Funny, I used one for 50,000 miles on a baja bug. Rain, So Cal heat and whatever didn't touch it....
Amazing at how many people play follow the leader here...
Next, I'm sure you'll tell him to ditch his chrome doghouse...
What a joke...
Great job, RAAAID..... I'm sure it's going to be a nice motor.  _________________ Herc |
The Noof Samba Member
Posted: Sat Nov 08, 2008 3:37 pm Post subject: |
bugninva wrote: |
manxcraig wrote: |
i use old beat up pistons(usually from dropped valves, but only use the ones that didn't get ventilation hole put in them) for ashtrays.... easy to mount when you just push the pin almost out... slides over a nail easily.  |
If you use the transparent cap, you might have beat up old pistons to use as ashtrays. |
Posted: Sat Nov 08, 2008 3:50 pm Post subject: |
The Noof wrote: |
i bought a pretty clear blue cap back in the early 90's... sure was pretty and matched the bug nearly perfectly.... car never ran well with it and i removed it... it could still be in a box somewhere looking pretty....
(FTR, i have a couple sets of ashtrays, one set from an engine that dropped a valve and trashed the engine, another set from a rebuild.. the rest got tossed... i need to quit smoking and i can toss the wall of shame ashtrays too...) _________________
MO Turbo Manx Samba Member
Joined: June 25, 2007 Posts: 240 Location: St. Louis, MO
Posted: Sun Nov 09, 2008 5:26 am Post subject: |
Beautiful!
What turbo is that? Looks like a Nissan T25 or T28?
I love my T25.
It's performed flawlessly on my 1600.
Yours makes mine look like junkyard fodder, though.
Go sane on the cam and you're gonna have a blast.
I'm using the stock VW with 1.25's with excellent results.
Here's my post:
http://www.thesamba.com/vw/forum/viewtopic.php?p=3405823#3405823
Any questions? Feel free to e-mail or PM. |
RAAAID Samba Member
Posted: Wed Apr 08, 2009 8:53 pm Post subject: update with pics |
well i finally had some spare time this week so i started getting the motor back together.still not done but progress.some stuff still needs to be fastened but you get the idea.heres some pics.im still cleaning up the carb and stuff but should be on soon.also the wastegate flange will serve for an wideband o2 sensor port.
