Type 3 Front Sway bars
Page: 1, 2, 3, 4  Next
Simon DeCasas
Simon DeCasas is offline
PostPosted: Sat Nov 15, 2008 11:30 am    Post subject: Type 3 Front Sway bars Reply with quote
Anybody have an aftermarket front sway bar on there car? How is it mounted and any problems with the way its mounted? I have a rear bar and was wanting to upgrade the front. I know they come with one stock I just want to stiffen the front to match the back. I have seen one by empi but they are almost nonexistent. Any suggestions on an improvement over stock?
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sat Nov 15, 2008 2:10 pm    Post subject: Re: Type3 Front Sway bars Reply with quote
you are aware that the Type 3 beam has one built in, right?
póg mo thóin
Certified DHS Technician
Samba Member # 24517
KTPhil Premium Member
KTPhil is offline
PostPosted: Sat Nov 15, 2008 4:08 pm    Post subject: Reply with quote
You are smart to look to increasing front roll stiffness if you are adding a rear bar. Otherwise you increase oversteer, already a problem in these cars.
It owuld be nice if someone made stiffer stock-mount T3 bars, but I know I'm dreamin'...
red_6
red_6 is offline
PostPosted: Sat Nov 15, 2008 6:24 pm    Post subject: Reply with quote
God I wish,
It was a nightmare just finding a replacement stock beam for mine!
frank2
frank2 is offline
PostPosted: Sat Nov 15, 2008 6:39 pm    Post subject: Reply with quote
I have a empi front swaybar on my square.Has mounting clamps similar
to a bay bus style.Dont think it does much other than look cppl.-Frank Laughing
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Nov 15, 2008 6:57 pm    Post subject: Reply with quote
red_6 wrote:
God I wish,
You didn't ask me. And I am just a 1/2 day drive.
And where are all the ones that KCW pulled out.
Gary: OK. Ima poop.
localboy
Samba Longboarder
localboy is offline
PostPosted: Sun Nov 16, 2008 11:50 am    Post subject: Reply with quote
Excellent question.
One man's "patina" is another man's cancer...
Black '65 Resto-Custom S Notch 2110 cc powered
original paint Pearl White '66 Westy SO-42
Allstate single-wheel trailer project
DucMike
DucMike is offline
PostPosted: Tue Nov 18, 2008 2:38 pm    Post subject: Reply with quote
It would be nice if someone made stiffer stock-mount T3 bars, but I know I'm dreamin'...
Correct me if I'm wrong, but didn't they increase the diameter of the upper bar at some point, say somewhere around '70? Larger diameter should equal an increase in stiffness. At least it felt like it did when I swapped out the one on my '66. Running that & my old camber compensator & it seems to corner pretty flat.
Mike S.
'66 Variant Sunroof TIII4ME
'76 Rabbit
'91 Passat Variant (Big 'back)
'96 GTI VR6
'03 20th AE GTI OEM+ 20th
Niello Ranch Run
wolfman's brother
wolfman's brother is offline
PostPosted: Tue Nov 18, 2008 7:49 pm    Post subject: Reply with quote
localboy wrote:
Excellent question.
if I had to guess they were tossed in the scrap heap and crushed,probably already melted down,made into cheap chinese crap and sitting on a shelf in wal-mart(sprawl mart)in the form of a cheap toaster already.the kcw terrorist don't care Crying or Very sad
insanity takes it's toll,please have exact change ready.
my imaginary friends keep telling me I have a mental problem.
localboy
Samba Longboarder
localboy is offline
PostPosted: Tue Nov 18, 2008 9:51 pm    Post subject: Reply with quote
wolfman's brother wrote:
localboy wrote:
Excellent question.
SIGH.... Evil or Very Mad
Mr. Bubblehead
El Chupa Nibre
Mr. Bubblehead is offline
PostPosted: Tue Nov 18, 2008 10:14 pm    Post subject: Reply with quote
Russ Wolfe wrote:
...And where are all the ones that KCW pulled out.
That's sig line material right there. LO effing L.
OGST
Samba Member #4862
KTPhil is offline
PostPosted: Wed Nov 19, 2008 11:11 am    Post subject: Reply with quote
Rear bars changed at some point, and may be different for early swing square vs fastback. I didn't think the fronts ever changed.... anyone know for sure?
Syncronaut
Syncronaut is offline
PostPosted: Wed Nov 19, 2008 2:48 pm    Post subject: Reply with quote
According to the VW parts book (and how I read the info given there...) the front sway bar came in two different diameters; 11.0 mm and 13.7 mm. The thinner version came in all type 34, Notch- and Fastbacks and in the Squareback for '67 and '68 model years, where as the other Squareback models has the thicker one (this is also true for all AT Squarebacks...).
So you people with Ghias, Notches and Fastbacks (and myself, since my Squareback is a '68 Rolling Eyes ) want to look for a Squareback front sway bar if you want to stiffen up the front end a bit. And be sure to stay away from model years '67 and '68 Wink
Gorm
KTPhil is offline
PostPosted: Wed Nov 19, 2008 2:56 pm    Post subject: Reply with quote
Excellent info! I will check mine when I reset the ride height. I have a spare axle and would like the stiffer bar if it has it.
Simon DeCasas
PostPosted: Fri Nov 21, 2008 8:36 am    Post subject: Type3 Front Sway Bar Reply with quote
If a latter 13mm bar helps what is stopping us from making a 19mm bar for the front that would fit in the stock location? It would be a matter of gettting the right kind of steel and machining the ends to fit the torsion arms right? If there is enough interest I don't see why we as the type 3 community couldn't make a short run of these bars from a small machine shop and have a awsome suspension set up. Any body know a friendly machine shop?
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Nov 21, 2008 9:02 am    Post subject: Reply with quote
Any Machine Shop could do it! If your first set comes out good post some pictures and we'll buy from you! Very Happy
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
KTPhil is offline
PostPosted: Fri Nov 21, 2008 10:52 am    Post subject: Reply with quote
Choice of steel and the heat-treating required may not be so simple. Filleting work is also critical. VW cautions that small nicks (or even rust from a nick in the paint) can cause failures under stress. But with homework it may be possible.
Franz
Franz is offline
PostPosted: Fri Nov 21, 2008 1:40 pm    Post subject: Reply with quote
localboy wrote:
Excellent question.
Took them to the metal recycler...really! About 10 type 3 beams complete drum to drum. Along with about 5 RGB bus transaxles.
https://www.vervemotorworks.com/
DucMike
DucMike is offline
PostPosted: Fri Nov 21, 2008 1:47 pm    Post subject: Reply with quote
From what I remember (& it's been a while now), my '66 had the smaller 11mm bar in it when I swapped it out & it was an untouched car before I got my hands on it. Twisted Evil
Mike S.
'76 Rabbit
'96 GTI VR6
Niello Ranch Run
grethi
grethi is offline
PostPosted: Fri Nov 21, 2008 2:37 pm    Post subject: Reply with quote
What about these?
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=SSS0002&cartid=
Does anyone have any pro/con info on these, or what difference they make to the vehicle stability and safety? Would using them as pictured damage or warp the factory suspension?
For that matter, it looks like the one currently mounted under my Subaru Impreza DD.
My mind not only wanders, sometimes it leaves completely.
'69 square
Page 1 of 4
