Buttafuoco Samba Member
Posted: Thu Nov 27, 2008 11:11 am Post subject: Tin |
Tin
Euro 67 Samba's 67 part whord
Joined: February 24, 2007 Posts: 1370 Location: Between Florida and Cali
Posted: Thu Nov 27, 2008 11:15 am Post subject: |
No, Not at all should you remove that tin _________________ 68 Bug totaled one day will live again
69 Bug donor car
Many parts had, always need em!
| millerje78 wrote: |
| I'm no expert but I'm guessing the spike during cold running has everything to do with the roofing tar(20-50) in the crankcase. |
| bill may wrote: |
| ...i could be wrong as i have only been driving air cooled beetles since august 1965. |
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 18056 Location: Eugene, OR
Posted: Thu Nov 27, 2008 11:17 am Post subject: |
It's perfectly safe to eliminate all the tin if the engine is going into a Gyrocopter! _________________ 69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
| Euro 67 wrote: |
| No, Not at all should you remove that tin |
Excellent....thank you. |
Posted: Thu Nov 27, 2008 11:32 am Post subject: |
Since your engine is open in the trunk it seems reasonable to eliminate the top tin? _________________ 69 FI/AT square Daily Driver
mystikjoker Samba Member
Posted: Thu Nov 27, 2008 11:34 am Post subject: |
| I have the tin over the heat exchangers removed. You have to cut around the holes though so you can still secure it to the head. I also removed the front tin but had to make a holder for the throttle cable. |
Notched Samba Member
Joined: January 19, 2003 Posts: 2365 Location: Pacific Northwest
Posted: Thu Nov 27, 2008 11:39 am Post subject: Re: Eliminating some engine tin....is it o.k.??? |
WTF?  |
burgandysquare Samba Member
Joined: October 10, 2007 Posts: 434 Location: San Diego, CA
Posted: Thu Nov 27, 2008 12:23 pm Post subject: |
Yeah its fine to remove it... as long as you put it back when you're done.  _________________ 1968 Volkswagen Squareback |
fasty69 Samba Member
Joined: November 28, 2006 Posts: 213 Location: CANADA
Posted: Thu Nov 27, 2008 12:32 pm Post subject: |
or if its a 1/4 drag car............ _________________ Newest member of the family+New project
69 Fastback-Free of Rust |
