russwiththebus Samba Member
Joined: September 25, 2007 Posts: 930 Location: Chattanooga, TN
Posted: Tue Jun 10, 2008 4:56 pm Post subject: Differences in ECU between the years? |
My situation is that I have a 1978 Westy with a transplanted engine. The block came from an air-cooled Vanagon but the heads are correct for the year model. Previous owner installed a center-mounted Weber carb, and I am in the planning stages of making it fuel injected again.
I've amassed a bunch of new and used parts to use, and I almost have everything I need. My question is, I have two ECUs here that have different part numbers and I want to know what the difference is, and/or if it matters which one I use.
Here's the first ECU I have, it's the original from the 1978 bus. VW part # 022 906 021 AG (Bosch part # 0 280 000 166) with a purple sticker.
The thing is that it rattled when I pulled it out, so I opened it up to discover why. It looks like one of the little black star-shaped heat sinks (at least I think they're heat sinks) is unglued on the far left. Here's a close-up of the piece.
Is it a problem to leave it off, or can it be re-glued perhaps?
Now on to my second ECU. This one came out of a box of parts I bought from someone. I think his bus is a '76 and that's what the majority of these parts came off of. His ECU has a different part number, 0 399 060 21B (Bosch part # 0 280 000 178) and has a black label. When I opened it up, I was surprised to find a second PCB inside, screwed down.
It connects to the other PCB via a few wires on the side.
So what's the deal? Are they functionally the same, despite their differences? Can I use either one on my bus, or does it have to be matched to a certain part, like the AFM or something?
Thanks. |
MadMax78 Samba Member
Joined: May 26, 2007 Posts: 511 Location: The Netherlands
Posted: Tue Jun 10, 2008 5:12 pm Post subject: |
ECU, CU 102 X - 039 906 021 B
Volkswagen
1979 Type 2 1970cc (CJ,GE) Except California Manual Transmission
1983-80 Vanagon 1970cc (CV) Except California Manual Transmission
ECU, CU 99 X - 022 906 021 AG
Volkswagen
1978 Type 2 1970cc (CJ,GE) Manual Transmission
Strange, at first I thought it may have had to do with the lambda system on Cali systems, but the ecu part numbers prove they are both fedederal manual transmission ecu's. Maybe it's for the altitude correction switch...? Or do all vanagons have the lambda sensor? Then that board would control the mixture...
Cool pics btw, always wondered how it would look on the inside! _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt Injection & Ignition // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply , Busted Bus, Aircooled Technology & DIYAutoTune
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 27.000km
http://www.oranjetrophy.nl
Camper Special Club Member |
Posted: Tue Jun 10, 2008 6:00 pm Post subject: |
Early 76 units did not use the throttle position switches, which many might view as a plus. There are also 6 plug and 7 plug AFM IIRC, and I suspect there were other changes over the years as well. To eliminate problems I would suggest you find a matching set of harness, ECU, and peripherals. Then again I really don't know much about this area and could be all wet.
Randy in Maine Samba Member
Posted: Tue Jun 10, 2008 6:01 pm Post subject: |
| Possibly the ECU internal "series resister" since a CA bus doesn't use the one on the firewall? |
vw76westy Samba Member
Posted: Tue Jun 10, 2008 6:47 pm Post subject: |
im no expert but the ecu, the air flow meter ,harness & injecters
have to all come from the same year in order work right
i have also read that the engine year should also match in order to avoid
problems later
regardless of what year system you choose |
Posted: Tue Jun 10, 2008 8:19 pm Post subject: |
All interesting ideas, thanks! As far as I know, none of these parts came from California buses, so I don't know it's lambada. Also the wiring harness I got came with series resistors, so I don't know if that's it either. I do plan on trying to keep everything intact as possible though, so I'll probably go with the '76 ECU first. And luckily they're easy enough to trade out, so that won't be a problem either.
Also I don't believe the L-Jetronic system changed much between '75 and '79, at least for non-California emissions so swapping parts should work. I meant it works off air flow so it's not like it cares how big the engine is or anything.
Either way it should be an interesting experiment getting it working. |
Karl Samba Member
Joined: January 29, 2001 Posts: 6170 Location: Coos Bay, Oregon
Posted: Tue Jun 10, 2008 8:50 pm Post subject: ECU Karl |
Only 79 Calif had the O2 sensor and no resistor pack.
I have a box full of ECU's. I used to grab them many years ago.... before I found out how bullet proof they are. Most 'mechanics' do not have a clue that they need to test first. 99% of them are 'parts replacers' and do repairs using the Mossberg Repair Procedure. Shotgun a sh!tload of parts at it til it runs.....
I would test each ECU on my 77 bus to see if it worked. Everyone did. Each year has 4 ECU's..... why? No friggin clue. My bus ran the same with each one!
California Models:
022-906-021K 1974 Automatic
022-906-021L 1975 Manual Trans
022-906-021M 1975 Automatic
022-906-021Q 1976 Manual Trans
022-906-021R 1976 Automatic
022-906-021AA 1977 Manual Trans
022-906-021AB 1977 Automatic
022-906-021AE 1978 Manual Trans
022-906-021AF 1978 Automatic
039-906-021D 1979 Manual Trans
039-906-021E 1979 Automatic
Federal Models:
022-906-021H 1975 Manual Trans
022-906-021J 1975 Automatic
022-906-021N 1976 Manual Trans
022-906-021P 1976 Automatic
022-906-021S 1977 Manual Trans
022-906-021T 1977 Automatic
022-906-021AG 1978 Manual Trans
022-906-021AH 1978 Automatic
039-906-021B 1979 Manual Trans
039-906-021C 1979 Automatic
Vanagon:
California Models:
071-906-021B All Transmissions 1980-1983 (071 plain and 071 E subbed to the 071B!)
Federal Models:
039-906-021E Manual Trans 1980-1983
039-906-021C Automatic 1980-1983 |
Posted: Wed Jun 11, 2008 6:31 am Post subject: |
| Thanks Karl, that's interesting! |
WhirledTraveller Samba Member
Joined: January 09, 2008 Posts: 1414 Location: Cambridge, MA
Posted: Mon Dec 22, 2008 2:19 pm Post subject: |
Resurrecting this thread,
I have acquired a bunch of F.I. parts for spares from a 78 Federal Manual Transmission. I have a 77 Federal Automatic.
The AFM has a slightly different part number, as does the ECU.
Does anybody know with certainty weather these parts truly interchange or don't? Anybody know, for example, what the difference is between an automatic and a manual transmission ECU?
Basically just want to know whether these are useful spares worth keeping. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
Karl Samba Member
Posted: Mon Dec 22, 2008 2:26 pm Post subject: |
| WhirledTraveller wrote: |
Basically just want to know whether these are useful spares worth keeping. |
I am betting your 77 AFM is part number 0 280 200 018 022-906-301B Correct?
Your 78 is part number 0 280 200 020 022-906-301D Correct?
They are one and the same. VW superceded the 018 to the 020 many years ago. If you went to the dealer and tried to buy the 0 280 200 018, they would have sold you the 0 280 200 020.
As far as the ECU's goes. I have run them all in my 77 Westy. They all appear to run the same.
Keep 'em.... |
Posted: Mon Dec 22, 2008 2:28 pm Post subject: |
Thanks Karl. You are correct on the part numbers. Good to know. _________________ 1977 Westy, Automatic. Big Valve heads, CS Cam. |
asbug Samba Member
Joined: January 01, 2008 Posts: 287 Location: N.W. Ga.
Posted: Tue Dec 23, 2008 6:53 am Post subject: |
So if I understand correctly,
The AFM doesn't matter if it came from an Automatic or a manual as long as it's a 7 or 6 pin respectively?
Thanks,
My early 76 Westy Automatic Delux has a 1.8L and a worn AFM plate, I have moved over the plate and it runs great now (after alot of work....) and am going to be looking for a better AFM for the thing...
Thanks,
KC  |
kevin77westy Samba Member
Joined: November 12, 2004 Posts: 796 Location: Ocean Springs, MS
Posted: Tue Dec 23, 2008 8:54 am Post subject: |
| kcandthez wrote: |
I have read it does matter but I have an auto and a manual and they don't seem to care which AFM is on them.. I've also interchanged lots of parts from different years when troubleshooting or putting FI on a bus and I have yet to have a problem crossing years as long as there are the right number of pins.. Just my experience, I am not a FI expert but I've taken three buses back to FI and each completed "mixed year" system has run great after a little troubleshooting and tweaking. Now if I can just fix all the mechanical problems! |
Karl Samba Member
Posted: Tue Dec 23, 2008 10:22 am Post subject: |
| kcandthez wrote: |
Thanks,
Thanks,
KC  |
No. You cannot use any 7 pin AFM in a mid 76 to 78 and 79 Fed bus. Only the 018 or the 020. 79 Calif is 7 pin but it is only for the one-year-only 79 Calif version. It is part number 0 280 200 022.
Also you cannot use Vanagon AFM's which are also 7 pin:
0 280 200 025 80 Calif which subs to
0 280 200 030 80-83.5 Calif
0 280 200 028 80 Fed which subs to
0 280 200 032 80-82 Fed
0 280 200 038 82 Fed |
Vamstad Samba Member
Joined: September 19, 2007 Posts: 223 Location: So Cal
Posted: Mon Jan 12, 2009 5:53 pm Post subject: |
Damn Karl, that is good information for me!!
I have a new, rebuilt AFM from a buddy that has the 018 part# that he was unable to return due to an open package (for his 77 FI bus).
Thinking that I had an AFM issue on my 79 FI Federal bus, I installed it (took out the stock 020)...did an idle speed adjustment (dwell and timing fine) and my bus ran like a champ! We are talking a real "smooth operator".
When I paid closer attention to the part numbers on the box (from fuel injection corp) I was surprized to find the part number difference. I was really, really close to purchasing a different AFM to match my bus exactly....until I read your post.
Just to confirm, you mentioned that a 020 would work in the place of a 018. How about the reverse of this (018 rebuild in place of the stock 020) like my setup?
Thanks again! _________________ Fear is the mind killer.
1979 Federal Westfalia
2.0 FI |
Posted: Mon Jan 12, 2009 6:42 pm Post subject: |
| i also want to know if the 018 is usable in a 77-79 bus |
1977_L63H_P27 Samba Member
Joined: January 17, 2006 Posts: 2345 Location: Bristol, Tennessee
Posted: Mon Jan 12, 2009 8:05 pm Post subject: |
| vw76westy wrote: |
Two post' above this one...
| Karl wrote: |
| You cannot use any 7 pin AFM in a mid 76 to 78 and 79 Fed bus. Only the 018 or the 020. |
Not trying to be a smart a__. Just pointing out the obvious. Peace! _________________
| busdaddy wrote: |
...and try a few chubby ones until you find one you like.
1977 Westfalia P27
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club |
asbug Samba Member
Posted: Tue Jan 13, 2009 9:33 am Post subject: |
| Kar wrote: |
| No. You cannot use any 7 pin AFM in a mid 76 to 78 and 79 Fed bus. |
Karl,
Since my August 1975 Build '76 model has a 1.8L with an early L-Jet system, and has a 6 pin AFM, can any old 6 pin work on my system?
You seem to be in the know on these things.
I appreciate your time,
KC  _________________ 1969 Ghia Vert - Jenny.
2004 B5.5 Passat Wagon - no name yet.
2012 Routan - Urban Assault Vehicle. |
dweomer21 Samba Member
Joined: October 26, 2008 Posts: 3 Location: Seattle, WA
Posted: Tue Jan 20, 2009 1:10 pm Post subject: |
Karl, are you getting your info from any place in particular, or just from general past experience? I ask because I'd like to know if this AFM on ebay (ref. Carter part# 349-028) would be compatible with my '82 Fed. M/T Camper (my current damaged AFM # is 280 200 028 / 071 906 301A).
I don't mind doing the research myself, if I knew where I could cross-reference part #'s and such. Also, I don't want to fork this thread too much, or get off topic; if I crossed the line there, my apologies  |
davis911s Samba Member
Joined: July 07, 2005 Posts: 976 Location: Lethbridge, Alberta, Canada
Posted: Tue Jan 20, 2009 10:29 pm Post subject: |
So what about for a 75 AUTOMATIC? Are these interchangable or a one year only?
Shawn _________________ "I choose to use CAA on old cars with character...instead of car payments on a new car "
1973 Westfalia, Camper Special with 75 FI. Automatic 003 . Non-pop top
1977 Porsche 911S Targa, 2.7 L with 5spd
1992 Passat G60 Syncro Wagon (SOLD)
1975 Westfalia (SOLD)
1979 Westfalia (SOLD) |
