Tranny question
rogerm
rogerm is offline
PostPosted: Mon Jan 12, 2009 6:37 pm    Post subject: Tranny question Reply with quote
My bus is a 68 camper (Penthouse). When I bought my bus the PO broke a piece of my trannys bell housing where the left bottom motor mount is (probably from not supporting it when pulling the engine). I didnt notice when I bought the bus because if you tighten the other engine to tranny bolts first it slips right in place and doesnt even look cracked at all. What kind of metal is the tranny case made of? It looks like it could be a easy fix if it can be welded or will I have to find a new bellhousing? I want to fix this before I hit the road this spring, Thanks
busdaddy
busdaddy is offline
PostPosted: Mon Jan 12, 2009 6:44 pm    Post subject: Reply with quote
The trans is high in magnesium, weld if you dare. You may be able to do without one bolt if the other 3 are good, or find another bellhousing. If it's a 68 only trans with the ring of nuts around the output shafts you may have to find another similar trans. as most of that stuff doesn't interchange well, beware.
Слава Україні!
dan macmillan
dan macmillan is offline
PostPosted: Mon Jan 12, 2009 7:22 pm    Post subject: Reply with quote
Welding magnesium is not advised. Once it lights on fire you will not be able to put it out. Water only feeds the fire. The preferred extinguisher is sand.
Licensed Automotive Service Technician
Licensed Truck and Coach Technician
Licensed Heavy Duty Equipment Technician
CFC/HCFC/HFC A/C handling and installation license
Alignment specialist
66 Modified Manx,68 Kyote,74 Thing,74 Beetle, 76 Transporter,75 self made Double Cab,65 Meyers Manx,78Westy,68 Ghia, 79 Bradley GT2
Current projects:
Built for others:69 Manx Clone
dbo550
dbo550 is offline
PostPosted: Mon Jan 12, 2009 7:36 pm    Post subject: Reply with quote
If none of the mounting points are messed up than I wouldn't sweat it. I've had water cooled vws with chunks missing from the bell housing and never had a problem out of them.
1985 Westy
2001 Audi Allroad
1999 Volvo v70 xc
1995 Volvo T5-R, Yellow
1998 Jetta GLX
rogerm
rogerm is offline
PostPosted: Mon Jan 12, 2009 7:37 pm    Post subject: Reply with quote
Thanks I wont try welding it, I think I'll try looking for a bell housing from busted bus Thanks again
