Custom Heat Riser Location?
Page: 1, 2, 3, 4  Next
sxuxrxf
sxuxrxf is offline
PostPosted: Wed Dec 17, 2008 3:16 pm    Post subject: Custom Heat Riser Location? Reply with quote
I need to add the heat riser mounts to my header and am wondering if there is a better place to put them.
I came across a suggestion for putting the right side in the standard location, but putting the LEFT side near the collector. What would be the benefit of this?
Any thoughts?
(ignore the X's )
KevinAlbrecht
Location: Ocean City > Boca > Pompano > Kirkland > Eugene > Sarasota
KevinAlbrecht is offline
PostPosted: Wed Dec 17, 2008 3:23 pm    Post subject: Re: Custom Heat Riser Location? Reply with quote
Any thoughts?
I think I read that from Bob Hoover. I have no welding skills, but would love to do it. The point of it, is by relocating the one side downstream, you create a negative pressure towards the side downstream. Thus drawing the exhaust from the positive pressure side flowing down to the negative side.
Would help heat the intake and prevent clogging.
Kevin Albrecht
1963 Panel
Don't forget those seat-belts!
Click to view image
sxuxrxf
sxuxrxf is offline
PostPosted: Thu Dec 18, 2008 12:20 pm    Post subject: Reply with quote
thanks, I'll give it a shot.
(ignore the X's )
KevinAlbrecht
PostPosted: Thu Dec 18, 2008 2:10 pm    Post subject: Reply with quote
Please share your progress. - Kevin
Kevin Albrecht
1963 Panel
Click to view image
Eaallred
Eaallred is offline
PostPosted: Thu Dec 18, 2008 5:26 pm    Post subject: Reply with quote
The way the heat risers work with an aftermarket header, the exhaust gases end up flowing back and forth, rather than flow through like it would on a stock manifold.
Relocating one side down near the collector will make it perform like stock.
Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn.
Bob Hoover
Bob Hoover is offline
PostPosted: Thu Jan 01, 2009 10:58 am    Post subject: Re: Custom Heat Riser Location? Reply with quote
Any thoughts?
Lotsa benefits. Better fuel vaporization is the biggie.
It would help you understand the situation if you can get your hands on a rusted-out STOCK muffler. Put a thin grinding wheel into your angle-head grinder (both avail. from Harbor Freight) and cut the belly out of the big 'can' (it's actually an 'expansion chamber.' the only 'muffling' is being done by the peashooters). Once you can see the INSIDE of the 'muffler' you will see that the heat-riser is damn near 4 feet long! It takes the OUTPUT of the heat riser and dumps it into the throat of the right-hand side outlet. The length plays a role in the muffling qualities but you can cheat a bit and no one will notice. When VW de Mexico began running juicers, which need CLEAN oil, they copied the Subaru oil pump/filter adapter, and stuck the oil filter over on the left-hand side. This made it kinda tricky to install the stock muffler so they moved the hear-riser OUTLET over to the RIGHT-hand side of the 'muffler,' putting the INLET on the LEFT. With regard to the engine's heat-flow nor carburetion -- as with any other 'flat' engine using a single center-mounted carb, VW's need a LOT of carb heat. VW de Mexico simply did a right-to-left swap.
Then someone comes along with an after-market exhaust system and FAILS to provide a proper OUTLET for the heat-riser system. Car doesn't run for shit and all the guy's buds tell him he's got to install dual carbs to fix it.
Welll.... actually, he don't. What he's got to do is to provide a PROPER OUTLET for the heat-riser system. And cutting open a stock muffler will show you what's involved in a PROPER system.
Basically, you have to put the OUTLET in an area of LOW PRESSURE, such as just in front of one of the outlet pipes. One way to do that is to use a step-drill to put a HOLE in the bottom of the COLLECTOR of your after-market system and use it as the outlet from your heat riser. That is, you tack-weld that small-diameter pipe from the stock muffler into the hole you just made then heat & bend it about a dozen times until you've the flanged fitting up to where it's a good fit with the flanged fitting on your intake manifold (HINT: It's a good idea to clean your heat riser before doing all this. Stock heat-riser tends to clog after fifty, sixty thou.)
So why do all the after-market exhaust systems come with the heat-riser outlet welded to the #4 exhaust stack? Actually, they don't. The GOOD ones, like the old EMPI, run the heat riser just as I've described above. And that puppy worked a treat! But at about $200, the typical VW owner simply couldn't afford it. So they bought one of those after-market POS jobbies... and found they'd just bolted a lot of problems onto their engine.
The heat-riser system isn't any mystery. Nor does it reflect any kind of 'trick' system, it's just basic physics ...and good engineering.
-Bob Hoover
sxuxrxf
sxuxrxf is offline
PostPosted: Wed Jan 14, 2009 6:51 pm    Post subject: Reply with quote
So, I'm ready to tackle this project this weekend. Here's a pic:
Can the right side use either #1 or #2? I'm guessing #2 is hotter = better. I was just thinking for easier/cleaner install.
Since the right side will be the inlet, instead of coming off the header at 90°, maybe make it more of a "Y" than a "T" to scoop up the exhaust.
For the left side, can I enter the collector anywhere? I was told that after-market set-ups use #2 and #4 for a pulsing effect. We are tying to create more of a one-way flow, right? I would like to enter either on the left side or top - does it matter? I will join the tube at an angle so that the return "feeds" into the exhaust in the same direction.
What do you think of wrapping the pre-heat tubes with the muffler wrap to hold in the heat better?
I just got my new manifold also. The pre-heat tube goes all the way to the carb, rather than just flowing thru the base.
Thanks for all of your input. I'll post pics of the outcome next week.
(ignore the X's )
KevinAlbrecht
PostPosted: Wed Jan 14, 2009 7:33 pm    Post subject: Reply with quote
sweet, keep us posted.
Kevin Albrecht
1963 Panel
Click to view image
sxuxrxf
sxuxrxf is offline
PostPosted: Sun Jan 18, 2009 11:59 pm    Post subject: Reply with quote
It's finished! It will be a while before it runs, but at least the hard part is done.
I had to cut up the stock heat tubes and add metal to get them in the right position so that the connections would be under the tin. Now the tin slides around the tubing. I still need to make a couple of small sections to cover the slots.
Hopefully this keeps the manifold nice and hot!
(ignore the X's )
KevinAlbrecht
PostPosted: Mon Jan 19, 2009 2:02 pm    Post subject: Reply with quote
sxuxrxf wrote:
It's finished!
Looks awesome!
Kevin Albrecht
1963 Panel
Click to view image
Bob Hoover
PostPosted: Mon Jan 19, 2009 8:41 pm    Post subject: Reply with quote
It should.
-Bob Hoover
PS -- Nice job. You owe yourself a cool one :-)
Scott Novak
Scott Novak is offline
PostPosted: Mon Jan 19, 2009 9:47 pm    Post subject: Reply with quote
The question I have is how do you go about cleaning out the carbon that will eventually clog the heater passage inside the intake manifold?
I would that periodic cleaning before it completely clogs with carbon would be in order.
Has anyone had any experience cleaning the carbon out of this type of intake manifold?
Scott Novak
Runboy
Runboy is offline
PostPosted: Mon Jan 19, 2009 10:27 pm    Post subject: Reply with quote
In my opinion they are cheap enough that should they become clogged, just toss it and get a new one.
That is my plan on my "mileage master" intake.
I don't believe anyone that says they can completely clean an original manifold out! Rolling Eyes
I have played around with that a bit, cut one open etc.
I have also been wondering if the buildup will be not so bad on modern pump gas vs the old leaded that original manifolds would have run on.
Mike
Runboy
Runboy is offline
PostPosted: Mon Jan 19, 2009 10:29 pm    Post subject: Reply with quote
Also, how about using one of those "turbo hats" and fabbing a hot air pickup up to the single IDF for clod weather running?
Mike
Bob Hoover
PostPosted: Tue Jan 20, 2009 5:18 pm    Post subject: Heat Riser Reply with quote
Somewhere between 50,000 and 70,000 miles of service, in association with some other task that requires dropping the engine and removing the heads, the heat-riser is cleaned using abrasives and a flexible wand, such as rubber tubing.
Some dealers had enough business to support a full inventory of 'exchange' parts, literally overhauling the old/used part and swapping it out against the customer's part. In that case, the entire intake manifold would be overhauled by removing the gross carbon build-up using abrasives, followed by cold-tanking the part repeatedly until the heat-riser was perfectly clean. The part was then primed & painted, often with decals or other markings that identified the dealer.
-Bob Hoover
Eaallred
Eaallred is offline
PostPosted: Tue Jan 20, 2009 5:26 pm    Post subject: Reply with quote
sxuxrxf, that looks great!
Now if only header manufacturers would offer something like that. Well done!
Eric Allred
Runboy
Runboy is offline
PostPosted: Tue Jan 20, 2009 9:40 pm    Post subject: Reply with quote
I have done three similar setups and am glad that the word is getting around about the "fix" for proper heat riser performance.
I would sure like to hear back how that single IDF with the modified heat riser runs for you.
I would like to do a larger carb setup on my bus but the dual carb tuning/linkage just ain't happening on my daily driver.
Mike
sxuxrxf
sxuxrxf is offline
PostPosted: Tue Jan 20, 2009 10:29 pm    Post subject: Reply with quote
Thank you very much! Very Happy
It will be on the dyno soon for tuning.
(ignore the X's )
Mongo63
Mongo63 is offline
PostPosted: Wed Jan 21, 2009 1:14 am    Post subject: Reply with quote
Scott Novak
A length of clutch cable in an electric drill works well for this, picked that up from 80's Yamaha dirtbike manuals. Wink
Southside Buggistas VW & kit car club
www.southsidebuggistas.com
Mongo only pawn in game of life...
mharney wrote:
Behold the true power of the extractor! Mongo has it right!
TallKewl7
TallKewl7 is offline
PostPosted: Wed Mar 04, 2009 7:30 am    Post subject: Reply with quote
I read this thread a while back. I'm running a single Dellorto DRLA 40 on my 1835 in a Baja. I've been having carb problems up the wazoo. (Kids, don't put a carb up your wazoo. I'm a trained professional with the proper safety equipment.) So I decided to implement this modification to my car. I started the fabrication last night. It's still pretty rough, but you get the general concept.
Right side:
Left side:
At the collector: (I plan on making a slip connection here. Take the springs off the collector, raise the collecter enough to slip the preheat tube in and slide it back down, trapping the preheat tube in the process)
Marshall
www.socalbajas.com
Page 1 of 4
