Cargo floor welding...
Page: Previous  1, 2, 3  Next
Campy
Campy is offline
PostPosted: Tue Jan 20, 2009 12:04 pm    Post subject: Reply with quote
Make sure that the battery is out of the vehicle before you do any welding on the body.
Before I started welding on the cargo floor halves, I spread out weights (bags and boxes of tire chains that I got stuck with) on the floors above the supports. Instead of drilling holes in the floors, I tack welded the bottom of each low point of the floor to the top of each side of the cargo floor support. It worked fine but it wasn't the stock way to do it, so I am going to try using my Marquette one-sided spot welder, next time, and see if it does the job (I hate plug welds).
Don't worry; be happy. (Baba)
BulletBus
BulletBus is offline
PostPosted: Tue Jan 20, 2009 12:44 pm    Post subject: Reply with quote
If it's not belly pan bus, wield the floor to the cross members from underneath. No drilling and plenty strong. Did it on my 58 with no problems. Just another way, although not how the factory did it. I used POR 15 top and bottom after all was complete.
53 Hatch Barndoor
If it's not a bus, it's bus money waiting to happen.
billzer06
billzer06 is offline
PostPosted: Thu Jan 22, 2009 9:05 am    Post subject: Reply with quote
I was considering the tack welding from underneath, but then decided I would mount a laser level on top of the roof, align it along the cross braces, then lay the floors in and draw dotswhere the level is shining on it (has to be straight above it), then drill it and plug weld it. its going to take forever, but so does everything else on these things. I will post pictures of my progress on here as I go. so far the floors are 95% cut out, so just gotta finish that
Glenn A
Glenn A is offline
PostPosted: Thu Jan 22, 2009 9:46 am    Post subject: Reply with quote
camerod wrote:
IF you have a TIG welder with a spot timer, this is the ultimate tool...
http://www.tectorch.com/tec%20spot%20gun.htm
you need a spot timer for it to work right...kinda works like a resistance (prong type) spot welder, so it uses no filler metal BUT you only need access to one side....
What can you expect to pay for one of these ?
mannys66 wrote:
In all my years, I have never given one thought about a blow up doll's feelings, until today......I feel sorry for it.
60 Double cab
65 EzCamper
66 Double cab
62 Kombi
2017 Golf R
camerod
Volksfab
camerod is offline
PostPosted: Thu Jan 22, 2009 11:13 am    Post subject: Reply with quote
the water cooled version is about $385 accessory kit about $50
I think the gas cooled unit is around $300?
gas cooled obviously lower duty cycle but will never be used at max capacity on sheetmetal, so you should be able to go all day!
you can get them through Indiana Oxygen online, but It is special order only.
DON'T SHIT WHERE YOU EAT!
Gmiee5
Gmiee5 is offline
PostPosted: Thu Jan 22, 2009 2:19 pm    Post subject: Reply with quote
How about this
The spot weld gun attaches easily to your home arc welder
http://www.eastwoodco.com/shopping/product/detailm...=undefined
Did anyone try this?
Dynamite_Goat
Dynamite_Goat is offline
PostPosted: Thu Jan 22, 2009 2:54 pm    Post subject: Reply with quote
Gmiee5 wrote:
How about this
I have one of those, but I could never get it to work worth a darn. Maybe I'm doing something wrong, but it pretty much sucks. Rolling Eyes
BarryL Premium Member
BarryL is offline
PostPosted: Fri Jan 23, 2009 8:28 am    Post subject: Reply with quote
Looks like you still must hold the ground electrode opposite the gun electrode. I'd think that you would need lots of pressing to do it up right.
zao
zao is offline
PostPosted: Fri Jan 23, 2009 9:05 am    Post subject: Reply with quote
What type of metal glue were you guys refering to? It would be a huge help for my battery tray along the outside wheel well paint side so I don't have to repaint it.
-Kevin
skidmarksgarage.com
skidmarksgarage.com is offline
PostPosted: Fri Jan 23, 2009 9:26 am    Post subject: Reply with quote
http://www.evercoat.com/productCategory.aspx?cat=41
Use as directed, I wouldn't use this on a floor but for that Batt. tray may be the ticket. I'll be using this on my bus when I put on the new Qtr. panel where it meets the outer wheel house.
Mark
zao
zao is offline
PostPosted: Fri Jan 23, 2009 7:23 pm    Post subject: Reply with quote
Cool, Thank you.
-Kevin
ekimikem
ekimikem is offline
PostPosted: Sat Jan 24, 2009 10:04 am    Post subject: Reply with quote
smokeybus wrote:
Gmiee5 wrote:
How about this
Anyone tried one of these? I would be tempted to try one if I owned an arc welder.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=98753
mike jansen
mike jansen is offline
PostPosted: Mon Mar 09, 2009 9:39 pm    Post subject: welding floors Reply with quote
cant you weld the floors from underneath?
Doug914
Doug914 is offline
PostPosted: Tue Mar 10, 2009 1:23 pm    Post subject: Re: welding floors Reply with quote
Thats the way i'm going to do mine. Might not be what was original, but it sure will be neat, strong, and less work. The edges I'll probably plug weld. Have to see once i get into it..
Stocknazi
Stocknazi is offline
PostPosted: Mon Feb 04, 2013 9:43 am    Post subject: Reply with quote
anyone used the harbor freight 240 spot welder?
WANTED:
Thomas Jefferson
BarryL is offline
PostPosted: Mon Feb 04, 2013 11:32 am    Post subject: Reply with quote
I have that one. Works good but it sure is heavy. It gets hotter than Hades. You have to keep the electrodes filed flat and adjusted for pressure and proximity but I think that applies for all spot welders.
zozo
zozo is offline
PostPosted: Mon Feb 04, 2013 11:51 am    Post subject: Reply with quote
Here's a cheap alternative:
http://www.instructables.com/id/How-to-Make-a-Spot-Welder-for-Cheap/
fredy a
fredy a is offline
PostPosted: Mon Feb 04, 2013 4:11 pm    Post subject: Reply with quote
sled wrote:
I have found that if you have a good enough MIG welder (powerful enough) you can crank the heat up with a slower wire speed...this will burn right through the cargo floor and into the tophats/I beams and the slow feed of wire will add just enough rod to make a nice little flush puddle.
PLEASE practice this on scrap metal first, it takes very fine adjustment to get this technique right...BUT it will save you hours of drilling holes. Spend a couple short evenings on your knees with a MIG torch and youre done.
thanks man I going to practice thes
sorry for the spelling
Stocknazi
PostPosted: Wed Mar 20, 2013 9:29 am    Post subject: Reply with quote
i am still looking for opinions on how to attach the rear section of cargo floor to the tank support shelf
how have you done this?
opinions?
WANTED:
Thomas Jefferson
glideking
glideking is offline
PostPosted: Wed Mar 20, 2013 10:19 pm    Post subject: Reply with quote
I will be doing a video of how I weld the cargo floor to the tank support shelf as soon as the floor arrives from Klassic Fab. I have the advantage of welding with the truck upside down in a rotisserie.
"The more I get done the less it looks like I did anything"
1959 Single Cab Restoration"Funky Truck"
http://www.thesamba.com/vw/forum/viewtopic.php?t=5...highlight=
1965 21 Window Restoration Thread (From old photos)
http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight=
1963 Panelvan build "Tyvanosaurus Wrecks"
http://www.thesamba.com/vw/forum/viewtopic.php?p=8351639#8351639
Page 2 of 3
