71_georgia_beetle Samba Member
Joined: March 24, 2008 Posts: 360 Location: Grayson, GA
Posted: Sun Feb 01, 2009 9:52 am Post subject: How To** Replace a Bay Outside Window Scraper |
#1 Tape off the entire inside of the window frame with a low adhesive, auto or painters tape. This will prevent the inevitable scratches.
#2 Pry out on the crank handle cover to release. You can use a screw driver but your fingers in the weakest "middle" section work just fine.
#3 Take out the center screw and remove the handle.
#4 Remove the two screws that secure the door handle, pull out slightly and twist inward to remove.
#5 Use a flat screwdriver to remove the finger cup of the door handle and then a phillips to remove the handle trim.
#6 Use a flat screwdriver or panel clip removal tool to release the panel.
#7 Carefully peel down the vapor barrier. If you do not have them, this would be a good time to install.
#8 Using a 10mm wrench or socket, release the window from the regulator. (2) bolts.
#9 Pry out the inner scraper. Careful not to bend the wire out of shape.
#10 Pry out the felt channel. This should be a one piece unis that runs from the vent window, out to the back of the door and down inside the door. There might be a 10mm bolt holding down the bottom near the lock.
#10a Once released, slide it up and out of the door.
#11 Remove the vent window secure screw.
#12 The next step is difficult to document. Pull the window glass and the vent window back towards the lock side of the door so that the vent window clears the frame. Next, pull the vent window in slightly towards the vehicle. At the same time with the vent window on the outside of the frame, push it towards the front of the vehicle and rocking back and forth, pull up about 2". Once this is done the glass can clear the frame and be removed. Next, pull straight up to remove the vent assembly.
#13 Carefully pry out on the old scraper to release the clips.
#14 Pull the old scraper towards the front of the vehicle at the same time pull down to remove.
This is a great time to get a cloth, soap and water and clean up the door panel, door frame, clean vent, etc. Lube lock, regulator, etc.
#15 When installing the new scraper, push it out so that you can see and correctly align the holes to clips. (and no that's not a dent, it's a shadow)
To reinstall all removed items simply turn the directions upside down! Good luck! _________________ 71 Standard Beetle "Big Bird"
74 Westfalia "Winifrid"
Call me if I need you!
www.burelphotography.com |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79584 Location: Sneaking up behind you
Posted: Sun Feb 01, 2009 9:55 am Post subject: |
You've been busy.
Rob... remember doing them one yours? It's a sucky job, but worth the effort.
The hard part is getting the vent window in without denting the trim. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Justin  Samba Member
Posted: Sun Feb 01, 2009 1:38 pm Post subject: |
Dude, 71_georgia_beetle, thanks! I'm gearing up to do mine sometime between now and this summer, and I've never done it before. This will be most helpful.
Thanks. (high five) |
Posted: Sun Feb 01, 2009 4:28 pm Post subject: |
rogers_68 wrote: |
You are quite welcome. The first one took around and hour, that included taking pictures. The second, in real time with no documentation, 30min. Take you time and it's not that bad. _________________ 71 Standard Beetle "Big Bird"
ccederholm Samba Member
Joined: February 08, 2009 Posts: 74 Location: weymouth, ma
Posted: Sun Feb 22, 2009 1:11 pm Post subject: ventage |
hey thanks for the photos will def come in handy on my 68' |
norcalmike Samba Member
Joined: May 14, 2005 Posts: 4784 Location: Marina, CA
Posted: Sun Feb 22, 2009 1:15 pm Post subject: |
Great tutorial. i think most everyone has this on their "to-do" list |
visibleink Samba Member
Joined: May 03, 2002 Posts: 1669 Location: Austin, Texas
Posted: Sun Feb 22, 2009 5:37 pm Post subject: |
Nice write up and pics......it's a bit harder than it looks!! _________________ Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
<-- Helga, she slammed her dub in '53 and adjusted valves with her teeth |
Bursch Samba Member
Joined: October 28, 2006 Posts: 448 Location: Netherlands
Posted: Sun Feb 22, 2009 5:56 pm Post subject: |
Thanks for the write-up
still got this one on the to do list indeed. Would certainly keep a lot of water out of the door! _________________ 1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
Camper Special Club Member |
sofakingcool Samba Member
Joined: November 13, 2007 Posts: 405 Location: Lexington, SC
Posted: Sun Feb 22, 2009 6:01 pm Post subject: |
Did mine without removing the glass (dumb) its a pain in the butt and the trim got kinda bent up.. these pieces are delicate so be careful! |
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Sun Feb 22, 2009 7:16 pm Post subject: |
When I did mine, I dent the trim (cos I put that in last) but I scraped my paint with the sharp bottom edge of that blasted vent window. This is one job where it helps to have a good vocabulary of swear words.  _________________ ---------
Rubber Duck
1974 Westfalia |
Posted: Sun Feb 22, 2009 7:18 pm Post subject: |
sofakingcool wrote: |
Yeah someone said that before but I like having the wiggle room with the window out. Hell I had to do it all over again. The vent window seals that I ordered back in October just go in and you have to basically pull all that stuff again. I recommend doing it all at the same time if yours are bad.
Nice to have it done though, huh? _________________ 71 Standard Beetle "Big Bird"
jl74supercab Samba Member
Joined: April 13, 2007 Posts: 172 Location: Flemington, NJ
Posted: Wed Feb 25, 2009 11:48 am Post subject: |
I am getting my bus ready for paint and was just up to taiking out the glass and removing the handles. Great post. Thanks _________________ 73 Riviera Camper - "Julius"
74 Super Convertible - "Someday" |
skid Samba Member
Joined: January 16, 2009 Posts: 1329 Location: Vancouver, BC
Posted: Wed Feb 25, 2009 2:13 pm Post subject: |
thanks! i have to do this soon and it was rad to see this. also, great paint color choice! |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5975 Location: Los Alamos, New Mexico, USA
Posted: Wed Feb 25, 2009 4:06 pm Post subject: |
I sure wish I had done this at the time I replaced the window regulator on one side and the vent window on the other. That was a real pain, and doing this would have been just a little bit more work at that point. Now I get to do it all over again some day. Not today. Or tomorrow...  _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
grandfatherjim Samba Member
Joined: April 23, 2007 Posts: 182 Location: near Ottawa, Canada
Posted: Mon May 11, 2009 12:28 pm Post subject: |
Are the outer scrapers only available with the integral chrome trim?
I'm trying to get rid of the chrome on my bus.
Thanks,
Jim |
Posted: Mon May 11, 2009 6:12 pm Post subject: |
The only ones I've seen are aluminum. _________________ 71 Standard Beetle "Big Bird"
enjoispammy8 Samba Member
Joined: December 26, 2007 Posts: 1984 Location: Long Beach, CA
Posted: Mon May 11, 2009 6:44 pm Post subject: |
im saving this. good job. _________________ 1969 Westy, 1690cc. montana red and cloud white.
1969 Standard Beetle [sold]
Watch My Movies: https://www.youtube.com/user/taylorlikesacdc
Desertbusman wrote: |
Is there a message here? Enjoy Spammy Ate |
EZ Gruv wrote: |
Way to fuck up some little kids riding in the car next to you. |
hazetguy wrote: |
you need to be doing better drugs. |
mranker Samba Member
Joined: April 11, 2006 Posts: 271 Location: Pasadena, CA
Posted: Mon May 11, 2009 7:53 pm Post subject: |
I just did this while I installed the door seal kit from Bus Depot and this tutorial was super helpful. Thanks georgia beetle. I think there may be an extra step for early bay folks. When I was trying to remove the vent window on my '70 after step 11, I noticed there was a 10 mm bolt holding it in just to the rear of the window crank. I'm not sure if georgia beetle's bus has this but mine did. |
Mr. Loaf Samba Member
Joined: March 30, 2005 Posts: 2098 Location: Okra, Oklahoma
Posted: Tue May 12, 2009 3:16 am Post subject: |
Good tutorial. If you are going to use a screw driver around your door panels tape that off as well. One thing I learned from doing this in the past is that the new clips that come with the scrapers are not near as good as the OG ones. You can pull out the new spring clips from the new scrapers and use your old ones. They will hold better than the replacements. _________________ Never drive faster than your Angel can fly
$24,100 was too hard to resist................. |
rbossert Samba Member
Posted: Wed Aug 12, 2009 9:17 pm Post subject: |
After replacing the felt and scrapers my window is very difficult to roll up. Is this normal and can I do anything about it? |
