Baywindow Mud Flap Bracket Plans FAQ
Page: 1, 2, 3  Next
71_georgia_beetle
71_georgia_beetle is offline
PostPosted: Sun Feb 01, 2009 9:49 am    Post subject: Baywindow Mud Flap Bracket Plans FAQ Reply with quote
Not sure of the original poster of the drawn plans but I have revised them and documented the build. Enjoy.
FULL SIZE <-----Click Here
Brought to you by The New Redneck Workshop!
The metal I chose was 1/8" steel for the main bracket and 22gauge for the well extension. Both pieces were purchased at Lowes around $15.
Lay out all the plans on the steel. Double check the hole location as each pair or flaps may vary slightly. You can see a few tools needed, square, ruler, markers, straight edge, etc.
I tested three types of cutting tools. Jigsaw, cutoff wheel and Dremel with a cut off wheel. The cut off tool left the edges to ragged, the Dremel was to flimsy and I kept breaking discs so I settled on the jig saw. Here is a tip: I had to switch to a full face mask. For some reason the jigsaw threw up hot steel pieces so fast that they would bounce off my cheek, ricochet off the inside of my glasses and back in my eyes.
I used a 40lb lug of steel to hold when clamps get in the way.
Finished cut outs.
Use a punch to locate the holes and eliminate bit drift.
Brace/clamp the steel to prevent it from spinning and drill out the holes. I used a floor drill but a handheld will work fine.
At the marked line, clamp the main brace and bend it over 90 degrees (don't forget the small tab). Also remember that the left side and right are different bends. The plans show a LH main bracket.
Check and adjust with a square. Close is OK because there will be some on car tweeking.
Lightly form the extension in the same fashion. This will be tweeked as well.
Shot of the initial forming.
Mock up. This is a prime time for a test fit and tweek. No need for a full mounting, I just clamped it in place.
After the mock up, sand, prime and let dry. I hastened the process with my $24.00 paint boot oven (space heater). Remember that the mock ups for each side will differ. Be sure to keep the pairs together.
Shoot with color of choice, dry and fit. Hand tighten everything, do not fully tighten.
Different angle.
Back view.
Full back view.
This is where you will need to mark up with the bracket and drill for the second hole.
This is where the well extension will mount. It will mount on the inside of the inner well, meaning you can see it if you are looking in the fender well.
Here is a view from the well side of the final mount.
Here is a view of the backside of the mount.
Completed pictures. Once you have them mounted, there is enough flex and give in the metal that you can manipulate it. In the picture, the drivers side is not level. I corrected this with a stiff pull up. Good Luck!
PDF here
https://www.thesamba.com/vw/archives/info/bay_window_bus_mud_flap_bracket_template.php
71 Standard Beetle "Big Bird"
74 Westfalia "Winifrid"
Call me if I need you!
www.burelphotography.com
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Sun Feb 01, 2009 9:51 am    Post subject: Reply with quote
Very nice... thanks for sharing.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
71_georgia_beetle
PostPosted: Sun Feb 01, 2009 4:43 pm    Post subject: Reply with quote
Correction on the material: Lowes Item #11665 1/8" x 3" x 26"
Lowes Item # 11771 6" x 24" 22ga
itlives
itlives is offline
PostPosted: Sun Feb 01, 2009 5:42 pm    Post subject: Reply with quote
Good job! Very Happy
fusername
fusername is offline
PostPosted: Sun Feb 01, 2009 7:19 pm    Post subject: Reply with quote
extra detail is key for any write up, and yo uhave it down pat. well done sir.
one question, why do you even HAVE a 40lb slab of steel? inquiring minds want to know.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
71_georgia_beetle
PostPosted: Sun Feb 01, 2009 7:29 pm    Post subject: Reply with quote
I had a friend that worked for a company that manufactured HVAC ducts and when they closed their door they let us have a free for all (except manufacturing equipment). I got a couple of lugs of steel, stainless bolts, nuts and washers out the wazoo, drafting supplies, sheet metal, rivets, air hoses.........and on and on. Every now and then I'll have a project and not have what I need and remember exactly where it was in the warehouse and if I had only grabbed.............
Bleyseng
Bleyseng is offline
PostPosted: Sun Feb 01, 2009 9:50 pm    Post subject: Reply with quote
where did you find the mudflaps with the white VW logo??????????
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles
71_georgia_beetle
PostPosted: Sun Feb 01, 2009 10:07 pm    Post subject: Reply with quote
This guy adamsvw pops up on ebay every now and then with a hell of a deal on these NOS flaps. 1/2" thick and 2.5lbs each.
Anchovy
Anchovy is offline
PostPosted: Mon Feb 02, 2009 4:27 pm    Post subject: Reply with quote
Looks good!
What is the purpose of the notch in the top center of the bracket? Looks like it would be easier to make without and there doesn't seem to be any reason to have the clearance.
P.S. You are obviously a sick individual with a work bench that clean and organized.
71_georgia_beetle
PostPosted: Mon Feb 02, 2009 5:08 pm    Post subject: Reply with quote
Anchovy wrote:
Looks good!
The bottom hole is a stationary pivot and the notch is used for forward and aft adjustment. Basically it can be used to increase or decrease the distance between the tire and the bottom of the flap.
Anchovy
Anchovy is offline
PostPosted: Mon Feb 02, 2009 9:07 pm    Post subject: Reply with quote
I understand about the adjustment slot. I am talking about the big notch you are about to cut out in this photo:
71_georgia_beetle
PostPosted: Mon Feb 02, 2009 10:08 pm    Post subject: Reply with quote
Sorry about that. I keeps the harmonic balance down on the inner fender well! Shocked Hell, now that I think about it..........I don't know. These plans are a replication of the VW originals. Not sure why they had it.
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Tue Feb 03, 2009 8:37 pm    Post subject: Reply with quote
71_georgia_beetle wrote:
...These plans are a replication of the VW originals. Not sure why they had it...
Every racer knows that weight costs hp and the less weight the faster the car and...oh, wait...I forgot, this is a Bus forum Embarassed
Laughing
Very nice write-up Applause
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
baumer99
baumer99 is offline
PostPosted: Tue Feb 03, 2009 9:51 pm    Post subject: Reply with quote
Great instructions and fabrication technique. I used those original templates and then decided on a different design. I wasn't happy with the gaps between the brackets and the frame. I prefer a wider flap and a tighter fit to the body, so I ended going a similar but different route.
I bent an aluminum bracket to support most of the weight and give support.
Then I cut the mudflap from a larger piece designed for a large truck. I used a cardboard template to get the fit and angle right.
I used the height of the rim as a guide for how close to go to the ground. I mounted the rear outside cut piece with a bit of undercoating for extra protection. I also used undercoating to seal all of the drill holes.
The front was mounted directly to the front of the frame cross member. The front mud flap was basically a rectangle. I had to fabricate a bracket to hold the mudflap tight against the frame and cut out a small piece for the ridge in the frame. The bracket also has to go under this ridge.
I do drive on gravel roads quite a bit so the extra coverage keeps the mud from the undercarriage. I wish I did this years ago, a much cleaner undercarriage equals less rust.
________________________________
current 1991 Westy
previous 1978 Riviera Bay for 26 years
dweller
dweller is offline
PostPosted: Tue Feb 03, 2009 9:52 pm    Post subject: Reply with quote
Good god, that is one righteous post!
bookmarked for when i'm just pissed off enough to attempt it.
dp
77 Westie 2.0L FI ... slowly restoring bit by bit...
Riguy718
Riguy718 is offline
PostPosted: Tue Feb 03, 2009 10:54 pm    Post subject: Reply with quote
Those are some nice mudflaps. Does anyone manufacturer mudflaps with the VW emblem on them, or do you have to find some OG ones?
First Vehicle:
Bil(bo) 1970 Westy Stock [1600DP]
Take life slowly and enjoy it, especially in a VW bus!!!
71_georgia_beetle
PostPosted: Wed Feb 04, 2009 8:23 am    Post subject: Reply with quote
As far as I know you have to track down the originals.
panic_fan
panic_fan is offline
PostPosted: Wed Feb 04, 2009 10:00 am    Post subject: Reply with quote
Looks good Scott....you put my hinge idea to shame! Razz
Either way we are both ready for some Mud Ridin' !!
Rich
Brilliant Blue/Cloud White
1970 Baywindow Bus
http://www.thesamba.com/vw/forum/viewtopic.php?t=291988&highlight=
"Still learnin the way around my VW bay"
Teal Bay Bus
g16stu
g16stu is offline
PostPosted: Thu Mar 12, 2009 11:39 pm    Post subject: Reply with quote
I have the mud flap braket mount plans made up as a pdf, you can download it from the site from the link below,
it should be to scale, so all you need to do is print it off, stick it to your sheet metal and get cutting,
enjoy
http://www.thesamba.com/vw/archives/info/bay_window_bus_mud_flap_bracket_template.php
'72 westie
All comments made are in accordance with the Rules of the Yorkshire County Cricket Club.
PopeSutek
PopeSutek is offline
PostPosted: Fri Mar 13, 2009 6:04 am    Post subject: Reply with quote
I just bought them online new for 10 bucks.. Cheaper, easier, and no chance for mistakes.
"Today was good.
Today was fun.
Tomorrow is another one.”
old DKP driver wrote:
Suck,Squeeze,Bang,Blow.. No Blow=No Go. Rolling Eyes
Page: 1, 2, 3  Next
