71_georgia_beetle Samba Member
Joined: March 24, 2008 Posts: 360 Location: Grayson, GA
Posted: Sun Feb 01, 2009 9:49 am Post subject: Baywindow Mud Flap Bracket Plans FAQ |
Not sure of the original poster of the drawn plans but I have revised them and documented the build. Enjoy.
FULL SIZE <-----Click Here
Brought to you by The New Redneck Workshop!
The metal I chose was 1/8" steel for the main bracket and 22gauge for the well extension. Both pieces were purchased at Lowes around $15.
Lay out all the plans on the steel. Double check the hole location as each pair or flaps may vary slightly. You can see a few tools needed, square, ruler, markers, straight edge, etc.
I tested three types of cutting tools. Jigsaw, cutoff wheel and Dremel with a cut off wheel. The cut off tool left the edges to ragged, the Dremel was to flimsy and I kept breaking discs so I settled on the jig saw. Here is a tip: I had to switch to a full face mask. For some reason the jigsaw threw up hot steel pieces so fast that they would bounce off my cheek, ricochet off the inside of my glasses and back in my eyes.
I used a 40lb lug of steel to hold when clamps get in the way.
Finished cut outs.
Use a punch to locate the holes and eliminate bit drift.
Brace/clamp the steel to prevent it from spinning and drill out the holes. I used a floor drill but a handheld will work fine.
At the marked line, clamp the main brace and bend it over 90 degrees (don't forget the small tab). Also remember that the left side and right are different bends. The plans show a LH main bracket.
Check and adjust with a square. Close is OK because there will be some on car tweeking.
Lightly form the extension in the same fashion. This will be tweeked as well.
Shot of the initial forming.
Mock up. This is a prime time for a test fit and tweek. No need for a full mounting, I just clamped it in place.
After the mock up, sand, prime and let dry. I hastened the process with my $24.00 paint boot oven (space heater). Remember that the mock ups for each side will differ. Be sure to keep the pairs together.
Shoot with color of choice, dry and fit. Hand tighten everything, do not fully tighten.
Different angle.
Back view.
Full back view.
This is where you will need to mark up with the bracket and drill for the second hole.
This is where the well extension will mount. It will mount on the inside of the inner well, meaning you can see it if you are looking in the fender well.
Here is a view from the well side of the final mount.
Here is a view of the backside of the mount.
Completed pictures. Once you have them mounted, there is enough flex and give in the metal that you can manipulate it. In the picture, the drivers side is not level. I corrected this with a stiff pull up. Good Luck!
PDF here
https://www.thesamba.com/vw/archives/info/bay_window_bus_mud_flap_bracket_template.php _________________ 71 Standard Beetle "Big Bird"
74 Westfalia "Winifrid"
Call me if I need you!
www.burelphotography.com |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79473 Location: Sneaking up behind you
Posted: Sun Feb 01, 2009 9:51 am Post subject: |
Very nice... thanks for sharing. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Sun Feb 01, 2009 4:43 pm Post subject: |
Correction on the material: Lowes Item #11665 1/8" x 3" x 26"
Lowes Item # 11771 6" x 24" 22ga _________________ 71 Standard Beetle "Big Bird"
itlives Samba Member
Joined: July 12, 2005 Posts: 1424 Location: Shreveport La
Posted: Sun Feb 01, 2009 5:42 pm Post subject: |
Good job!  |
fusername Samba Member
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Sun Feb 01, 2009 7:19 pm Post subject: |
extra detail is key for any write up, and yo uhave it down pat. well done sir.
one question, why do you even HAVE a 40lb slab of steel? inquiring minds want to know. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Posted: Sun Feb 01, 2009 7:29 pm Post subject: |
fusername wrote: |
one question, why do you even HAVE a 40lb slab of steel? inquiring minds want to know. |
I had a friend that worked for a company that manufactured HVAC ducts and when they closed their door they let us have a free for all (except manufacturing equipment). I got a couple of lugs of steel, stainless bolts, nuts and washers out the wazoo, drafting supplies, sheet metal, rivets, air hoses.........and on and on. Every now and then I'll have a project and not have what I need and remember exactly where it was in the warehouse and if I had only grabbed............. _________________ 71 Standard Beetle "Big Bird"
Bleyseng Samba Member
Posted: Sun Feb 01, 2009 9:50 pm Post subject: |
where did you find the mudflaps with the white VW logo?????????? _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sun Feb 01, 2009 10:07 pm Post subject: |
Bleyseng wrote: |
where did you find the mudflaps with the white VW logo?????????? |
This guy adamsvw pops up on ebay every now and then with a hell of a deal on these NOS flaps. 1/2" thick and 2.5lbs each. _________________ 71 Standard Beetle "Big Bird"
Anchovy Samba Member
Joined: August 05, 2000 Posts: 2976 Location: San Diego, CA
Posted: Mon Feb 02, 2009 4:27 pm Post subject: |
Looks good!
What is the purpose of the notch in the top center of the bracket? Looks like it would be easier to make without and there doesn't seem to be any reason to have the clearance.
P.S. You are obviously a sick individual with a work bench that clean and organized. |
Posted: Mon Feb 02, 2009 5:08 pm Post subject: |
Anchovy wrote: |
Looks good!
The bottom hole is a stationary pivot and the notch is used for forward and aft adjustment. Basically it can be used to increase or decrease the distance between the tire and the bottom of the flap. _________________ 71 Standard Beetle "Big Bird"
Posted: Mon Feb 02, 2009 9:07 pm Post subject: |
I understand about the adjustment slot. I am talking about the big notch you are about to cut out in this photo:
Posted: Mon Feb 02, 2009 10:08 pm Post subject: |
Anchovy wrote: |
Sorry about that. I keeps the harmonic balance down on the inner fender well! Hell, now that I think about it..........I don't know. These plans are a replication of the VW originals. Not sure why they had it.
Air_Cooled_Nut Samba Member
Joined: March 27, 2004 Posts: 3068 Location: Portland, Oregon
Posted: Tue Feb 03, 2009 8:37 pm Post subject: |
71_georgia_beetle wrote: |
...These plans are a replication of the VW originals. Not sure why they had it... |
Every racer knows that weight costs hp and the less weight the faster the car and...oh, wait...I forgot, this is a Bus forum
Very nice write-up  _________________ Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion |
baumer99 Samba Member
Joined: September 16, 2008 Posts: 61 Location: Victoria, BC
Posted: Tue Feb 03, 2009 9:51 pm Post subject: |
Great instructions and fabrication technique. I used those original templates and then decided on a different design. I wasn't happy with the gaps between the brackets and the frame. I prefer a wider flap and a tighter fit to the body, so I ended going a similar but different route.
I bent an aluminum bracket to support most of the weight and give support.
Then I cut the mudflap from a larger piece designed for a large truck. I used a cardboard template to get the fit and angle right.
I used the height of the rim as a guide for how close to go to the ground. I mounted the rear outside cut piece with a bit of undercoating for extra protection. I also used undercoating to seal all of the drill holes.
The front was mounted directly to the front of the frame cross member. The front mud flap was basically a rectangle. I had to fabricate a bracket to hold the mudflap tight against the frame and cut out a small piece for the ridge in the frame. The bracket also has to go under this ridge.
I do drive on gravel roads quite a bit so the extra coverage keeps the mud from the undercarriage. I wish I did this years ago, a much cleaner undercarriage equals less rust. _________________ ________________________________
current 1991 Westy
previous 1978 Riviera Bay for 26 years
dweller Samba Member
Joined: May 31, 2007 Posts: 819 Location: Chapel Hill, NC
Posted: Tue Feb 03, 2009 9:52 pm Post subject: |
Good god, that is one righteous post!
bookmarked for when i'm just pissed off enough to attempt it.
dp _________________ 77 Westie 2.0L FI ... slowly restoring bit by bit... |
Riguy718 Samba Member
Joined: November 27, 2008 Posts: 370 Location: Nampa, ID
Posted: Tue Feb 03, 2009 10:54 pm Post subject: |
Those are some nice mudflaps. Does anyone manufacturer mudflaps with the VW emblem on them, or do you have to find some OG ones? _________________ First Vehicle:
Bil(bo) 1970 Westy Stock [1600DP]
Take life slowly and enjoy it, especially in a VW bus!!! |
Posted: Wed Feb 04, 2009 8:23 am Post subject: |
Riguy718 wrote: |
Those are some nice mudflaps. Does anyone manufacturer mudflaps with the VW emblem on them, or do you have to find some OG ones? |
As far as I know you have to track down the originals. _________________ 71 Standard Beetle "Big Bird"
panic_fan Samba Member
Joined: April 21, 2008 Posts: 713 Location: Mcdonough GA
g16stu Samba Member
Joined: January 12, 2009 Posts: 94 Location: NETHERLANDS
Posted: Thu Mar 12, 2009 11:39 pm Post subject: |
I have the mud flap braket mount plans made up as a pdf, you can download it from the site from the link below,
it should be to scale, so all you need to do is print it off, stick it to your sheet metal and get cutting,
enjoy
http://www.thesamba.com/vw/archives/info/bay_window_bus_mud_flap_bracket_template.php _________________ '72 westie
All comments made are in accordance with the Rules of the Yorkshire County Cricket Club. |
PopeSutek Samba Member
Joined: January 26, 2008 Posts: 331 Location: Pensacola, FL
Posted: Fri Mar 13, 2009 6:04 am Post subject: |
I just bought them online new for 10 bucks.. Cheaper, easier, and no chance for mistakes. _________________ "Today was good.
Today was fun.
Tomorrow is another one.”
old DKP driver wrote: |
Suck,Squeeze,Bang,Blow.. No Blow=No Go.  |
