Traveling Writer Samba Scribe
Joined: May 07, 2006 Posts: 1112 Location: Florence, Italy
Posted: Sun Apr 05, 2009 7:07 am Post subject: Anyone undercoating with bar and chain oil? Advice? |
I've got a good solid underbody (ha ha), and want to keep it that way. I live in Hungary, and I'm sure they put all sorts of bad things on the road in the winter, plus I camp by the beach a lot too... I've been reading a lot of stuff on bar oil by Vermont drivers. It sounds messy as hell, and you have to reapply it twice a year, but it also sounds cheap, easy, non-permanent, not as much need to scrape everything (old undercoating, etc) down to bare metal, easy to get into door crevices etc....
Anyone a believer in bar and chain oil? Any tips? Drill out doors? Inside frame? Photos? Can I do it with a pesticide garden sprayer? Prepwork needed? Can I throw it over light surface rust? As a temporary fix till I get it sandblasted next year? Whatever ya got, throw it at me! Oh, the Search came up dry...
Thanks in advance! _________________ Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well) |
Bleyseng Samba Member
Posted: Sun Apr 05, 2009 7:15 am Post subject: |
interesting idea as it should help to seal the metal against rust..My experience with bar oil is using it on chainsaws...its fairly sticky oil so it sticks to the chain to lube it. Heck, try it thinning it so you can spray it on..
No one over there that does undercoating? _________________ 70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!(sold)
76 Porsche 914 2.1L L20c, 120hp Djet (sold)
87 Syncro Westy Titan Red 2.1L 2 knob 100k miles |
Posted: Sun Apr 05, 2009 7:26 am Post subject: |
It's crazy...Hungarian is my first language, and even I can't find anyone to do anything car related! One guy will sandblast, another will prime but not paint, someone will undercoat once it has been blasted (with 3M-type stuff)... and I can't find an actual phone book! Putting together anything is like working a jigsaw puzzle, one that is rusting by the minute (such as after sandblasting!)... Ah well, that's why I'll do it myself...just need a bit of feedback from the bigger brains! _________________ Cheers,
Davi
1977 2.0 FI Westy
Posted: Sun Apr 05, 2009 8:11 am Post subject: |
Spraying the insides of the rockers and the bottoms of the doors with some oily substance if probably not a bad idea. Using a spray can that has one of those little plastic hoses to stick up into the drain holes will help get the oil where you want it. Rustoelum and others sell products just to do this, you might also consider motorcycle chain oil, or a spray grease. |
Opossum Samba Member
Joined: February 26, 2005 Posts: 757 Location: Islets of Langerhans
Posted: Sun Apr 05, 2009 8:18 am Post subject: |
I used this stuff:
http://www.roversnorth.com/waxoyl/waxoyl-corrosion-prevention.html
I read here (The Samba) that it is the same stuff VW originally used. It goes on very easy and remains flexible. _________________ "You can lead an aircooled to water, but you can't make it drink"
"Live and learn or crash and burn"
"It's only Cool, If it's Air-Cooled"
Virginia Whiteface (Opossum) the first VW
Camper Special Club Member
1973 Orange Westfalia Hard top, Original owner |
Mark Samba Member
Joined: January 20, 2003 Posts: 1523 Location: Victoria, BC Canada
Posted: Sun Apr 05, 2009 8:36 am Post subject: |
I'm looking at drilling access holes that were covered up after some bodywork welding was done and doing something similar to what you propose.
I haven't decided on which product to use, and heard a lot of positive feedback on Wax-Oyl. _________________ www.zwerks.ca |
danfromsyr Samba Member
Joined: March 01, 2004 Posts: 15369 Location: Syracuse, NY
you can make your own Waxoyl too
Quote: |
from this source: http://home.metroweb.co.za/~pdoug/tips_and_recipes.htm
WAXOYL
Take a ½ kilogram of paraffin wax or candle making wax and grind it up with a cheese grater. Soak it in 2 liters of mineral spirits/ Paraffin/ Kerosene/ lamp oil/ Diesel until all of the wax is dissolved. It might take a couple of weeks. Stirring will cause most of the wax to dissolve, but soaking should take care of the rest, heating the mixture in hot water (no open flames) will add in the quick dissolving of the wax. Generally try to dissolve as much wax as the mineral spirits/ kerosene/ paraffin/lamp oil/ Diesel will hold. Pour one liter of mineral oil/ non-detergent motor oil into the dissolved mixture. If the mixture is too thick for spraying you can thin it further with more mineral spirits until it is of a spray-able consistency.
Application:
Buy any cheap engine spray gun at your local auto or tool store that carries air tools. You can also use a garden insecticide sprayer, although it will really make you tired. Rent or borrow an air compressor. If possible elevate your car so that you can get at the underside. (Remember to chock both front and rear wheels as you are going to work underneath the car.) First wash your truck's chassis, both inside and out, to get rid of all the mud, oil etc. Spray the solution onto the underside of the chassis and into every little hole, crack and crevice. Make sure you push the tip into the chassis to spray the inside of the chassis. Let the excess drip off. You will find that the solution will blend into all cracks and chips and if the chassis is scratched it will flow, covering the scratch. If there is existing rust the solution will be soaked up by the rust and thereby creating an oxygen free coating stopping the further rusting/corroding of the surface.
Repeat the above once a year if you live in an area where the roads are sprayed with salt. Once every two to three years if staying inland where it is dry and salt free.
The above information was received from the LRO list where various people contributed their own recipe. Most of the recipes was essentially the same varying only on which oil to use and discussing the pro's and con's of Mineral spirits/paraffin/ Kerosene/ lamp oil vs. Diesel etc.
or for one with US measurements here: http://www.geocities.com/wallaces_21/waxoyl.html
Quote: |
Here is a recipe for home made "Waxoyl". It's an old fashioned rust treatment / undercoating:
2 1/2 quarts turpentine
12 oz. beeswax / candle wax
1 quart light machine oil
With a cheese shredder, cut the wax into the turpentine, stir until the wax has dissolved, (takes a long time; you can use very low heat (a warm room) to aid but be careful) and thin with the machine oil to a brushable / sprayable consistency. Apply liberally. You can use a hand spray bottle to get into closed-off sections if you have a small access hole.
Please be sensible when you make this stuff; don't go breathing the fumes or applying heat and burning down your house. If you have any doubts about it, err on the side of caution and just buy a commercially available product. |
Dan in NY _________________
Abscate wrote: |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42625 Location: at the beach
Posted: Sun Apr 05, 2009 9:46 am Post subject: |
marine supplies - CRC Heavy Duty Corrosion Inhibitor
It is Cosmoline (TM) in a spray bottle and is about what VW used new.
_________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Jalabert Samba Member
Joined: December 06, 2005 Posts: 680 Location: On the coast in NZ, somewhere...
Posted: Sun Apr 05, 2009 3:19 pm Post subject: |
I rustproofed an old citroen with a mixture of waxoyl and old engine oil - if you stand it in a bath of hot water for a while, it sprays reasonably - waxoyl on its own is too thick to spray without a compressor (and even with one, I've ended up wearing it more than once) |
Posted: Mon Apr 06, 2009 12:27 am Post subject: |
So especially if I'm just extending my time before having to do the complete sandblast restoration thing, spraying this kind of oil will act to stop the progress of the (very mild, only in a few places) surface rust already present? _________________ Cheers,
Davi
1977 2.0 FI Westy
kafer113 Samba Member
Posted: Mon Apr 06, 2009 5:45 am Post subject: |
When I rebuilt the heater channels in my beetle I sprayed hot gear oil in the tubes. It was several years later that I finally finished the full restoration of the car. For at least two years the stuff would ooze from the bottom of the tubes. I don't recommend it if your actually going to use the heater channels for heat cause it stinks for a long time like onions but my tubes are sealed shut. I also used cold galvanizing spray on the pan after I sandblasted. Then I painted it and layered hard truck bed spray and paint a few times to get a good gravel barrier on the bottom. |
Dead 1 Samba Member
Joined: October 31, 2005 Posts: 1374 Location: Burning shores of Lake Michigan
Posted: Mon Apr 06, 2009 6:41 am Post subject: |
danfromsyr wrote: |
WAXOYL
Application:
Dan in NY |
I made this solution. It smells like a bit*h sticks like crazy. I have it in a spray bottle and it sprays nicely. _________________ "I reject your reality and replace it with my own"
"The American Dream - true enough because you gotta be asleep to believe it"
71, 1776 cc. |
Posted: Mon Apr 06, 2009 7:18 am Post subject: |
I had responded with the DIY Waxoyl recipies 1st because the OP is non-USA and already has enough trouble locatiing products & resources.
but here are the products I use regularly on the vehicles I maintain..
For temporary oiling & sealing of materials I like to use either
FLUID FILM
We have used it on a freshly ground & Welded frame section with no other treatment and driven thru a Upstate NY Salty winter wash, with still shiney metal in the spring (under a layer of film)
economical & available by the gallon, it is recommended to use a Wagner power painter to apply, it's a pressure pump not a air spray pump
NAPA CABLE & CHAIN LUBE (but not Bar & chain lube)
I use this regularly to protect the brake line unions and cable fittings as well as on my Utility tractor to keep the mud, grit & snow from harming it's moveable features.
Both are kind of pricey by the spray can, but very handy and unequaled in their application to service vehicles.
Abscate wrote: |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5828 Location: Wamego, Kansas, USA
Posted: Mon Apr 06, 2009 7:34 am Post subject: |
I've never done it, but a bus friend once recommended bar oil. I believe he drilled or utilized existing holes in the body work. Put some oil in the holes. He said that it would actually leave a layer on the outside that you'd have to wipe off once or twice, but it worked well to prevent rust. |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Mon Apr 06, 2009 10:08 am Post subject: |
A quart of POR goes a heck of a long way. |
Posted: Mon Apr 06, 2009 10:17 am Post subject: |
Okay, I found this on the Type 2 library... may as well make a comprehensive thread about it for the next guy who searches!
Bar Oil Undercoating
by Don Martin
Here's my Vermont two cents worth on undercoating:
Spray on rubberized coatings tend to cover the rust and do nothing to kill it. Over time it will chip or peel and end up trapping salt and making your bus rust faster than if it had not been undercoated!
The best thing some of us up here have found is quality bar and chain oil. Do not get the cheap stuff. Agway or Husquarvarna seem to both use similar formulas. That is a mixture of phosphoric acid, oil, and paraffin. The phosphoric kills the rust. In fact the rust will turn black within a week. The oil and wax leave behind a sticky residue. This treatment also has the advantage of lubricating all joints, etc...
When looking to buy bar and chain oil, READ THE LABEL. Although it won't give you the ingredients, it should say something like: High adhesiveness, high oiliness, High Film Strength, Anti-Rust.
The best way we have found to apply the bar and chain oil is with a 3M Rocker Schutz gun and an air compressor at about 50-60 PSI. Atomizing the oil helps to make this a quick job as well as makes it possible to spray into doors, rockers, etc.
This stuff will evaporate/dry to some extent and leave a thin film behind.
I do my cars twice a year. In the fall, and also in the spring.
It's a good idea to pressure wash your ride and let it dry before undercoating. Spraying the oil on top of mud won't do much good...
I spray all sheet metal, joints etc underneath, and also spray in the rocker panels, doors, etc.
Would you rather have salt water or oil in them door seams ? Remember you'll be splashing up slush that seems to get inside all seams (this salt mix is not nice !)
Unlike the rubberized stuff that does nothing to kill rust, you get a chemical reaction from the bar oil with the metal which forms a protective oxide.
This treatment is for cars driven daily in the rust belt.
Considering the cost ($5 a gallon) this is economical. If you are judicious in applying this stuff, one gallon is all you need.
CAVEAT:
BE CAREFUL WITH ANY UNDERCOATING YOU APPLY.
DO NOT SPRAY IT ON THE EXHAUST OR ENGINE !
GIVE IT TIME TO "DRIP DRY".
YOU DON'T WANT A BURNIN' BUS. _________________ Cheers,
Davi
1977 2.0 FI Westy
Posted: Mon Apr 06, 2009 11:29 am Post subject: |
I wanted to add that used motor may not be the greatest since it has water and dissolved combustion byproducts in it. Algae begins to form slimmy messes with it being used without cleaning areas first. Also heard of folks using ATF. I've also used the wax seals (for toilets) mixed with kero and painted areas with a big brush. I've used it like putty in places I wanted a real good barrier. Got the idea from my old mazda 323. It has some cosmolean type stuff an inch thick in the rear quarters at the bottom. Our subaru wagon had the stuff 1/4inch thick under it. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23155 Location: Oklahoma City
Posted: Mon Apr 06, 2009 11:55 am Post subject: |
The corrosion inhibitor is good....its a waxy substance. Itswaterproof.
Oil is a horrible idea...and promotes rust. This is actually mentioned in teh body care section of several VW manuals. (a)Oil and grease is not 100% waterproof and (b) it collects dirt, dust and sand...which gather water. Some of teh worst rust comes from clumps of oil and grease that have gathered over the years from leaking valve covers and leaking CV boots. It gathers crud...which in itself gathers water.
Sandy oil is porous and holds water even in hot weather.
Steam clean the underside and use a simple spray of phosphoric acid mixture to "kill" rust that is in any cracks of shrinking original undercoating ( common issue). Then spray it with a waxy rust inhibitor. Ray |
Rubber Duck Samba Member
Joined: January 18, 2006 Posts: 806 Location: Pitt Meadows BC
Posted: Mon Apr 06, 2009 1:03 pm Post subject: Here's what I did.. |
Hi there TW...here's what I did to rustproof my bus. I don't even intend driving this when it rains, much less snows, but I did it anyways
As you can see, its not very hard to do, and even a mechanically inept guy like me could do it. I think the most important part of this job (at least in my case) was to get the b*lls to get under the bus whilst it was supported the way it was, and be totally not afraid to get dirty.
In that thread, you can see also how 56Oval bug posted a few shots of how his bus fared after many years of the worst Canadian winters. Now you all know why its called the Great White North right? That's the same stuff I used. If that stuff works here, it will work anywhere  _________________ ---------
Rubber Duck
1974 Westfalia |
jcrick Samba Member
Joined: July 22, 2012 Posts: 10 Location: North Carolina
Posted: Sat Jul 28, 2012 8:31 pm Post subject: Bottom Door seams covered on waxy stuff |
I recently purchased a 93 eurovan, and have started examining the vehicle body for rust (I have a rocker panel that is showing some punch through, so I suspect there is moe).
I noticed some mildew around the bottom of the drivers door inide panel. When I removed it I was shocked to see almost 3 inches of water standing in the bottom of the door. The water could only drain out the openings for the door panel retainers.
Further investigation (after draining the swamp) revealed there was about an 1/8" of waxy goo on the seam. The stuff was applied thick enough to actually plug the dain holes, hence the pool of water. Some of this stuff has actually lifted and is lose and has dirt and moisture under it..
So, can I assume one of the previous owners installed this waxy stuff outlined in this thread? Or is this actually something that the manufacturer installed?
Is there a commercially available material similar to the waxy concoction listed here?
Wouldn't it be better to clean the wax out and wse an undercoating material? Any advice on how to proceed with repairs? |
