madmike Samba Member
Joined: July 11, 2005 Posts: 5300 Location: Atlanta,Michigan
Posted: Thu May 21, 2009 4:59 am Post subject: Electrical Gremlin with ignition |
Before I get under the Dashboard of my Laser917 "again" I'll ask you guys what do you think?? I'm driving along and the thing runs great,then it just shuts off ?? the alt lite comes on and the elec. oil pressure gage drops to zero,I switch off the universal keyed switch untill the alt lite is off and it starts right back up every time. then the other day I went to start it and the starter stayed engaged even with the key out WTF??? I'm thinking the Ing. switch or the starter sylinoid "Opinions please" Thanks in advance ,Madmike _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
Marv [UK] Samba Member
Posted: Thu May 21, 2009 5:47 am Post subject: |
WTF is a laser 917?
Anyway.... sounds like a problem one of my old colleagues had with a GM motor once... Alternator was on it's way out and when the charge dropped below a certain voltage, everything shut down to prevent damage.
No idea if this is anything like what you are having to deal with but thought it might be relevant  |
ALB Samba Member
Joined: August 05, 2008 Posts: 3506 Location: beautiful suburban Wet Coast of Canada
Posted: Thu May 21, 2009 6:46 am Post subject: |
Marv- It's a swoopy, futuristic looking kit car from the 70's. _________________ On a lifelong mission to prove (much to my wife's dismay) that Immaturity is Forever!! |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71930 Location: Phoenix 602
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Thu May 21, 2009 10:03 am Post subject: |
| ALB wrote: |
| Marv- It's a swoopy, futuristic looking kit car from the 70's. |
Yep, it's a smaller-scale fiberglass kit car based on the Porsche 917.
Real:
Laser 917:
A Laser was featured in "Herbie Goes to Monte Carlo", btw:
Not that any of this helps with the ignition problem!
- Scott _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Letterman7 Samba Member
Joined: March 14, 2004 Posts: 3232 Location: Downingtown, PA
Posted: Thu May 21, 2009 11:51 am Post subject: |
| Actually, sounds like you've got two different situations going on. The car suddenly shutting off sounds like it's either dropping a ground to the coil or power to the coil. Check all your lines from the ignition to the coil, and all your ground lines. A loose ground line can ruin your whole day. Same deal with the starter staying engaged, though that's more likely a sticking Bendix in the starter itself (or sticking solenoid). |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 23022 Location: Northwest of Normal
Posted: Thu May 21, 2009 12:13 pm Post subject: |
| EverettB wrote: |
| Sounds like a bad ignition switch. |
X2. _________________ Немає виправдання для війни! Я з Україною.
| Bryan67 wrote: |
| Just my hands. And a little lube. No tools. |
Those who can- do.
Those who can't? Subaru. |
