Sawsalesman Samba Member
Joined: May 27, 2009 Posts: 796 Location: Ashland, NH
Posted: Thu Jul 09, 2009 12:03 pm Post subject: Idea on how to fix square hole in my roof |
So the PO decided to make his own vent on this bus. He cut a square hole which is 15-1/2" x 15-1/2". I know that I want to keep some ventilation in this panel bus but his homemade unit is terrible. You can make it out in this picture. Any ideas to make this bus look acceptable from the outside. I don't want to patch it with steel.
busman78 Samba Member
Joined: August 17, 2004 Posts: 4667 Location: Oklahoma City, OK
Posted: Thu Jul 09, 2009 12:09 pm Post subject: |
That is one heck of a head knocking handle hanging down.
Metal is the only was if you want to close it off, fibergrass will not only look like a repair but crack (roof flexes) due to dissimilar material.
An RV supply may have a better looking or more practicle vent system to fit your hole. |
theizzardking Samba Member
Posted: Thu Jul 09, 2009 12:12 pm Post subject: |
yeah i was thinking rv store or a skylight with proper seals as well, steel would eb the best bet for getting it to look normal, other wise look for a boat sky light and use one of those, they have a good low profile design and have all the features you need to keep it water tight if done correctly. _________________ "Democracy is two wolves and a lamb voting on what to have for lunch.
Liberty is a well-armed lamb contesting the vote." - Benjamin Franklin
'71 westie "the wanderer" |
Posted: Thu Jul 09, 2009 12:20 pm Post subject: |
| Yep, I was thinking about a flip up style like you would see on a pop up camper. A flip up skylight would be nice. I don't want to seal it off, just put something better in its place. And yes you are correct, that nob has been imbedded in my head more than once! |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42948 Location: at the beach in Northern Wokistan
Posted: Thu Jul 09, 2009 12:28 pm Post subject: |
if you don't want to patch it you will have to look for some kind of vent. A marine or rv shop would be best. You might consider aftermarket sunroofs and see if there is one that could fit if the hole was enlarged. Regardless it will be a place where water can get in so be prepared. _________________
Canned Water - the new California approved parts cleaner (except in a drought in which case rub it with sand).
George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
peaceful warrior Samba Member
Joined: January 22, 2005 Posts: 5271 Location: Taoswest, USA
Posted: Thu Jul 09, 2009 6:12 pm Post subject: |
Check this link, not the exact size, but I bet if you searched around a bit you could find one to fit the opening you already have.
http://mobilehomepartsstore.com/Merchant2/merchant...ct_Count=0 _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
"Notchboy" says "Man up!"
"Tram" says " My bus is bigger than your bus."
66 13W Deluxe, 68 Westfalia, 87 Syncro.
TOOB Member #15
Brian |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53208 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Jul 09, 2009 6:17 pm Post subject: |
The only issue with all those North American vents is they use a 14"X14" hole, unless you go for a truck camper escape hatch (even bigger and uglier) it's not going to fit. Sure it wasn't installed by whoever made it into a firetruck?
If I wanted to cover a hole and didn't want to weld I'd glue a piece of plexiglas over it with urethane. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
cdub1971 Samba Member
Joined: October 30, 2008 Posts: 24 Location: Dallas, TX
Posted: Thu Jul 09, 2009 10:08 pm Post subject: |
I have the same problem with my roof, I am planning on using the skin from a beetle door to patch it. It will be a couple of months before I am able to try it. _________________ '71 Super Beetle
'72 Deluxe |
werksberg Samba Member
Joined: February 08, 2005 Posts: 2164 Location: Green Valley, AZ
Posted: Thu Jul 09, 2009 10:55 pm Post subject: |
| busdaddy wrote: |
| If I wanted to cover a hole and didn't want to weld I'd glue a piece of plexiglas over it with urethane. |
Very good idea but use Polycarbonate sheeting as it is unbreakable clear plastic! Rivet in with PUR or silicone sealant too. _________________ Werksberg Products....Products that work!
Follow my Facebook page "Werks Berg"
Click the below ADs link for products & feedback.
Please remember to buy "American made products!" Like my own products |
Posted: Fri Jul 10, 2009 4:15 am Post subject: |
Busdaddy,
No this hole had to be put in by the previous owner. No fire department would do this crappy of a job. Well after getting home from work last night I looked at the vent on my pop up camper and noticed that the flange on the outside of the camper was 17-1/2" square. The opening on the vents are 14 x 14 but this should cover the hole pretty well. I got on line and found a vent with a steel cover, not plastic, so it can be painted the same color as the bus when I paint it. It appears that this should work pretty well. I will seal it very well and worry about the inside head liner area when I get to the interior. |
Posted: Fri Jul 10, 2009 7:10 am Post subject: |
I agree the one I put the link to is not the nicest looking, but glad you did a search. I found a few marine sites, but none of them had small vents. I think if you went that route, it would be special order and costly.
Glad you found something you like and will work. As stated, seal it well and screw it in to the roof, with stainless steel screws. _________________ "Two things are infinite: The universe and human stupidity; and I'm not sure about the universe." Albert Einstein
TOOB Member #15
Brian |
Posted: Fri Jul 10, 2009 7:14 am Post subject: |
| Yep, I was surprised to find the one with the steel top instead of the plastic ones. At least I can try to hide it by painting it the same color as the roof. It only cost about $27.00 with shipping. |
