Alaric.H Samba Member
Joined: March 28, 2009 Posts: 2529 Location: Sandy Springs GA
Posted: Tue Aug 04, 2009 6:42 pm Post subject: Making a little more room |
| I got tired of the drain hose under the sink aways getting in the way so I rerouted it so now I can put 2 shelves in. |
markz2004 Samba Member
Joined: November 13, 2007 Posts: 947 Location: Portland, OR
Posted: Tue Aug 04, 2009 7:53 pm Post subject: |
interesting 90-degree angle from the sink. Where did you get it? _________________ 87 Westy, 250k GW 2.4 - 2.0 , 16" wheels |
madspaniard Samba Member
Posted: Tue Aug 04, 2009 10:08 pm Post subject: |
very nice Alaric, we need details, yeah, what is that 90 degree angle? _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10884 Location: Western WA
Posted: Tue Aug 04, 2009 11:25 pm Post subject: |
| madspaniard wrote: |
| very nice Alaric, we need details, yeah, what is that 90 degree angle? |
Yes this is a great idea please more details! _________________
....KTMs, GasGas, SPOT mtb |
Posted: Wed Aug 05, 2009 4:27 am Post subject: |
I am not so great at details after I do it I lose interest and go on to the next thing I was just cleaning the cabinet out and thought that hose it a pain and started driving to the plumbing store found a sink drain kit 2inch cut out but in the end you can use the stock 90 the new one is just a little shorter the plan was to find a really low profile drain to be able to use the rest of the drawer http://www.pyacht.com/scandvik-drains.htm
but even this is not low enough so I glued a 3/4 barb reducer to the 90 in the kit drilled a hole near the bottom and put a 90 at the hole to lower the line with a thru hull thingy I made and I cut a channel on the bottom of the floor to go lower but you can not see it. Wow my write ups suck sorry. |
jackbombay Samba Member
Joined: October 19, 2007 Posts: 2725 Location: Portland Oregon
Posted: Wed Aug 05, 2009 11:19 am Post subject: |
Phase 2
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 944 Location: Calgary, Canada
Posted: Wed Aug 05, 2009 6:02 pm Post subject: |
wow Alaric - hope you have stronger than average hatch struts.
but a neat out of the way hidey-hole. _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
Posted: Fri Sep 04, 2009 8:53 am Post subject: |
I found this quick release pop rivets to hold the hatch cover on and I have had no problems it takes about 45 seconds to accesses it.
The westy has the panel without the holes so you will need to find one from a 7 passenger.
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Fri Sep 04, 2009 9:41 am Post subject: |
clever. _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
stormforge Samba Member
Joined: May 05, 2009 Posts: 355 Location: Adirondacks NY
Posted: Fri Sep 04, 2009 11:03 am Post subject: |
Can you give us a source for those quick-release rivets? Do they fit nicely into the existing holes?
Cheers,
-Bill
'89 Syncro |
Posted: Fri Sep 04, 2009 12:17 pm Post subject: |
| stormforge wrote: |
Cheers,
-Bill
'89 Syncro |
facia retainers black
GM products A body 1983 on
794-0704 L.S.P products
I just nipped the tangs on a sander a little to be able to take them off faster. they fit perfect. |
Posted: Fri Sep 04, 2009 12:19 pm Post subject: |
Thanks Alaric! I need to totally replace that back panel and that will be perfect!
Cheers,
-Bill
'89 Syncro |
faretheewell Samba Member
Posted: Mon Oct 05, 2009 6:42 am Post subject: |
does the upper part of the sink drain unscrew from the metal sink? I tried briefly and its stuck on pretty good. I wanted to ask the forum before herkin' on it and breaking something...(like i usually do.) thanks _________________ '84 2.3L Wolfsburg Westy - "Brown Sugar"
'72 1700 cc Baywindow 'Tatonka' |
Dogpilot Samba Member
Posted: Mon Oct 05, 2009 6:45 am Post subject: |
You can stick something like a pair of needle nose pliers into the X in the drain. This allows you to twist the top and the bottom. It can be stiff. _________________ Geology with a Syncro rocks!
98 Disco I
08 Range Rover SC
08 VW Rabbit S
1951 O-1G |
Posted: Tue Dec 22, 2009 5:43 pm Post subject: Re: Making a little more room |
| Alaric.H wrote: |
Alaric,
yesterday I bought some tubing to this same thing, thanks for the idea _________________ 1991 Westy auto w/ Peloquin TBD
Posted: Tue Dec 22, 2009 8:48 pm Post subject: |
Here is another way to save one spice bottle with 6 spices.
