gordonzo Samba Member
Posted: Sun Aug 23, 2009 2:23 pm Post subject: Shifter stop plate adjustment |
A search of this forum and my Haynes manual did not answer my question. My Bentley manual is on order.
I am having trouble shifting - it is a bit difficult to find 2nd and too easy to hit reverse! I removed my shifter and discovered the stop plate was in backwards (front to back). This info I found in the forum search.
Now my question - I believe the notch in the stop plate is for the reverse lockout. Is it supposed to have an upward bend as shown below?
Note the brownish tinge is grease and not rust.
Also, is the flat area on the shifter supposed to be there?
Thanks for any and all help I have already received and hopefully more help coming my way. _________________ 1958 Sunroof Sedan (For Sale) - SOLD
1972 Deluxe Sunroof - For Sale1975 Campmobile with 2.0 litre (summer driver)
busdaddy wrote: |
Tried soaking it in some search?
"We are taking it to the shop soon" - Those words always end badly, why not tackle it yourself? |
germansupplyscott Samba Member
Posted: Sun Aug 23, 2009 2:55 pm Post subject: |
everything in the photos looks normal. _________________ SL |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10799 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sun Aug 23, 2009 2:59 pm Post subject: |
germansupplyscott wrote: |
everything in the photos looks normal. |
except the dislocated pin in the shifter ball. |
Posted: Sun Aug 23, 2009 3:10 pm Post subject: |
hazetguy wrote: |
isn't that just poking out the other way from the spring tension? the pin is often stuck fully into the ball but by design is is free to move back and forth. it is the shift rod that holds it pushed into the ball, but it often gets seized all the way in. does that make sense? _________________ SL |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42543 Location: at the beach
Posted: Sun Aug 23, 2009 3:15 pm Post subject: |
Not to hijack your thread - now I am lost. The pin on my shift ball comes out one side only and there is but one slot in the head of the socket.
I was kinda under the impression that when the shifter was pushed down, the ledge on the shifter could slide under the curved ramp. Mine was all broken up so I've followed other posts here trying to install it correctly. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin
Posted: Sun Aug 23, 2009 3:17 pm Post subject: |
There is a spring on the pin that pushes it out a bit. Is this not normal, ie intended to minimize slop in the ball? The bus is a 1975.
I also have an Empi shifter that came extra with the bus. It has just a ball and no pin. How does that work? I am not installing it - just curious. I understand many here think the Empi shifter is junk. _________________ 1958 Sunroof Sedan (For Sale) - SOLD
busdaddy wrote: |
SGKent  Samba Member
Posted: Sun Aug 23, 2009 3:21 pm Post subject: |
ours is a 1977 and the pin is embedded in the bottom ball on the shifter. It has no spring and is not moveable. Does anyone know what year that area changed? _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sun Aug 23, 2009 3:29 pm Post subject: |
they all have springs. they are on the pin inside the shifter ball. the pin is supposed to be peened in the ball. you can see the peening pattern in the 3rd pic. the pin is not supposed to move out of the ball as seen in the pics.
Posted: Sun Aug 23, 2009 4:24 pm Post subject: |
Should I something with the pin before reinstalling it or will the socket keep it together? _________________ 1958 Sunroof Sedan (For Sale) - SOLD
busdaddy wrote: |
SGKent  Samba Member
Posted: Sun Aug 23, 2009 4:55 pm Post subject: |
what is the purpose of the pin being able to float? I thought it was fixed so it would hold the shifter from rotating, and that it just rode up and down in the vertical slot. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin |
Posted: Sun Aug 23, 2009 5:51 pm Post subject: |
hazetguy wrote: |
the pin is supposed to be peened in the ball. you can see the peening pattern in the 3rd pic. the pin is not supposed to move out of the ball as seen in the pics. |
not sure what picture you are referring to, maybe the link didn't make it into the posting. i have worked on many shifters and the pin is usually either free to move and can come completely out of the shift rod, or it is seized, doesn't move at all in the rod and once freed up it will fall out. never seen a bay bus shift rod that had the locating pin peened, or at least never noticed that feature. now i will have to dig into parts bins and see this for myself.
as for the pin floating, it doesn't move very much, once the shifter is in the socket of the front shift rod the spring just keeps some tension on the joint. if the pin is seized there is not as much tension in the joint between shift lever and rod, so there will be a bit more slop in the shifter. _________________ SL |
Klaussinator Samba Member
Posted: Sun Aug 23, 2009 5:58 pm Post subject: |
Sorry to jump off-topic, but . . .
Gordonzo - That is one COOL paint job on your avatar! Got any more or bigger pics of that bus?!?
-Klauss _________________ I have taken a vow of poverty. To annoy me, send money!
____________________________________________
the Klaussinator - `73 hardtop Bay custom-built camper |
hazetguy wrote: |
not sure what picture you are referring to, maybe the link didn't make it into the posting. |
the serrated looking edge is the peening. it's visible in the 3rd pic.
gordonzo wrote: |
1st pic
2nd pic
3rd pic
4th pic
Posted: Sun Aug 23, 2009 6:04 pm Post subject: |
hazetguy wrote: |
the serrated looking edge is the peening. it's visible in the 3rd pic. |
OK, i see it now. _________________ SL |
Posted: Sun Aug 23, 2009 6:26 pm Post subject: |
Am I missing something (I probably am). If the head is peened to keep it from moving, what is the purpose of the spring? Why not just a fixed pin?
And how does the Empi shifter function without a pin at all. I know many consider them junk but they must work, not? _________________ 1958 Sunroof Sedan (For Sale) - SOLD
busdaddy wrote: |
Posted: Sun Aug 23, 2009 6:59 pm Post subject: |
gordonzo wrote: |
Am I missing something (I probably am). If the head is peened to keep it from moving, what is the purpose of the spring? Why not just a fixed pin? |
it can move. it's like the ball on the end of the ratchet handle. _________________ SL |
Posted: Sun Aug 23, 2009 7:01 pm Post subject: |
Ah! The lights just came on. Will it work ok without the peening? I am likely to mess up a perfectly good shifter. _________________ 1958 Sunroof Sedan (For Sale) - SOLD
busdaddy wrote: |
Posted: Sun Aug 23, 2009 7:57 pm Post subject: |
Just looked at a Berg shifter. Looks good and rave reviews. How do they get away without having a pin on the shifter ball? Is the ball larger so it fits more snuggly? _________________ 1958 Sunroof Sedan (For Sale) - SOLD
busdaddy wrote: |
Posted: Mon Aug 24, 2009 7:45 am Post subject: |
gordonzo wrote: |
Just looked at a Berg shifter. Looks good and rave reviews. How do they get away without having a pin on the shifter ball? Is the ball larger so it fits more snuggly? |
the stock shifter has a pin for at least two reasons that i can come up with.
the first, and most obvious, is to locate the shifter in the ball socket of the shift rod. this is necessary because the shifter has a designated angle of operation, and if there was no pin, the shifter could and would rotate any which way it wanted to.
the second, and this is speculation based on many miles of road weary philosophizing, is that the ball end of the pin, which is sprung, helps keep slight pressure on the ball of the shifter in the socket to help keep rattling noise down, and to help make the shifting tighter (as minimal as that effect probably is).
the berg, and other aftermarket shifters, do not use a locating pin because the orientation of the shifter is held in position by the shifter box (mechanism) itself. |
Patrick199 Samba Member
Joined: June 29, 2006 Posts: 550 Location: Menlo Park, California, USA
Posted: Mon Aug 24, 2009 8:03 am Post subject: |
Yea, man. Let's see some pictures of that bus!!! |
