Ragtop Rebuild
Stanw3
Stanw3 is offline
PostPosted: Wed Apr 01, 2009 9:29 am    Post subject: Ragtop Rebuild Reply with quote
I'm rebuilding the ragtop assembly for my 65.
For refernce: I also had to replace my "sex screws". I couldn't bring myself to pay the $5.00 each that the replacements cost so I went to ACE hardware and put my own together for about $1.50 each.
I used loctite on one end so it adjusts like the original.
I flipped them so the beveled end is on bottom - no heads pushing out on the headliner:
OG
Flipped
Before:
After:
View user's profile Send private message MSN Messenger Facebook Gallery Classifieds Feedback
Ian
Ian is offline
PostPosted: Thu Apr 02, 2009 11:36 am    Post subject: Reply with quote
I have no clue but what you've done so far looks real nice.
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 & KEN CRIMMINS 1957-2024
2Pack
2Pack is offline
PostPosted: Thu Apr 02, 2009 11:38 am    Post subject: Reply with quote
This vendor offers them also. I don't know anything about them.
http://www.thesamba.com/vw/classifieds/detail.php?id=697106
Okie Adam
Okie Adam is offline
PostPosted: Thu Apr 02, 2009 11:40 am    Post subject: Reply with quote
I know your frustration. I redid my roof a few years back and ended up reusing my original foam instead of the door seal foam WW sends. Didn't like having to do it but it worked.
Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia
Stanw3
Stanw3 is offline
PostPosted: Fri Apr 03, 2009 7:54 pm    Post subject: Reply with quote
I see that VW Sunroofs sells the foam blocks for $11 each plus shipping. Uh, yah - mine aren't bad enough to warrant that. I added a layer of camper-top foam seal to get things back to a decent height. All good.
I also had to replace the tack strip on the header bow. Rust just plain sucks. :
Sanborn7
www.facebook.com/Sanborn7
Stanw3
Stanw3 is offline
PostPosted: Sun Apr 05, 2009 8:12 pm    Post subject: Reply with quote
All done. Three trailing bows and one header bow - ready for install.
Out of the 6 blocks on the trailing bows only one was missing. The other five were all in nice shape. I rouned the corners of the replacement block to mimic the originals.
The internal mechanism works much better without the extra rust. Smile
I found these in my bag of spare parts but I have no idea what they are. Anyone recognize them??
Sanborn7
Ian
Ian is offline
PostPosted: Sun Apr 05, 2009 8:25 pm    Post subject: Reply with quote
I believe the three on the left are for mounting the rear splash pans, they are reinforcement inside the corner. I think.
PostPosted: Sun Apr 05, 2009 10:53 pm    Post subject: Reply with quote
Correct.
Kelly
Kelly is offline
PostPosted: Mon Apr 06, 2009 5:27 am    Post subject: Reply with quote
great job with the sunroof bows!
The only thing I did different was I added black heat shrink on the ends of the bows to finish it off.
It's not how wide your hatch is, it's what you do with it.
Eriba Puck Sticky
Stanw3
Stanw3 is offline
PostPosted: Mon Apr 06, 2009 6:19 am    Post subject: Reply with quote
Thanks Ian and Jack. I need to find something for the ends before it allgoes together.
Ev - any idea on the pieces on the right? The screw hole is beveled.
Sanborn7
PostPosted: Mon Apr 06, 2009 10:38 am    Post subject: Reply with quote
The pieces on the right I am not sure of but they do look similar to the lower plates for the sunroof cross-beams? I don' t have a sunroof assembly to examine.
Stanw3
Stanw3 is offline
PostPosted: Sat Sep 05, 2009 2:50 pm    Post subject: Reply with quote
Mostly done - pics for posterity. Smile
First - color sand the roof with 800, 1000, 1200
Buff it till it's chiney!
Lay out the bones - get everything even
Put in the webbing to help everything close up nice:
Look at that front lip!!! I can hardly believe it came out so straight!
MAJOR props to the Master himself, Senor Jorge Coblentz for letting me watch him do his and answering all my phone calls when I did mine! I could never have done it without his help!
Sanborn7
royDHPNM
royDHPNM is offline
PostPosted: Sat Sep 05, 2009 4:24 pm    Post subject: Reply with quote
it is one sweet bus man. great work all around Cool
if I can ever afford it you will be my first choice for a painter
DHP, bringing the Dry Heat
WHAT?!
http://www.dhpvw.com/
El Roy Pinstriping on Facebook
Vermeulen
Vermeulen is offline
PostPosted: Sat Sep 05, 2009 11:51 pm    Post subject: Reply with quote
great work on the sunroof assembly , need to do mine to so this can help
http://11windowgoldesunroof.skynetblogs.be/
http://11windowrag.webs.com/index.htm
SBS UK #71
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger Facebook Gallery Classifieds Feedback
Kelly
Kelly is offline
PostPosted: Sun Sep 06, 2009 5:04 am    Post subject: Reply with quote
nice job!
Lays flat and the front looks perfect.
I noticed when your rag is back it lays flat on itself, and I've seen this on several other buses. Mine seems to puff up. I wonder, is there a particular order in which the bows go to prevent this?
Eriba Puck Sticky
Stanw3
Stanw3 is offline
PostPosted: Sun Sep 06, 2009 7:47 am    Post subject: Reply with quote
Nah, the three rear bows are all identical. I'd guess it has more to do with the spacing of the bows and the bend/angle of the rear of the bows (how it pushes the material as it goes back).
Sanborn7
npbusguy
npbusguy is offline
PostPosted: Sun Sep 06, 2009 8:36 am    Post subject: Reply with quote
Nice job, I like informative threads like this.
Vermeulen
PostPosted: Sun Sep 06, 2009 10:49 am    Post subject: Reply with quote
could you tell me what this is ? ; closed my sunroof 15min ago and this fell out ? , its the second time this happens
SBS UK #71
Stanw3
Stanw3 is offline
PostPosted: Sun Sep 06, 2009 1:10 pm    Post subject: Reply with quote
I don't recognize that. Looks like some padding - not sure about the square in the center. Neither were in my sunroof.
Sanborn7
Vermeulen
PostPosted: Sun Sep 06, 2009 1:12 pm    Post subject: Reply with quote
the square thing is metal and looks like there is a broken screw in it .
it's a 66 sunroof standard bus , will do some inspection on the bus itself next week .
Hope i can find what it is
SBS UK #71
