Aussie style alternator for a type 3
Page: 1, 2, 3, 4, 5  Next
mackaymanx
mackaymanx is offline
PostPosted: Thu Sep 17, 2009 6:31 pm    Post subject: Aussie style alternator for a type 3 Reply with quote
Here is something I have been working on. This is my type 3 alternator conversion.
http://forums.aussieveedubbers.com/viewtopic.php?tid=78941
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Thu Sep 17, 2009 6:45 pm    Post subject: Reply with quote
cool -- what is the alternator from?
póg mo thóin
Certified DHS Technician
Samba Member # 24517
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Thu Sep 17, 2009 9:06 pm    Post subject: Reply with quote
yeah that's pretty sweet, but it LOOKS to me like some kind of alternator mated to a stock generator housing with a longer shaft... Confused cool either way! more details!
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
Air_Cooled_Nut
Air_Cooled_Nut is offline
PostPosted: Thu Sep 17, 2009 9:45 pm    Post subject: Reply with quote
Diahatsu 3 Cyl Diesel. Link is at the top of OP's thread.
Looks nice...tell 68AutoBug he needs to go to my site and look at the instructions I made...and the date Wink
Toby http://www.aircoolednut.com/
Did I mention that I'm an original Darksider?
'72 VW Squareback, 2007cc, GB 5-speed, rag top; '76 VW Riviera Penthouse Sundowner 2.0L; 2015 Audi S5 Cabby w/Stage II APR; '06 Ducati Sport Classic 1000; '14 Ducati Diavel Strada
The First Invasion
JSMskater
PostPosted: Fri Sep 18, 2009 12:08 am    Post subject: Reply with quote
and then he later says something about a type 1 alternator... doesn't look like any type 1 alt I've ever seen Confused
I can't wait to finish my conversion... I'm pretty happy with it so far...
TOOB Member #3
rovingmind
rovingmind is offline
PostPosted: Fri Sep 18, 2009 8:09 am    Post subject: Reply with quote
actually he sat it beside "type 1 generator converted to alternator" as a reference
JSMskater
PostPosted: Fri Sep 18, 2009 8:48 am    Post subject: Reply with quote
exactly. that doesnt look like any type 1 anything I've ever seen.
TOOB Member #3
dirtsandwich
dirtsandwich is offline
PostPosted: Fri Sep 18, 2009 11:42 pm    Post subject: Re: Aussie style alternator for a type 3 Reply with quote
Wow, as far as the DIY alternator conversions that looks as close to a bolt on solution as I've seen. Nice find indeed. Same diameter? 55 amp? Part number?
71 Squareback
77 Bus
mackaymanx
PostPosted: Sat Oct 03, 2009 12:16 am    Post subject: Reply with quote
More to come
mackaymanx
PostPosted: Sat Oct 03, 2009 12:39 am    Post subject: Reply with quote
Ok here is my step by step of how to do it.
Start with a type 1 (or type 3) generator.
Strip it down. You will need the bearing housing from the fan end, this is the fixed end (the brush end is the floating end of the shaft). Also the pulley end of the amature shaft.
Cut the armature end off the shaft and remove the commutator, I have shown the two different types of shafts I found in the type 1 generators.
This is what you keep plus the two 6mm screws that hold the the generator together.
mackaymanx
PostPosted: Sat Oct 03, 2009 2:52 am    Post subject: Reply with quote
You need to build up this area of the housing, enough to leave you with 106 to 107 mm once machined back. The type 3 housing will need more as they are undercut more in this area.
As the type 1 generators are undercut at each end you need to trim the pulley end back so the mounting suface aligns properly with the type 3 fan housing. Copy the type 3 housing profile onto the pulley end of the housing and rough out the other end.
Pulley end
Alt end
Next we need some tabs on the side so it will bolt together. The first two I did I just built this up with weld but this way is far quicker.
Now we need to duplicate the front housing of the donor alternator into the VW housing. This is a type 3 housing. Use the 6mm screws to hold the front bearing housing on. Bend and weld them into the field coil holes in the housing.
Drill out the cooling hole in the housing(Yes a hole saw would be a lot easier).
Russ Wolfe
Russ Wolfe is offline
PostPosted: Sat Oct 03, 2009 6:51 am    Post subject: Reply with quote
When you install this conversion on a T-3, do you have to modify the cooling tin going to the 3/4 cylinders?
Gary: OK. Ima poop.
mackaymanx
PostPosted: Sat Oct 03, 2009 7:03 am    Post subject: Reply with quote
No mod to cooling tin. This is a straight bolt in, only mod is wiring.
mackaymanx
PostPosted: Sat Oct 03, 2009 8:19 pm    Post subject: Reply with quote
Here is the field coil installed and the screws(original and modified). The diameter of the coil is 100mm, this gives you a housing wall thickness of about 2.5 mm with the VW housing being around 105 mm. There is a very similar NipponDenso alternator which has a 103 mm coil but I thought that a 1mm wall thickness was insufficient.
notchboy
notchboy is offline
PostPosted: Sat Oct 03, 2009 8:22 pm    Post subject: Reply with quote
Um, thats some realy cool shit right there Shocked
t3kg wrote:
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
1977 Westfalia Camper pop-top
mackaymanx
PostPosted: Sat Oct 03, 2009 9:24 pm    Post subject: Reply with quote
Here are the two different types of shafts stubs with the spacer sleeves installed. I won't give exact measurements here as is will just get too complicated. Accuracy and attention to detail is a must with this step. Clean up you stubs carefully and keep any runout to a minimum. A good check is to measure the shaft protrusion at the rear housing before you strip down your donor alternator and compare this as you calculate your sleeve lenght(make sure the pulley is on and tight when you measure this). I found around 23mm for these alternators.
Shaft together with end cover installed. Note tin plate to seal the type 1 end cover. Second roll pin not installed yet as I was still checking shaft lenght.
mackaymanx
PostPosted: Sat Oct 03, 2009 9:53 pm    Post subject: Reply with quote
Once you are happy with everything and have it together it's time for a quick bench test. I ran this at 2200 rpm and got 20 amps at 14.2 volts. I'm sure they will put out more but that is all I ran it up to.
1500king
1500king is offline
PostPosted: Sun Oct 04, 2009 6:37 am    Post subject: Reply with quote
save yourself the trouble and pull one from an SP2.
notchboy
notchboy is offline
PostPosted: Sun Oct 04, 2009 6:40 am    Post subject: Reply with quote
If you can find me the compleet set up from an SP2 Ill take it mate. Trade you some nice trinkets too if you want.
1964 1500 S
Russ Wolfe
PostPosted: Sun Oct 04, 2009 7:56 am    Post subject: Reply with quote
SP2 alternator was only 30 amps. Might as well stay with the generator.
Mack's conversion is 60 amps, if I read the tag right.
Gary: OK. Ima poop.
Page 1 of 5
