How do i check the transmission oil level / condition
TroySmith80
TroySmith80 is offline
PostPosted: Wed Sep 16, 2009 7:23 am    Post subject: How do i check the transmission oil level / condition Reply with quote
I just got an '84 westy 4-speed and there is a lot of oil on the bottom of the engine/transmission. I just cleaned it all up lastnight and will be monitoring to see if i can determine where it's coming from. Since it was mostly on the transmission, and not on the engine, i suspect it's coming from the trans.
So i'm nervous that there may be a low quantity of oil in the transmission, i haven't been able to find any directions on how to check that.
How do i check the transmission oil level?
markmc90
markmc90 is offline
PostPosted: Wed Sep 16, 2009 7:29 am    Post subject: Reply with quote
I have an 87 syncro, but I think your's is the same. On the passenger side of the tranny, near the linkage there is a 17mm drain plug. Many people have tried different types of wrenches, like an allen wrench cut down, or a 11mm bolt, has a 17mm head. It's a bitch the first time but you'll figure out the angle and wrench combo and it wont be so bad next time.
87 Syncro
TroySmith80
PostPosted: Wed Sep 16, 2009 7:33 am    Post subject: Reply with quote
So there's no ability to just check it? I have to drain and refill? I guess that would explain why that is the only information i could find in the bentley manual.
markmc90
markmc90 is offline
PostPosted: Wed Sep 16, 2009 7:34 am    Post subject: Reply with quote
No the drain plug is on the bottom. The check plug is about halfway up the side where I described. When you unscrew it the fluid should be at the level of the plug or just under it. Stick your finger in there to see.
87 Syncro
zerotofifty
zerotofifty is offline
PostPosted: Wed Sep 16, 2009 7:38 am    Post subject: level Reply with quote
with van on level surface, remove the filler plug on side of tranny. the oil shold be up tot eh bottomlip of the filler plug. top off as needed wit the correct fluid.
if it is substantially low, or if your are unsure when teh fluid was last changed, go ahead and drain it (drain hot) and replace.
note never ever remove the drain plug first!! always remove teh filler plug first, just in case it is stuck, better to have a stuck filler plug with oil still in t he tranny than to find it is stuck after your drained all teh oil out!
mightyart
mightyart is offline
PostPosted: Wed Sep 16, 2009 7:40 am    Post subject: Reply with quote
Undo the fill plug and stick your little finger in, if it has oil on it when you pull it out, the level should be fine.
It would be a good idea to drain it and fill it, if you don't know when it was changed last.
Look for metal chunks in the old oil, that will give you some idea of trans. condition.
Make sure you can get the fill plug out before draining it.
TroySmith80
Ah, ok, now i'm with ya. Thanks for the info.
Good tip on removing the filler plug first. That's the kind of thing i tend to learn the hard way.
riceye
riceye is offline
PostPosted: Wed Sep 16, 2009 8:02 am    Post subject: Re: level Reply with quote
VW changed the fill level recommendation to about a half inch low to promote smoother shifting. I'm not convinced that it makes a difference, but if yours is a half inch low, don't go out and buy gearlube to top it up. It'll be fine.
Hopefully the leak is minor, or something relatively simple for you. Some folks have had issue with transmission flange oil seals. Captainpartytime did a nice tutorial a while ago.
Good luck!
'87 Westy Weekender - daily driver on salt-free roads
There's gonna be some changes made.
“I find that things usually go well right up until the moment they don't.” - Ahwahnee
"Quality isn't method. It's the goal toward which the method is aimed." - Socrates, later quoted by R.M. Pirsig
GeeZ12
GeeZ12 is offline
PostPosted: Wed Sep 16, 2009 8:24 am    Post subject: Reply with quote
Remember to use your nose - Transmission oil has a very definite odor. If the oil on the ground doesn't smell like transmission oil then it will most likely be engine oil. Very Happy
Bruce Wayne
Bruce Wayne is offline
PostPosted: Wed Sep 16, 2009 9:05 am    Post subject: Reply with quote
I have been thinking about replacing my tranny fluid,what should I use? how much does the tranny take to "fill" it?
sjhannan
sjhannan is offline
PostPosted: Wed Sep 16, 2009 10:01 am    Post subject: Reply with quote
The debate on gear oil is below. Redline or Swepco.
http://www.thesamba.com/vw/forum/viewtopic.php?t=366486&highlight=gear+oil
TroySmith80
PostPosted: Thu Sep 17, 2009 1:41 pm    Post subject: Re: level Reply with quote
Good luck!
Well, it looks to me like that is my problem. I cleaned everything up underneath, wiped off all the grease and dust and grime and drove it to work and back then parked. Came back a day later and checked and there is a PUDDLE underneath and it appears to be coming from where the driveshafts exit the transaxle on each side. It's definitely not coming from the engine. Strangely though, it doesn't seem to have much of a scent at all.
Anyway, i better order some seals...
riceye
riceye is offline
PostPosted: Thu Sep 17, 2009 8:33 pm    Post subject: Re: level Reply with quote
The nasty aroma of some gearlubes can be associated with the sulfer bearing components. If your gearlube doesn't stink, it's probably a GL-4 or synthetic - free of the stuff that can degrade brass particulars, such as synchros, in your transmission.
That's a good thing.
Bruce Wayne
PostPosted: Thu Sep 17, 2009 8:43 pm    Post subject: Re: level Reply with quote
must be why all the flies show up whenever I have the grease out.
TroySmith80
PostPosted: Thu Sep 17, 2009 10:04 pm    Post subject: Re: level Reply with quote
Wow, that makes perfect sense because i stopped in at German Transaxle here in Bend today (really nice, helpful and impressive people there!) and they told me to use GL-4 and NOT GL-5 because the 5 has sulfur and it would make the synchros grind. I stopped in to pick up some seals and caps (which they had in stock) and to talk about rebuilding my tranny with 1.18-3rd and .77-4th gears. They took a lot of time showing me all around the shop and explaining all the things they use in rebuilding a transmission. Very surprising since most techs seem very irritated to be taken away from their work (and understandably so in many cases).
They told me to use a 90 weight non-synthetic GL-4 oil. For some reason i forgot to buy it from them, so i stopped at a couple FLAPS on the way home and neither had that. I guess i'll go back to German Transaxle in the morning.
?Waldo?
?Waldo? is offline
PostPosted: Thu Sep 17, 2009 10:09 pm    Post subject: Reply with quote
Before you go pulling the drive flange seals you might want to give this a gander:
http://www.thesamba.com/vw/forum/viewtopic.php?t=344159
It might just cure your tranny fluid leaks FOR FREE (or close to it).
Andrew
TroySmith80
PostPosted: Thu Sep 17, 2009 10:19 pm    Post subject: Reply with quote
Andrew
Well I'm planning on doing the work myself, and the parts were all of $8 or so, but i'd rather not do the work if it isn't necessary! Good tip, i'll check it out!
I just bought the van in portland (~100' elevation) and brought it home to Bend (~3,500' elevation). I wonder if the air inside is trying to get out now.
TroySmith80
PostPosted: Thu Sep 17, 2009 10:34 pm    Post subject: Reply with quote
Ok, well i just went out and crawled under the van with a bit of coat-hanger wire and a flashlight and mirror and probed that hole out. It would be really nice if that were all that was necessary but i'm skeptical. It was a bit grubby and grimy up there but I don't think it was packed so tight that it would be easier for oil to force past the seals than for air to seep out that hole.
I cleaned up the housing though and we'll see if it stays dry now.
thewump
thewump is offline
PostPosted: Sun Sep 20, 2009 5:51 pm    Post subject: Reply with quote
What a bee with in itch.
Just completed this job, and did not have fun. The van I bought 3 weeks ago has a speed (not RPM) related whine that was getting more evident and is now MUCH more under control. Sounds like pinion bearings from what I've read.
For the record, repeating what is said and argued elsewhere:
1) Used GL4 lube - NOT GL4/GL5. The only place I could get it locally was Napa for $23 / gallon.
2) If you google it you'll find suggestions on how to fashion a tool using a bolt and a couple of nuts. I tried it but couldn't get the torque I needed without stripping threads (of the tool - not the van). If you search Samba you'll also find horror stories of people rounding / ruining the hex plugs and the pain in the butt that leads to so I'd STRONGLY recommend getting the right tool for the job. One option is the 3 piece Hex Bit Set from Autozone. It's got a 17mm hex bit for a half inch socket, but space is so limited (especially the drain plug) just drive the hex bit out of the socket and use it with a 17mm wrench. Either that or cut about a 4 cm section from a 17mm hex wrench.
Found evidence of leaking there so thanks whoever posted that info about the breather hole. Will check that when I get my spirits up again!
Well anyway. Between having to go out and find the tool and drive all over the place to find the oil that one hour job just took 5. Thankful though that I have a SOCAL van in Denver - and no longer live in Ireland where ANY job was like that due to rust Wink
K
87 Weekender
TroySmith80
PostPosted: Sun Sep 20, 2009 9:29 pm    Post subject: Reply with quote
Oh yeah, forgot to post back.
I replaced the seals on saturday. I'm just slow, took me a few hours. Also repacked one of the CV joints because it was lookin bad. The other looked ok. Probably should have just done them all but i didn't have time.
Anyway, first thing i noticed when i was getting ready to do the job is that a lot of oil has been leaking around where the shifter goes into the housing. Didn't have a seal for that so i'll keep an eye on it and if it continues to look bad i'll replace it later.
Have put probably 70 or 80 miles on since new seals and so far, so dry.
On an unrelated note: Also bent the window frame on drivers door so it is closer to the body. Sounds like a terrifying and stupid idea but my grandpa worked most of his life in a body shop and after checking the seal around the door with slips of paper he said that's what it needed.
What an improvement! So much quieter now! Fixed my slider door too. It was VERY hard to turn the latch to open the door. Took everything apart and cleaned the 20 year old gooked up grease out. Now it works pretty nice.
