mpate Samba Member
Joined: October 16, 2004 Posts: 676 Location: Miami, Florida
Posted: Sun Sep 20, 2009 7:22 pm Post subject: Engine has a dead spot when reving engine. Idles fine. |
I need a little help here. I have 1600 DP with SVDA with vac. line attached and timed accordingly and as of late the engine has a dead spot on acceleration. Unlike 009 flat spot issue with the pict 34, this is different. Here is the breakdown:
1. Engine takes a quite a few cranks to get started as if starving for fuel in the carb bowl.
2. Idles great.
3. Timing, valves, adjustment to carb done.
4. Noticed a lot of condensation building up around carb base and adjustment screw area. Condensation tends to drip down the intake manifold a little. Very humid in Miami.
5. Revs with no hesitation, but then at around 2500 or so complete dead spot as if the I lost spark for a split second. I can push past it by giving it more gas and it revs out fine.
6. Plugs and wires are new as well as cap and rotor. All Bosch components.
Now, I have resealed the carb. and blew out all jets and passages, although it was a new Mofoco purchase. No issues were found.
I did notice the fuel filter looking quite empty when running. Should some residual gas be able to be seen as it is refilling from the pump? When the engine is shut off there is around 1/2 the filter full of fuel.
Maybe I am not getting the right amount of fuel from the tank or the screen is dirty.
What gives? Help!! _________________ Matthew Pate
1974 Brasilia |
madmike Samba Member
Joined: July 11, 2005 Posts: 5302 Location: Atlanta,Michigan
Posted: Mon Sep 21, 2009 5:37 am Post subject: |
I install the filter before the pump then check to see if the gas shoots across the driveway you'll know if the pump is working  _________________ 'Black Ice'Drag Buggy 'Turbo'
Rail Buggy 1915 turbo
sloboatnova Samba Member
Joined: September 20, 2009 Posts: 989 Location: Broken Arrow, Ok
Posted: Mon Sep 21, 2009 5:44 am Post subject: |
| One thing to consider is, does your gas tank have a way to bring in air when the gas is sucked into the engine. If not, it could create a vacuum that will cause the fuel pump to not perform effectively at certain RPM's. |
mpate Samba Member
Posted: Mon Sep 21, 2009 6:22 pm Post subject: |
I have a vented cap, but I have thought about this before. Wouldn't the car basically die out if it was starving for fuel after the dead spot threshold is reached? Once I get past this dead spot, it revs out with no problem. Could a bad condenser cause this? It doesn't happen at the same RPM it seems. _________________ Matthew Pate
1974 Brasilia |
