How do I check end play?
Stray Catalyst
Stray Catalyst is offline
PostPosted: Mon Sep 28, 2009 6:53 pm    Post subject: How do I check end play? Reply with quote
I did a search and didn't find an answer I understood. I'm trying to find the end play in an engine I just bought - the engine is in unknown condition. The flywheel is off - in fact, I received the flywheel and the engine from entirely different sources, so they're used and not a mated set.
So, how can I check end play? I looked through the Muir book - I don't have the Bentley manual.
Stray
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Sep 28, 2009 6:59 pm    Post subject: Reply with quote
You can't with the flywheel off.
You need to remove the flywheel seal and all the shims. Then install the flywheel and measure the distance from maximum inward and outward of the flywheel. Then add a combination of 3 shims that gives you .003-.007" endplay. If you can't get it that low then you have a worn engine.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Stray Catalyst
PostPosted: Thu Oct 15, 2009 2:57 pm    Post subject: Reply with quote
I haven't installed a flywheel to test it, but I found out I can move the crankshaft in and out of the engine about 1/8" by hand, with little resistance - all the case studs are tightened, one head is removed. Am I missing something, or is this case toast?
Stray
fastinradford
fastinradford is offline
PostPosted: Thu Oct 15, 2009 3:00 pm    Post subject: Reply with quote
worn bearings and/or case, only a tear down will tell all.
EDIT:
YOU CAN
ONLY
CHECK
ENDPLAY
WITH A
FLYWHEEL
INSTALLED
95 jetta 5spd, (first waterpumper vw)
the nice 74 Ghia, (of course the fiance drives that one).
My mk1 jetta 1.6d
"It'd still be like my grandads old broom though, original, only 3 new heads and two new handles" -Marv [UK]
Paul Windisch
Paul Windisch is offline
PostPosted: Thu Oct 15, 2009 3:01 pm    Post subject: Reply with quote
The crankshaft endplay is set with the flywheel and those shims. The crank will flop all over until you get them put on.
*ASE Recertified Master Automotive Tech*
1984 Mexican Beetle
-1914cc
-L3 Heads 35x32 valves 52cc chambers
-0.040" deck for about 9.1:1 Compression
-Engle W110 cam
-CB Super Stock 1.1:1 Rockers
-Stock Heat Exchangers w/ Tri-Mil Muffler
-Dual Weber IDF 40s w/ 26mm venturis
-034 SVDA Distributor
2013 Chevrolet Volt DD
2005 Pontiac Montana SV6
MAHLE Service Solutions
Applications Engineer
Stray Catalyst
PostPosted: Thu Oct 15, 2009 3:26 pm    Post subject: Reply with quote
Thank you - I'm delighted to be wrong.
Stray
andrewsanteiro
andrewsanteiro is offline
PostPosted: Fri Oct 16, 2009 11:16 am    Post subject: Reply with quote
I just bought a baja with a bus 1600 in there and it has no end play. HOWEVER. the shady f*** I bought it from would be capable of pulling any sort of maneuvers. Could someone put excessive shims to 'hide' end play? If so is this something that could cause a problem that I should check if the engine is already on the floor?
On the road. Thanks to the Samba!
72' 1600cc Baja Bug
Chris Vellat
Chris Vellat is offline
PostPosted: Fri Oct 16, 2009 11:23 am    Post subject: Reply with quote
^ It would be 'normal' for someone to think they're fixing the endplay by just adding more shims 'til the crank didn't clunk.
You should pull the flywheel off and see if the bearing is moving in the case...if it is, there's a move you can do to buy some time without tearing it all down...but if the bearing seems to be tight you can adjust the endplay to factory specs, maybe a little loser if you're suspect.
Make sure to use the correct endplay shims when setting endplay, early shims will physically fit on a late crank, but they hula-hoop around cutting right into the crank.
buckwheet
buckwheet is offline
PostPosted: Tue Oct 20, 2009 2:08 pm    Post subject: Re: How do I check end play? Reply with quote
Stray
u can check it with a piece of 3/8 threaded rod 4 nuts and a big washer lock the rod to the case where an engine bolt goes. set a second nut just about even with the flywheel , check it with a straight edge, put on another nut and washer push flywheel in. put feeler guage between washer and flywheel. pull flywheel out check distance with feeler guage again subtract differrance. if 4 thoudsants or less your in if more than 5 thoudsants your
Chris Vellat
PostPosted: Tue Oct 20, 2009 3:32 pm    Post subject: Re: How do I check end play? Reply with quote
buckwheet wrote:
... if 4 thoudsants or less your in if more than 5 thoudsants your fucked
Factory spec. is 0.0027" to 0.005" - but many prefer to set it up a little looser in favor of tighter - maybe as much as 0.008" - not my fancy.
BGEE68
BGEE68 is offline
PostPosted: Tue Oct 20, 2009 4:22 pm    Post subject: Reply with quote
The Factory spec is 0.07 to 0.13mm (.0027 to .0051), the wear limit is 0.15mm (.0059).
Buy and use this tool to set up the end play:
We were taught to set end play to the mid point of the specs:
0.10mm (.0039)
