minsk Samba Member
Joined: March 17, 2008 Posts: 901 Location: pittsburgh
Posted: Tue Dec 01, 2009 3:19 pm Post subject: ugh |
i am replacing the coil on my 85 weekender...
seems i have wires miked up .
there are three wires
two black ones and one black and white.
wich one is positive wich one is neg
looked in my bentley didnt see a diagram.. |
shadetreemech Samba Member
Joined: October 05, 2005 Posts: 831 Location: Claremont, CA
Posted: Tue Dec 01, 2009 4:00 pm Post subject: |
My 84's got a thicker Green wire to the + terminal and and a Black and Black w/ white stripe to the -.
 _________________ '84 GL 1.9
'01 Volvo V70 T5
'88 Westy - "MZDRTHY" |
minsk Samba Member
Posted: Tue Dec 01, 2009 4:09 pm Post subject: |
the green wire goes on the two prong terminal on mine...
then i have two black ones and a b/w |
ftp2leta Samba Member
Joined: October 11, 2004 Posts: 3271 Location: Montreal
minsk Samba Member
Posted: Tue Dec 01, 2009 4:18 pm Post subject: |
oh man..i hope i dont have a problem..
i have a 1985 weekender digijet
i do NOT have two green wires going into the top one...only one green wire...
ugh.
and then
down below ..two black ones and one black and white
shit |
minsk Samba Member
Posted: Tue Dec 01, 2009 4:37 pm Post subject: |
this is mine..hmm only one green wire...the other side of the green plug wire is empty also...
perplexed in pittsburgh
[/img] |
Posted: Tue Dec 01, 2009 7:55 pm Post subject: |
| minsk wrote: |
[/img] |
Ditto - thick green wire is in a two-prong connector by itself.
'01 Volvo V70 T5
minsk Samba Member
Posted: Tue Dec 01, 2009 8:39 pm Post subject: |
so wich one is + tho... black and white ...or black
i wished i had a diagram of the tabs so i knew exactyl wich each one is for |
Californio Samba Member
Posted: Tue Dec 01, 2009 9:35 pm Post subject: |
Bentley 97.61 shows green going to post 1 on the coil. The other green is to the tach. If you don't have a tach, you don't have the other green.
Black and black and white's go to post 15.
The coil is labeled with the numbers. |
conrad1468 Samba Member
Joined: December 20, 2003 Posts: 1019 Location: Jeannette, PA 15644
