Headlights aren't working
Page: Previous  1, 2, 3  Next
jacob.
jacob. is offline
PostPosted: Wed Dec 16, 2009 6:05 am    Post subject: Reply with quote
Shit! I hope thats not what I have to replace. Thats a high price for a little part.
RCB wrote:
jacob gets razzed a lot cause he has the only GEX engine thats lasted longer than half an oil change.
Mikeyb
Mikeyb is offline
PostPosted: Wed Dec 16, 2009 6:17 am    Post subject: Reply with quote
Sounds like it to me. You have all the same symptoms I had only a couple weeks ago. Headlights mysteriously stop working; a pull on the high-beam arm turns them on; releasing the arm turns them off; heater and wipers still work. . . yep, sounds like the high beam switch. You might be able to find one at your local Westy cemetery.
'82 1.9 TD Westy (Tortuga Veloce)
2014 Honda Pilot
2021 VW Atlas
jacob.
jacob. is offline
PostPosted: Wed Dec 16, 2009 7:15 am    Post subject: Reply with quote
Guess I'll make some calls. Theres a few dead vans around the area.
jacob.
jacob. is offline
PostPosted: Wed Dec 16, 2009 7:59 am    Post subject: Reply with quote
My temporary fix for the drive to work tonight Smile A pencil, a folded up piece of paper, some zip ties, and pure genius.
youremyboyblue
youremyboyblue is offline
PostPosted: Wed Dec 16, 2009 10:32 am    Post subject: Reply with quote
10) take a break and come back to it > beer
11) repeat steps 1-10
12) swap bulbs > realized bulb does not work on functional side
13) kick dirt that a day was wasted over a bad bulb > unwarranted bad feelings toward vendor and self
14) put old lower power bulbs in while wating for replacement > light from both headlights on low or high
so now that i have learned a bunch and have light, i have some poltergeist business going on ...
while driving, the driver's interior light flickers on accompanied by loss of power and dimmed headlights/interior. i'm troubleshooting a bit of a hunting idle but, the interior light flickering while in the light when door open position is not only new but, mysterious. i thought that i had read something about this issue with the flickering interior in another headlight thread but, am at a loss to find it currently.
any help is appreciated!
singler3360
singler3360 is offline
PostPosted: Tue Dec 29, 2009 8:45 pm    Post subject: Reply with quote
Jacob, what finally resolved this for you? I currently have the same problem. Thanks.
kevtherev
kevtherev is offline
PostPosted: Wed Dec 30, 2009 4:19 am    Post subject: Reply with quote
I too am interested in who the culprit was
singler3360
PostPosted: Wed Dec 30, 2009 7:19 am    Post subject: Reply with quote
OP indicates in a PM he has not resolved this issue yet. I just ordered new headlight AND high beam (wiper/washer assembly) switches from VC. I'll try the high beam first and will report back the results. It will be next week most likely before I report in. In the meantime, I'm tempted to wire the yellow and white wires back together, bypass the relays, to see if the problem persists. Has anyone done this already?
jacob.
jacob. is offline
PostPosted: Wed Dec 30, 2009 9:35 am    Post subject: Reply with quote
Is bypassing the relays bad for the van at all? And no I haven't solved the problem. My van is being a piece of shit right now. Its draining the battery, so every morning when I go to start it, it doesn't work. With a full battery everything works fine (except the headlights of course). I ordered a new voltage regulator/brushes and hopefully that solves that. If not, I'll have my alternator rebuilt.
singler3360
PostPosted: Wed Dec 30, 2009 9:57 am    Post subject: Reply with quote
I was thinking that reconnecting the yellow and white wires back together would simply restore it back to the stock configuration. If nothing else, just to reestablish a baseline since I performed a lot of upgrades at the same time when the dash was out. However, I'd rather not clip out the butt splices and shorten those wires anymore than they are. For instance, could it be possible the Shoebox Electronic headlight buzzer I wired in some time ago (and has always worked) is somehow interfering with the headlight relay kit?
jacob.
jacob. is offline
PostPosted: Tue Jan 05, 2010 1:06 pm    Post subject: Reply with quote
I installed a used headlight switch I got at a wrecking yard for 20 bucks. Headlights came right back on. Now on to the relays.
singler3360
PostPosted: Tue Jan 05, 2010 8:20 pm    Post subject: Reply with quote
Ok, the new high beam assembly and headlight switch arrived today. Didn't even need to take the headlight switch out of the package, the culprit was the high beam switch. Westapotamous finally has [brighter] lights again. Yessss!
claytonic
claytonic is offline
PostPosted: Thu Jan 07, 2010 8:09 am    Post subject: Head light and fans Reply with quote
I have the same thing going on after a relay install. Dam it nothing is simple!
I was wondering if this is normal
If you have
the key off
running lights on (not the head lights )
heater fan switched on
and flash the high beams
do your heater fans come on ?
Mine do, now at least don't know if this was the case before?
Thanks
crazyvwvanman
crazyvwvanman is offline
PostPosted: Thu Jan 07, 2010 8:36 am    Post subject: Re: Head light and fans Reply with quote
This is normal. With the key off but headlight switch all the way on, only the running lights are on. If you turn on the heater fan nothing happens. Then flash the high beams and the heater fan will spin. It has nothing to do with adding the relays.
Mark
If you have
the key off
Thanks
claytonic
PostPosted: Thu Jan 07, 2010 8:59 am    Post subject: Thanks Reply with quote
Thanks for the speedy replay
I was not looking for ward to chasing gremlins!
GWTWTLW
GWTWTLW is offline
PostPosted: Thu Jan 07, 2010 10:17 am    Post subject: Reply with quote
That's also a good way to raise or lower power windows without the ignition on too...
89 Syncro Westy - GW 2.5, now with a double knob job
@gwtwtlw
TUFF
TUFF is offline
PostPosted: Sat Jan 16, 2010 2:09 pm    Post subject: Left headlight out on Low beam Reply with quote
My challenge is th left low-beam does not come on. Wipers work, and heater fans work. Fuse 10 good. Any suggetsion ?
thatvwbusguy
thatvwbusguy is offline
PostPosted: Sat Jan 16, 2010 4:41 pm    Post subject: Reply with quote
Bad bulb? Start with the simple stuff.
TUFF
TUFF is offline
PostPosted: Sat Jan 16, 2010 5:26 pm    Post subject: Reply with quote
Bulb is OK, wondering if it is the Light switch - other posts say if wipers and hetaer fan work, it must be the light switch. Thanks
jacob.
jacob. is offline
PostPosted: Sat Jan 16, 2010 5:31 pm    Post subject: Reply with quote
If it was the headlight switch, both low beams would be out, and the high beams would still work. Perhaps the wire to that specific light fell off or is corroded?
Page 2 of 3
