25 HP and 36 HP Outside differences ?
Flavio
Flavio is offline
PostPosted: Wed Jan 13, 2010 12:47 pm    Post subject: 25 HP and 36 HP Outside differences ? Reply with quote
Hello
Is it possible to see some diferences beetween the 25 Hp case and the 36 HP one, or are they equal from an outside view ?
If there are some diferences could anybody post some pics ?
Thank you very much for any help
Regards
Flavio
RareAir
RareAir is offline
PostPosted: Wed Jan 13, 2010 2:43 pm    Post subject: Reply with quote
The case itself? Or the parts that go on the outside? (shroud, fuel pump, oil filler etc....)
If you looking at a very early 25hp, early cases were made of Aluminum. Later VW added Magnesium for extra strength. The coloring is obvious if you find an Aluminum case. Here's the one out of my '47
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
Flavio
Flavio is offline
PostPosted: Wed Jan 13, 2010 2:56 pm    Post subject: Reply with quote
Hello. Thanks for your reply. I mean the case itself. When the magnesium was added by VW is it more dificult to see the diferences ?
Ivan Fuller
Ivan Fuller is offline
PostPosted: Thu Jan 14, 2010 1:16 am    Post subject: Reply with quote
If you are going to use a 36hp case you should try and find an early one that does not have the cast threaded lug on the genarator stand that holds the later style oil filler. I'd say this is the most notable visual difference between a magnesium (elektron) 36hp and 25hp case, also the early cases do not use the later part numbering system.
johnshenry
johnshenry is offline
PostPosted: Thu Jan 14, 2010 7:46 am    Post subject: Reply with quote
x2 That is what I look for too.
John Henry
'57 Deluxe
'56 Single Cab
Flavio
Flavio is offline
PostPosted: Thu Jan 14, 2010 8:31 am    Post subject: Reply with quote
By phone I have speak with the person that has the good 25 or 36 HP case and he told that the case have the cast threaded lug for the oil filler. So, it seems like a 36. He also sent me the parts numbers : the rigth side is 111101102 A and the feft is 1111011101 A. Can you give some more info with this ?
Thanks
johnshenry
PostPosted: Thu Jan 14, 2010 8:38 am    Post subject: Reply with quote
What is the serial number on the case???
John Henry
'57 Deluxe
'56 Single Cab
spectre6000
spectre6000 is offline
PostPosted: Thu Jan 14, 2010 11:00 am    Post subject: Reply with quote
The case was eventually made of magnesium for light weight (a crucial part of Ferdinand Porsche's engineering philosophy), not for strength. Aluminum is the stronger of the two alloys in this application.
Jason Hopper
-'58 German Market Deluxe Beetle (in progress)
-'84 M1009 CUCV
-'81 K10
"Buy the best, cry once." -Gene Berg
"A cheap man will always buy the cheapest thing available, and then buys another one hoping for a better result, and then spends the rest of his life in misery complaining about it. A thrifty man will buy a good part once and never think about it again." -RockCrusher
"Don't feed the Shitty Parts Monster!" -Me
Zwitterkafer
Zwitterkafer is offline
PostPosted: Thu Jan 14, 2010 11:01 am    Post subject: Reply with quote
X2 on the serial number being the best indicator.
Another clue:
The small raised area onto which the s/n is stamped is longer left-to-right and more pronounced on the 36 hp version.
Be aware that there exist factory replacement 25 hp cases with 36 hp appearance and 36 hp upgrades, but still with the 25 hp cylinder bores in the block. In this case, (pun intended) measuring the cylinder bores is the way to tell.
H.
- Zeuxius, 400 BC
Flavio
Flavio is offline
PostPosted: Thu Jan 14, 2010 4:27 pm    Post subject: Reply with quote
You mean that the cylinder bores have diferent diametres ? Which are ?
Zwitterkafer
PostPosted: Fri Jan 15, 2010 5:31 pm    Post subject: Reply with quote
Sorry, I won't be able to measure and post on this before Monday.
Anyone?
H.
- Zeuxius, 400 BC
Flavio
Flavio is offline
PostPosted: Sat Jan 16, 2010 4:54 am    Post subject: Reply with quote
Ok Zwitterkafer.
I'll wait for the measure. All this is because I want to built a good 36 HP. The person who has the good case lives farway from me and all the talks about the case have been done by phone.
I have an used but still good Mahle 36 hp cylinder set. The cylinder part that inserts in the case has a diameter of 81.8 mm. Regardind this, I imagine that the bore in the case must be a litle bit bigger (82 mm ?).
If the person's case has that measure (82 mm) can I assume that it is a 36 Hp Case ?
Thank you
Zwitterkafer
PostPosted: Tue Jan 19, 2010 10:03 am    Post subject: Reply with quote
fnribeiro, you are correct.
36 hp case openings = 82 mm dia
25 hp case openings = 80 mm dia
Sorry for the delay; I could only measure them this morning.
Cheers,
H.
- Zeuxius, 400 BC
Flavio
Flavio is offline
PostPosted: Wed Jan 20, 2010 3:33 am    Post subject: Reply with quote
Ok Zwitterkafer. Thanks for your care.
The person who has de case phone me and says that the openings have 80 mm. So, it´s a 25 HP case.
He also says that I could open the bores for 82 mm., but I believe that is not suficient for transforming a 25 Hp case in a 36 HP case. There must be some other internal differences. I think I am going to tell him to forget the possible business with me.
Best regards
Zwitterkafer
PostPosted: Wed Jan 20, 2010 11:22 am    Post subject: Reply with quote
Yes, there are other internal differences; the 36 hp have more internal ribbing for rigidity, and at some point the oil galleries had some refinements in the area of the pressure relief drillings. While a converted 25 hp would work, (some people here do that on purpose to circumvent buying expensive 25hp pistons & cylinders) it would be better to start with the real thing, freeing up your seller's 25hp for someone else in need.
Good luck,
H
- Zeuxius, 400 BC
Flavio
Flavio is offline
PostPosted: Wed Jan 20, 2010 12:14 pm    Post subject: Reply with quote
Once more, thanks for your very good help.
Best regards
SplitPersonality
SplitPersonality is offline
PostPosted: Thu Nov 08, 2012 6:05 am    Post subject: Reply with quote
Bringing up an old topic here....have been doing some searching, but...
- What is the last engine serial number on a pure aluminium case? (feb '51 is it?)
- What is the last engine serial number on the 25hp engine?
- What is the last engine serial number on a "cast gen stand" engine?
L378
L378 is offline
PostPosted: Thu Nov 08, 2012 8:02 am    Post subject: Reply with quote
I can't remember off the top off my and can't do a quick search for the first two questions right now, but but first date seems about right and want to say sometime in Dec '53 for the other (but can't recall with certainty) as to the 3rd - well in to the middle 60's with a number above 4000000. It was in fact, a fresh air 36 hp. You can see this in this vintage speed forum thread http://www.thesamba.com/vw/forum/viewtopic.php?t=531266&start=20
I'd be interested in the date for this
I'm assuming this is something in the very late 50s?
SplitPersonality
PostPosted: Thu Nov 08, 2012 8:49 am    Post subject: Reply with quote
L378 - thanks for your inputs!
The picture (pasted below) in your attached link pretty much answers 2 of my questions, I see.
Now - when did they stop the shiny alu case?...January-1951?
L378
L378 is offline
PostPosted: Thu Nov 08, 2012 10:18 am    Post subject: Reply with quote
from progressive refinements engine section page M9
Jan 19, 1951 chassis# 1-0225 376 & 20-09 065 unit # 272 061 Crank Case Now: made of electron Formerly: remelt alloy
So 1-19-51 is the date
The exact date of the cutoff for the 25 page M 19
Dec 21 1953 Chassis # 1-0575 415 & 20-069 409 unit # 695 282 & 695 356 & 122-019 888
I think that covers it as I see the end of 36 hp production listed in the above photo.
So my question remains
