Calculating Tire Height mathematically
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Thornton
EMPI Guru
Thornton is offline
PostPosted: Sat Jul 18, 2009 8:04 pm    Post subject: Calculating Tire Height mathematically Reply with quote
Tire Height questions pop up here in the forum often so I am posting the math equation so anyone can figure out the height of a tire.
This Simple math equation can tell you the height of a tire without air and vehicle weight on it.
We will do the tire size 205-70-15
you take the width 205, Divide it by 25.4 (25.4 is how many millimeters are in a inch)
205/25.4 = 8.07086614
Now you take the Series of the tire, in this case its 70
70 represents that the side wall height is 70% of the tread width
you take the 8.07086614 times it by 0.7
8.07086614 x 0.7 = 5.6496063
you then times this number by 2 meaning above wheel and below wheel
5.6496063 x 2 = 11.2992126
take that number and add the rim diameter to it
11.2992126 + 15 = 26.299
so a 205 / 70 / 15 has a rolling diameter of 26.299"
you can do the math like I always tend to do
OR
use this link below for the non math people Wink
http://www.wallaceracing.com/tire-aspect-calc.php
Thornton
booch
booch is online now
PostPosted: Mon Jul 20, 2009 6:37 pm    Post subject: Reply with quote
Here is another link for the non-Mensa crowd. You can compare two sizes at the same time, complete with graphics.
http://www.rims-n-tires.com/rt_specs.jsp
CoastalDefender
CoastalDefender is offline
PostPosted: Wed Oct 21, 2009 9:02 pm    Post subject: Reply with quote
And if you are a complete dolt like myself, this should do you well...
http://www.miata.net/garage/tirecalc.html
Rewired '74 Std Baja w/ '69 engine
sactojesse
sactojesse is offline
PostPosted: Tue Dec 01, 2009 11:17 am    Post subject: Reply with quote
I prefer to do the math myself, but I have a simpler method.
(Width in mm) x (double the aspect ratio) = sidewall height in mm
Divide by 25.4 mm/inch to get sidewall height in inches
Add to rim diameter in inches to get total diameter
For example, 165R15 is a P-metric (82 series) tire:
165 mm x 1.64 = 270.6 mm/25.4 = 10.65 in. + 15 in. = 25.65 in.
1966 Karmann-Ghia convertible
schunacher
schunacher is offline
PostPosted: Wed Jan 20, 2010 4:52 pm    Post subject: Tire math "without air" Reply with quote
@Thornton (or anyone),
What are the implications of measuring the tire without air? Does it get smaller when you add air?
Stephan
Thornton
EMPI Guru
Thornton is offline
PostPosted: Wed Jan 27, 2010 2:33 pm    Post subject: Re: Tire math "without air" Reply with quote
Stephan
Looking on Tirerack.com it says this about tire measurement
Overall Diameter
A tire's overall diameter is the outer diameter of the tire measured in the center of the tread. This measurement is made without any load placed upon the tire and after the tire has been properly mounted on its industry assigned measuring rim and has been inflated and reset to its test pressure after 24 hours.
If you take a tire without them mounted on the rim and compare the same tire to one mounted on a wheel they are going to seem to be different heights. the mounted version on wheel has some sidewall stretch for the rim width.
So depending on the width of your rim, i guess your tire can get smaller if your stretching it on a wide wheel
Thornton
sammystics
sammystics is offline
PostPosted: Thu Feb 18, 2010 10:51 pm    Post subject: Tire size Reply with quote
Here's another place to go to. It will calculate the tire size for you.
Also if you put in the rim size,width and et it will give you the backspacing too.
http://www.wheelsmaster.com/rt_specs.jsp
I Don't Wanna Work
I Wanna Bang On The Drums All day
KellyH
KellyH is offline
PostPosted: Thu Feb 25, 2010 7:51 am    Post subject: Tire size calculator and charts Reply with quote
This site has another calculator as well as charts that list tire dimensions of the older tires.
http://vw.zenseeker.net/Wheels-TireSizing.htm
schunacher
PostPosted: Thu Feb 25, 2010 1:34 pm    Post subject: Reply with quote
There is another interesting "tire height" dimension listed in the VW service manuals called "Rolling Radius" (12.09") which is substantially less than the 5.60x15 tire's calculated radius (12.65"). I assume that the reduced radius is because of gravity acting on the flexibility of the sidewall. I guess it only matters if you are calculating the ride height of the car, but the interesting part is that VW chose to publish this number.
KellyH
KellyH is offline
PostPosted: Thu Feb 25, 2010 10:25 pm    Post subject: Reply with quote
Calculated height and true height are different. There is also static height, which is measured when weight squishes the tire a bit. This changes the true rolling diameter of the tire, which in turn changes the final gearing of the car and the speedometer reading.
Rolling radius is
"Tire-rolling radius is the distance from the center of the wheel to the road. Static radium applies when the vehicle is standing still. Dynamic rolling-radius described wheels in motion. The latter is used to measure tire revolutions per mile and is usually slightly higher than static radius. "
This would be a little harder to measure than static, as the car needs to be moving to measure it and will differ in regards to tire pressure, axle load, speed, tire size, tire composition, etc.
The effective rolling radius
Tyre and vehicle dynamics
The automotive chassis: Components design
schunacher
PostPosted: Fri Feb 26, 2010 4:00 pm    Post subject: Reply with quote
I don't have any real expertise but here are some thoughts off the top of my head. Once you start accounting for distortion of the tire you can no longer rely on calculations that assume that the tire is a circle. In other words the reduced radius due to distortion of the tire does not affect the speedometer or gearing since the circumference of the tire remains the same as it was in a distortion free calculation (reduced radius does not result in reduced "circumference" since the tire is not a circle anymore). Therefore we are still pulling along the same amount of road with each revolution of the axle and tire. Does that make sense or am I missing something?
KellyH
KellyH is offline
PostPosted: Fri Feb 26, 2010 9:04 pm    Post subject: Reply with quote
There is a great deal of chemistry and physics that goes into tire science.
I think that knowing how to calculate the size of a fully inflated tire and knowing that this is really just a ball park estimate of what you will have in the end is really all most of us will find useful.
Lucky for folks like me, there are charts and calculators available on the web, as well as lots of other car owners who have already experimented with different tire/wheel configurations who have posted their results and photos on the web.
schunacher
PostPosted: Sun Feb 28, 2010 8:30 pm    Post subject: Reply with quote
Tire selection is definitely voodoo in more ways than one. Tire selection is one thing that makes Formula One racing so interesting (it used to be even more interesting when F1 had competition between multiple tire manufacturers). One aspect (unintended pun) that seems counterintuitive is that F1 cars use relatively tall profile tires to produce their phenominal handling.
strelnik
strelnik is offline
PostPosted: Tue Nov 16, 2010 1:15 pm    Post subject: Re: Calculating Tire Height mathematically Reply with quote
Thanks for doing this, I figured it out on my own and made a chart, but I have another question:
What happens if you have one of the 1950's era tires that were 165 mm x 400mm?
Unfortunately, they never showed the aspect ratio of the tire Sad
L'audace! L'audace! Toujours l'audace!
Metzler
Metzler is offline
PostPosted: Thu Nov 27, 2014 12:22 pm    Post subject: 65 beetle project Reply with quote
I just had my 65 painted and I bought everything new to replace the old. I replaced the wheels with 15 in BRM 5 in wide wheels I'm using 195/60/15 on front and rear it has 67 fenders on front it already was lowered a lil in the front but when I put the new wheels on the front my driver side tire scrubs any suggestions on what I can do to fix this problem?
Thanks David
FRNKNSTNGHIA
FRNKNSTNGHIA is offline
PostPosted: Mon Jan 27, 2020 8:07 pm    Post subject: Re: Calculating Tire Height mathematically Reply with quote
I've been a fan of this site. You can play with offsets, widths, tire sizes and see how the wheel should sit in the fender well.
www.willtheyfit.com
Car32
Car32 is offline
PostPosted: Fri Oct 09, 2020 7:23 am    Post subject: Re: Calculating Tire Height mathematically Reply with quote
Another other other other site:
https://www.rimsntires.com/specspro.jsp
This one's nice 'cause you can compare two potential tires and rims side-by-side.
First Car = 1970 Westfallen Typ II
Second Car = 1966 Baja
Nth Car = 2006 Cayman S
1971 Karmann Ghia Coupe
sonoma_vw
sonoma_vw is offline
PostPosted: Wed Mar 16, 2022 4:59 pm    Post subject: Re: Calculating Tire Height mathematically Reply with quote
I haven't seen this case yet, so I'll grit my teeth and ask:
Im running 185/ 60 R15 on the front of my slightly lowered bug. (205/ 60 R15 on the back)
I am looking for Bias Ply look (piecrust) radials. It seems the smallest is the 560 R15. I have been told they are too big for my lowered bug.
Is there a calculator that compares 2 different types of tires? I can't find one that converts the XXX/ XX R15 to a YYY R15 tire format. (This shouldn't be too hard, I realize, but I dont get the different tire formats. Appologies)
Summary:
I'm just trying to figure out what size "Bias Ply look" radial that I can safely fit on a car that's got 185/ 60 R15 as the smallest size.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
