zadefaraj Samba Member
Joined: March 29, 2009 Posts: 20 Location: Houston, TX
Posted: Tue Feb 02, 2010 6:26 pm Post subject: Transmission flooded out in April 09. Salvageable? |
I was wondering if anyone could share their opinion as to whether or not this transmission could be salvaged. It's a 74 bay window with what appears to be a GEX rebuilt motor. I've read quite a bit about the GEX motors and the hit/miss with them, but this one seems to be okay (20k+) Anyways, the engine and tranny were totally submerged in April with the engine being treated for water almost immediately, but the tranny was not.
Since that time the bus has actually ran a short distance (max 1 mile), and from what I could tell, everything seemed in order except for some newly formed intermittent 1st and 2nd gear synchro scratching.
Well, I drained the tranny oil today and boy that stuff smelled pretty bad! I took some photos of the oil, the oil drain bolt, the metal shavings found on the oil drain bolt head, the very thick soupy mixture of oil and water, and also after running a small magnet thoroughly through the goop.
I let her sit and cool down for about 20 minutes before I drained the oil seeing as how I had to move it into my garage. The color and consistency is very much what I recall seeing coming out of the motor when I drained that out, just this time it's a LOT thicker. There were quite a few shavings found on the bolt as you can see in the photos. I tried to clean it up a little bit to see if they were large fragments, but instead, they were actually fine granules arranged along the magnetic field lines that turned into paste on touch. I also just read somewhere that it is not unusual to find this amount on the bolt.
I measured roughly 4400cc of fluid (4.4L or 4.65 US quarts) coming out of the trans, which may be quite a bit, but im not sure. I would really like to salvage the trans if possible, but I don't think I can make that determination alone. If someone would be kind enough to offer their advice or expertise, I would greatly appreciate it.
Thank you in advance!
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9156 Location: Syracuse, NY
Posted: Tue Feb 02, 2010 6:34 pm Post subject: |
Fill it up with fresh GL-4 and see where it goes.....what's the worst that could happen? I don't know how you want any of us to make a determination as to the life expectancy of your transmission. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
borninabus wrote: |
a measurement of your rod would be extremely useful. |
notchboy wrote: |
my dad wasnt a belittling cock when he tought me how to wrench on cars. |
EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Paslode235 Samba Member
Posted: Tue Feb 02, 2010 6:38 pm Post subject: |
Refill the tranny with some fresh tranny fluid. Then after 500 miles or so drain it out and refill it with some more clean fluid. I am guessing the tranny will be fine. _________________ "We make a living by what we get, but we make a life by what we give." Sir Winston Churchill
Mint Green 1965 Beetle - "Misty"
White 1974 Westy - "The Fig Rig"
Yellow 1972 Super Beetle - "Jasper" RIP
Black 2001 Jetta wagon - "Gadget"
Red 2004 Jetta TDI - "Lucy" |
thanks for the tip. considering the amount of shavings on the bolt, and any previous experience with flooded cars or vw's, i'd say someone might be able to make an educated guess whether or not it has a chance for survival. |
rumplestilskin Samba Member
Joined: January 13, 2007 Posts: 963 Location: los banos,CA
Posted: Tue Feb 02, 2010 6:40 pm Post subject: |
the shavings are normal . unless u just changed the fluid recently before the flood _________________ currently 71 super auto-stick, 73 ghia, 71 yellow ghia , a 68 square w71 fi, a 77 bus station wagon deluxe. and finaly finaly a 74 riveria with volvo pawer .ITS AN ADDICTION!!! |
Posted: Tue Feb 02, 2010 6:45 pm Post subject: |
cheers guys,
i'll give it a go and post the results. these wonderful things just don't want to die. a good friend of mine just flipped his bus 1.5 times and did a 180 monday coming down from colorado to visit. everything got thrown about as if it were in a blender. but the only thing that broke was the side view mirror. even the front windshield popped out and was put back in without a crack. drove back home that very same day. albeit a bit slower.
Rusty O'Toole Samba Member
Posted: Tue Feb 02, 2010 6:58 pm Post subject: |
The only problem would be if the bearings were rusted and it's impossible to tell that unless you tear the tranny down.
It's probably OK. It appears some water got in but it settled to the bottom of the tranny until it got mixed in by driving. As long as the bearings were not full of pure water, they are OK.
Drive it and see what happens. 9 chances out of 10 there is no serious damage. |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Tue Feb 02, 2010 7:20 pm Post subject: |
In very cold climates, VW has recommended ATF (like 10* below zero) in the manual boxes. I would think a nice short run down the road with some ATF to use as a flush would really help get rid of not only some of the sludge but it would also help blast out rust from bearing races. ATF has excellent detergent properties. Change and refill with GL4 80-90.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
redwagon Samba Member
Joined: March 05, 2006 Posts: 220 Location: Arvada, CO
Posted: Tue Feb 02, 2010 8:09 pm Post subject: |
+1 for flushing it with ATF. How on earth did your friend come to flip his bus? Strong crosswind? |
fusername Samba Member
Joined: March 15, 2006 Posts: 2899 Location: Boston MA
Posted: Tue Feb 02, 2010 8:57 pm Post subject: |
I was going to say find something to flush the trans with, but apparently ATF is the ticket. then fill it up with something decent, run it a few weeks, assuming you drive this thing, then fill it with something good and don't worry about it for another 100k.
the trans only has one tiny pinhole for in/out on it, so it doesn't take on much water all that fast. Also most trans will have more metal than that, thats a pretty clean plug. _________________ [email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote: |
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine! |
Emeritusx Samba Member
Joined: June 20, 2008 Posts: 2775 Location: 12 inches behind the wheel
Posted: Tue Feb 02, 2010 9:08 pm Post subject: |
ATF is a good idea.. it is the recommended fluid when its colder than -31F.. _________________ 82 Westy ☢, 66 Splitty ☮, 73 Type 181 ✠ |
Posted: Tue Feb 02, 2010 10:39 pm Post subject: |
I used to do a lot of off road driving and drained out fluid that looked like yours from every few months to a year. Never really had any problems with it. This was on a non VW which was driven weekly but not daily. I have never been above just filling a gear box with Diesel, driving it around the block a time or two and then dumping the Diesel and filling it again with gear lube. |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 23148 Location: Oklahoma City
Posted: Wed Feb 03, 2010 8:44 am Post subject: |
DO NOT put ATF in the tranny. Yes...it can be used in very cold climates...but only if you remain with that gear oil.
No...metal filings like that are NOT normal. You should have little or no normal wear on gear faces. The only real wear parts in the tranny....if its running well....are non-magnetic. Those look like what you get when you have destroyed bearing cages.
If you really want to make that tranny survive...strip and clean it.
the reason you want to do this...is (a) if any of your bearings has a single rust pit or "fleck" that will trash the bearing in a moderate to short time. Needle bearings and roller bearings do not tolerate rough or pitted surfaces.
Hopefully you have no rust on gear teeth and faces. Those are hard and expensive to replace. The real issue here is not to drive it around with bad or damaged bearings.
Damaged ring and pinion bearings can do far more damage to the mesh and wear of the ring and pinion than even light rust on the faces of the ring and pinion themselves. The spyder gears tolerate no rust specs at all ebcause they will rapidly start wearing the thrust washers....and when those wear that leads to spalling of differential side gears and spyder gears.
ATF does work great because its thinner and a great preservative....but if you do not get every spec of it out of the tranny...it destroys the EP properties of the hypoid gear oil. Just ask anyone who has ever lost the seal between the automatic fluid section of the type 2,3 or 4 automatic tranny...getting as little as 4-6 ounces of tranny fluid into the hypoid gear oil and driving on it. It will literally destroy your ring and pinion in about 100 miles.
You can ONLY use ATF...with an additive package...when you are using the tranny in very cold climates....that do not change. Automatic tranny fluid in warm climates...meaning almost anything sub-artic...does not have the EP properties necessary to support a hypoid or semi-hypoid (which yours is) gearing.
You would need to fully flush this tranny with solvent before putting hypoid oil back in. A mix of the two oils does not hurt bearings, needle bearings or synchros...but it will hurt the final drive ring and pinion. Ray |
Posted: Thu Feb 04, 2010 2:18 am Post subject: |
raygreenwood wrote: |
No...metal filings like that are NOT normal. You should have little or no normal wear on gear faces. The only real wear parts in the tranny....if its running well....are non-magnetic. Those look like what you get when you have destroyed bearing cages. |
Many folks in the far north fill their trannies with ATF every winter and drain it come spring and I don't see them falling apart all that fast.
As for the metal filings that really isn't very much, depending on the number of miles on that oil he doesn't have much in the way of filings at all. |
Posted: Thu Feb 04, 2010 6:47 am Post subject: |
Wildthings wrote: |
Many folks in the far north do indeed use ATF in their trannys....but are you sure they drain them in the spring and refill them with 90 weight...or are you just assuming that they do?
Most places where this is necessary at all.....do not get much warmer than 40F in the summer....and are freezing again at night.
Also...I know for absolute 100% fact....that ATF WILL destroy the EP lubricity of hypoid gear oil. Been there...done that...several times.
This has been a factual ongoing problem for eons on all ACVW automatics and on all front wheel drive combined units. Its why up until just about 10 years ago....it was required to change the seal between the diff section and transfer case at 7 years or 70K miles. Because ....when that seal fails...as little 4-6 ounces of ATF in the hypoid oil will cause violent failure of the ring and pinion in under a 100 miles.
Long before I knew this...I destroyed two units due to seal failure. The second one had less than 6 ounces of overfill in the diff housing.
The only way you can SAFELY use ATF in a hypoid unit...is to drain it in the spring before weather gets above about 35-40F....fill with 90 weight run it for just a few miles at low speed...drain it again...and refill.
Personally I would repeat that one more time just to be sure its absolutely dilluted to the max if you are not going to employ any solvent washing.
ATF is NOT an EP rated fluid. Why do you think they run ATF in the transfer section of automatics...and then go through all the rigamarole to have two seals, two o-rings and a gasket to separate the ATF from the hypoid 90 oil in the differential....if it was ok to use it there?
By the way....in case you are wondering....the type 2,3 and 4 auto box differentials are all virtually the same design....and virtually the same design as any other 4 speed differential. Same parts. So...they have the same lubrication requirments.
The ONLY reason ATF would ever be run in a hypoid differential is when the outside temp is so cold that even the lightest hypoid gear oils turn into a "gel" that will not flow through roller bearing cages....and prevent synchronizers from operating. At that point....which is usually below -30F.....ATF is roughly the consistancy of 90W-140 gear oil. And...it will still require an EP metallic additive like moly to operate.
If you are not in Northern Canada, Alaska or the rocky mountains....it would not be smart to do this.....as a solution to a transmission that already has rust and potential bearing issues. Ray |
Kirk Samba Member
Joined: December 05, 2003 Posts: 5492 Location: North Texas
Posted: Thu Feb 04, 2010 8:23 am Post subject: |
I dont know anything about ATF in transmissions. I would fill it up with GL-4, drive it a while, drain it, and refill it. While driving, feel for anything odd. I think it will be fine. You didnt say, is this thing free, you bought it, you had it, what? _________________ MAKE FORUMS GREAT AGAIN
Bear
Fasty
Super |
Posted: Thu Feb 04, 2010 9:53 am Post subject: |
Also...I know for absolute 100% fact....that ATF WILL destroy the EP lubricity of hypoid gear oil. Been there...done that...several times. |
Gets a lot hotter than that in much of the north country and there is no night for many months so there isn't much in the way of freezing to be had.
ATF will run fine in these boxes, even in much warmer climes. I have run ATF in both 091s and 091-1 that had existing synchronizer problems and were hard to get into gear when running the spec oils. Each of the boxes I have done this to have gotten over 150K miles of additional service, or are still in service. More recently I have gone to running 0W-40 motor oil in lieu of the ATF.
BTW there are GL-4 rated ATF's available these days as well. |
Posted: Thu Feb 04, 2010 11:18 am Post subject: |
If its a Gl-4 rated ATF...thats a gear oil because its EP.
That is also not your average ATF. Different story.
Whats interesting is you saying you run 091's with ATF and getting high miles.
Ok...then what ATF were you running?...because your average Dexron II, IIE and III which is what the average Joe will take away from this conversation... WILL NOT ....safely lubricate any hypoid or semi-hypoid differential when its viscosity drops below that of a standard 90 weight hypoid oil. It flat out is not an EP oil and cannot survive the shear pressure of the gear teeth.
Ok...so if your transmissions do indeed survive on regular type F or Dexron in their differential....in warm weather...then that begs and/or creates the question that gets back to my original point:
At what point does a mixture of both fluids create a problem. It might just be that a mixture of the two causes a severe issue....and not just one or the other exlusively.
But it is 100% widely known and factual....that the addition of small amounts of ATF into hypoid gear oil WILL destroy the differential. Just go down to a transmission shop (especially Audi and VW) and ask how many absolutely smoked differentials they have had to replace due to seal failure in autoboxes. Those diffs are only marginally different than an 091 or a bug. This problem pretty much went away in the mid 90's due to changes in seal design and materials....but it was the absolute scourge of front wheel drive and European combined gearboxes.
Running 0-W 40 as auto tranny fluid is not a great idea either. Why?...because though it performs the hydraulic function perfectly well (a fluid is a fluid in that respect), real dedicated auto tranny fluids must resist oxidization, hydraulic shear thinning and oil film failure at temperatures over 450F in the torque converter (in not so odd cases 550F is common). There are no 0-W 40's that meet the temperature and viscosity control level for automatic transmissions. These are some of the hall marks of automatic transmission fluids and why there are so many specific ones. ATF...does not shear-thin or heat thin in exactly the same manner as motor oil.
If you were speaking of using synthetic 0-W-40 in the differential section....thats actually a better idea than using ATF. Ray |
Posted: Thu Feb 04, 2010 11:38 am Post subject: |
I went ahead and topped up with fresh GL-4 gear oil. It still has a bit of trouble getting into 1st and 2nd, but every other gear is fine. The shifter has felt harder to locate gears since the flood, but I will assume thats due to wonky bushings unless anyone else can chip in. I'm going to run it with this oil for a week then drain it out, and possibly take it down and strip it apart to have a good look at the internals. I'll post more pics if and when I get to that stage.
Thanks again!
zade |
