Crashbox Samba Member
Joined: February 11, 2010 Posts: 41 Location: Germany
Posted: Fri Feb 12, 2010 3:37 am Post subject: Mysterious small nut RGB gear ratio - 17 to 19 teeth |
I've searched the forums and parts catalogues but couldn't find any reference to the small nut tranny stub axles (19 teeth) and matching upper gears (17 teeth) I bought at Hessisch Oldendorf last year. These give a RGB ratio of 1:1,12 as opposed to the common 1:1,39 (18/25 teeth) and 1:1,4 (15/21 teeth) ratios for 55-63 busses.
Any information as to whether this was a factory option would be much appreciated!
[/img] |
thom Samba Member
Joined: October 12, 2000 Posts: 6307 Location: Sacramento
Posted: Fri Feb 12, 2010 7:32 am Post subject: |
Unless I'm missing something, your gears don't match the parts book
_________________ -Thom
1956 Single Cab
1957 Porsche 356A Sunroof
1957 23-Window Deluxe
1963 Unimog 404
1965 E-Type |
Lind Samba Member
Joined: November 06, 2000 Posts: 10272 Location: idaho
Posted: Fri Feb 12, 2010 8:39 am Post subject: |
the shape of those gears is unlike anything I have ever seen inside a reduction box. and I have had in my hands BD reductions, early small nut, late small nut, little big nut, big nut, and alpine gears. they are not listed in any of the dozens of parts lists that I have seen from '55-'70s.
my questions are who machined those, how long did it take, and what harness steel did they use?
how much did they cost? _________________ .
Wanted:
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10804 Location: the past
Posted: Fri Feb 12, 2010 8:42 am Post subject: |
| Lind wrote: |
how much did they cost? |
i agree. i don't think i've ever seen that marking stamped on a gear either (back of upper gear).
the only thing i can think they might be (other than some weird aftermarket or someone making them) is some kind of military Thing gears? |
Clara  Samba Member
Posted: Sat Feb 13, 2010 12:12 am Post subject: |
Who made those? _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
sub-hatchtim Samba Member
Joined: September 19, 2006 Posts: 2694 Location: Phoenix AZ
Posted: Sat Feb 13, 2010 12:32 am Post subject: |
im sorry but im not good at math what does this gear configuration amount to _________________ 58' pg/sg silo fridge westy
58 Dove blue singlecab
76 911S |
Busryder Samba SuperHero
Joined: September 17, 2007 Posts: 1663 Location: In Your Face...
Posted: Sat Feb 13, 2010 12:35 am Post subject: Re: Mysterious small nut RGB gear ratio - 17 to 19 teeth |
| Crashbox wrote: |
That's the best "first post" I think I have ever seen here on TheSamba...
And a stumper too.
Welcome to TheSamba Crashbox. _________________
| Lind wrote: |
| Apparently I was just the lucky asshole that showed up at the right time. |
I am a Dick, hear me roar-
Me, an OVP Lifer... |
Posted: Sat Feb 13, 2010 5:10 am Post subject: |
Thanks for all your replies!
| Quote: |
| my questions are who machined those, how long did it take, and what harness steel did they use? |
I'm afraid I don't know - that's what I'm trying to find out. What I'm quite sure of, however, is that they are not a recent reproduction or aftermarket kit as they show some surface corrosion marks which indicate that they are NOS. Whether the hardness of steel is correct only time will tell, I guess.
| Quote: |
Well, let's say they were not exactly cheap, but I knew right away that they were something special and probably pretty rare.
| Quote: |
| im sorry but im not good at math what does this gear configuration amount to |
Theoretically (rolling resistance, air resistance and lack of engine power left aside) the top speed in each gear should increase by about 25 percent.
I've asked several split bus experts here in Germany and one of them claimed that there was a lower reduction gear ratio option for flat regions and/or busses that never had to carry heavy loads. But if there was such an option, then why isn't it included in the parts catalogues and M-code lists?
| Quote: |
| Welcome to TheSamba Crashbox. |
Thanks, Busryder! It was about time I registered as I had been lurking here anonymously way too long ... _________________ '50 Type 11C
'52 Type 21A
'62 Type 111
'71 Type 23-517, SO 72/3 |
Ojai63dbl Samba Member
Posted: Sat Feb 13, 2010 7:57 am Post subject: somebody interested in reproducing?? |
Nows the times to get the specs measured on those gears.
It sure would be a nice option ot go with that configuration for a RGB box for those of us i nthe flatlands, that want speed but want originality look.
Can we convince you to get the specs drawn up by a machinist and then maybe someone would be interested in a pre purcahse run of these - of course everyone would want to see what the price would be for a set.
Its be interesting to know if they were an option perhaps they were made out of Germany (i.e south africa or australia - true flat landers) |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15469 Location: Casa de Oro, California
Posted: Sat Feb 13, 2010 8:49 am Post subject: |
| My guess is that they were small nut prototypes and the engine couldn't keep up so they never went into production. Now with ga-ga motors they would be a small nutter's nirvana. It's like the Holy Grail of the RGB keepers. |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
krisbeetle Samba Member
Posted: Sun Feb 21, 2010 2:24 pm Post subject: |
| that seems to me like a fairly pricey en-devour for a one off. how much did they cost you? where did the person before you get them from? |
mightymouse Samba Member
Posted: Sun Feb 21, 2010 3:52 pm Post subject: |
I want a set. asap! Need to pull these off, ship them to weddle or ppg and have them copy them. Man thatd be so sick. _________________ Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters. |
Posted: Sun Feb 21, 2010 6:35 pm Post subject: |
| mightymouse wrote: |
I want a set. asap! Need to pull these off, ship them to weddle or ppg and have them copy them. Man thatd be so sick. |
I know, I really want to know the history on these things. |
andreou Samba Member
Posted: Tue Jun 01, 2010 12:45 pm Post subject: |
| They are from a split ambulance. |
Rick Samba Member
Joined: December 17, 2003 Posts: 1539 Location: Soquel, California
Posted: Tue Jun 01, 2010 12:57 pm Post subject: |
| Those look pretty beefy. Am I wrong or do the tips of those gears look thicker than others I've seen? Whenever I see a chipped tooth on an RGB gear it's usually only the tip, and these gears appear thicker. Would be nice... |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 26288 Location: Olympia Wash Rinse & Repeat
Posted: Sun Jan 22, 2017 10:46 am Post subject: Re: Mysterious small nut RGB gear ratio - 17 to 19 teeth |
Found an interesting though a little hard to read thread about Soviet captured examples of KDF Beetles in Russia.
http://www.thesamba.com/vw/forum/viewtopic.php?t=670747
One is a 1945 that has the RGB open:
Looks like similar design. _________________ In Stereo, Where Available! |
