kahala46 Samba Member
Joined: April 16, 2007 Posts: 221 Location: Mesa Arizona
Posted: Tue Mar 17, 2009 4:26 pm Post subject: Spark plug access window |
Has any one cut a window in the rear wheel well to access the spark plugs and make changeing the plugs easer when you are running dual carbs.If you have a pic it would help.Thank you |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79600 Location: Sneaking up behind you
Posted: Tue Mar 17, 2009 4:31 pm Post subject: |
Thank you Glenn butI was thinking of something a little bigger so you could access the manafold nuts and take them off as well. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16803 Location: State College, PA
Posted: Tue Mar 17, 2009 4:41 pm Post subject: |
I am so glad you posted that again - Was trying to find it the other day because I need to do the same thing on my project. Thanks! _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
nobuggybob Samba Member
Joined: October 31, 2008 Posts: 415 Location: Monument Co.
Posted: Tue Mar 17, 2009 4:45 pm Post subject: |
For the guys that just drill holes for your jets and adj. screws,What do you plug the holes with when not in use? _________________ You Can't Quit Poverty
Posted: Tue Mar 17, 2009 5:05 pm Post subject: |
[quote="nobuggybob"]What do you plug the holes with when not in use?[/qu I plan to use nut inserts and and screw a plate over the hole with some kind of rubber backing to keep the H2O out ote] |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33135 Location: Hot Arizona
Posted: Tue Mar 17, 2009 5:30 pm Post subject: |
I cut an access panel maybe 6 x 10 inches in my 1970 sedan, to access #3 and #4 spark plugs, which were behind/under the AC compressor. I used a piece of sheet metal to seal that, with a hex head screw at each end to hold it. Maybe I can take and post a photo this weekend, PM me Friday. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
Posted: Tue Mar 17, 2009 6:43 pm Post subject: |
nobuggybob wrote: |
For the guys that just drill holes for your jets and adj. screws,What do you plug the holes with when not in use? |
I have no problem getting to the intake manifold nuts.
_________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Hotrodvw Samba Member
Posted: Tue Mar 17, 2009 9:07 pm Post subject: |
Can ya see them winder's in there????
_________________ '67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings |
Cusser Samba Member
HerrrKafer Samba Member
Joined: June 02, 2004 Posts: 1465 Location: East Fishkill, NY
marekv8 Samba Member
Joined: January 24, 2006 Posts: 276 Location: Louisiana
Posted: Wed Mar 18, 2009 6:30 am Post subject: |
I'm running the HiPacs from the previous post and they're extremely well made. All the Hooky's Panel Shop bits are great.
Posted: Thu Mar 19, 2009 10:42 am Post subject: |
Thank you all for all your posts. please keep the pics and ideas comming Rob |
hemifalcon Samba Member
Joined: June 15, 2005 Posts: 1483 Location: Union Grove, WI
Posted: Sat Feb 13, 2010 8:38 am Post subject: |
I don't need to do this, although it may make things easier. Removing those covers is one extra headache. I can get my carbs and all off without doing some cutting of the car. I have to use a similar setup with my ratchet, and different connections, but I can get the job done with dual Dell 40's installed. It's a bit of a pain, but I don't see how this really makes it any easier in the end. _________________ '62 VW Bug Sedan (Ruby Red)
Resto pics> http://smg.photobucket.com/albums/v697/hemifalcon/Bug%20resto/?start=all&paginator=top |
Posted: Sat Feb 13, 2010 8:42 am Post subject: |
It does make it easier to change plugs, get to manifold nuts, etc......BUT, IMO I wouldn't cut the car if it isn't already. Mine were done when i bought it. _________________ '67 Sunroof
Eric
lots of money!
Hose & Fittings |
