Vsyevolod Samba Member
Posted: Thu Feb 25, 2010 10:23 pm Post subject: Bostig conversion, Charcoal cannister. Anybody done this? |
I'm just finishing up my Bostig conversion. I know that the TEC shop in Seattle has a 5 page PDF on hooking up the charcoal cannister to capture/recycle the gas fumes. Has anyone succeeded in doing this? The TEC shop PDF is rather vague.
TIA,
Stephen
climberjohn Samba Member
Joined: January 11, 2005 Posts: 1840 Location: Portland Orygun
Posted: Thu Feb 25, 2010 10:47 pm Post subject: |
Does the Bostig conversion require that the charcoal cannister be moved from the stock location?
-CJ _________________ '86 Westy, 2.5 Subaru power
Know your limits. Exceed them often. |
Posted: Thu Feb 25, 2010 10:49 pm Post subject: |
No, the Bostig conversion currently ignores the whole thing. The TEC shop actually does something about it. I don't know enough to understand the why's and wherefore's so I was asking the esteemed community at large here. I'm guessing that it's not so much a big deal if Bostig can comfortably ignore it.
Stephen
thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Fri Feb 26, 2010 12:46 am Post subject: |
I'll give you a little perspective.
the 2.2 subaru conversion uses the vanagon coalcan as well. the 5/8" bottom tube goes to the intake upstream of the throttle body and pcv. The white 6mm hard plastic line goes to the intake manifold for vacuum. [I tapped a 1/4" npt taper thread with an 1/4" icemaker ferrule into it and slipped the 6mm inside the 1/4" for a nice tight fit. the top 5/8 hose goes to the vanagon vacuum valve. the purple 4mm hard plastic goes to the throttle body small black rubber vacuum line system, teeing in.
https://www.thesamba.com/vw/gallery/pix/642456.jpg
see the vac valve in the right corner and the white plastic line on the right.
the purple line is visible in the foreground crossing the silver manifold.
the black hose at the bacl on the intake periscope is the bottom charcoal hose.
todd |
Posted: Fri Feb 26, 2010 1:22 am Post subject: |
So part of my question is: Can the two hard plastic tubes safely be ignored?
Another part of my question is trying to clear up some of the vagaries of the whole system that the cannister functions within. Go easy on me. Use small words...
Stephen
Posted: Fri Feb 26, 2010 8:36 am Post subject: |
The charcoal cannister is part of your emissions control system. It prevents gas vapors from going into the atmosphere, a significant source of air pollution. There is quite a lot written about it here. Tencent, as always, has posted some useful info. Try a search on <charcoal AND cannister>, and check these posts to get started:
Fuel Tank Vacuum
http://www.thesamba.com/vw/forum/viewtopic.php?t=391727
EVAP system circumvention go or no go?
http://www.thesamba.com/vw/forum/viewtopic.php?t=222942
PS - Could you post a link to the vwtechshop .pdf file you mentioned? I'd be very curious to read this, as I am having issues with my cannister as well (a loud "bonk" sound from the gas tank.)
xo,
Vanagon Nut Samba Member
Joined: February 08, 2008 Posts: 10497 Location: Sunshine Coast B.C.
Posted: Fri Feb 26, 2010 11:52 am Post subject: |
| Vsyevolod wrote: |
On my Jetta swap one item I had to learn about was the charcoal canister purge valve.
There should be something similar on your Zetec engine.
Is it connected? Or did the Bostig guys figure out a way to use the stock WBX valve?
Here's what I learned about an electrically controlled purge valve
pulses open/closed via signals from ECU (engine computer)
If failed/failing, when engine run up to temp, shut-down, restarted, valve might have allowed fuel vapours to build up in intake (during shut-down) possibly causing a hard start due to rich mixture. May also cause issues at idle.
My Jetta purge valve ('93 OBD1) is simpler. The Focus one looks more complex. Don't know what other connections are for. Maybe Bostig forums would tell all?
Maybe yours looks like this?
2000-2004 Ford Focus Motorcraft CX1754 Vapor Canister Purge Solenoid:
_________________ 1981 Westy DIY 15º ABA
(VW Gas I4)
1988 Westy DIY 50º ABA
VE7TBN |
Williamtaylor33 Samba Member
Joined: September 07, 2007 Posts: 1545 Location: Arkansas
Posted: Fri Feb 26, 2010 12:02 pm Post subject: |
I havent done it. But if you want to connect the charcoal canister i think you can extend the vaccum hoses from the canister to one of the nipples on the intake.
You know....the ones that are usually broke off when you get your engine from the yard... Bostig supplies some rubber block offs for these. _________________ 89 Bostig powered syncro westy |
Posted: Fri Feb 26, 2010 12:27 pm Post subject: |
You have to be a member of the Bostig Core Google Group to view this file. As this question is directed (in part) to people who might have already done this mod, here is the link.
http://bostig-core.googlegroups.com/web/EVAP_BOSTI...F-vtiGpWAA
If you aren't a member of this group, PM me with your email address and I can send you a copy.
Stephen
Posted: Fri Feb 26, 2010 12:54 pm Post subject: |
| Vanagon Nut wrote: |
| Vsyevolod wrote: |
It's my understanding that the Bostig set-up uses an ECU that did not originate with the OEM Ford. I hesitate to say that it is not an OEM computer because I understand it is a Delphi based system and Delphi does supply OEM ECUs to the OEMs, so...
Anyway, the point is that if this is the case, the Bostig ECU most likely has not been written to operate the OEM Evap Purge Valve. This means that it would be best to simply hook up the original charcoal canister just the way VW did it with the stock filter valve in place to determine when to purge the canister via the vacuum signal. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Fri Feb 26, 2010 1:25 pm Post subject: |
| loogy wrote: |
| Vsyevolod wrote: |
Anyway, the point is that if this is the case, the Bostig ECU most likely has not been written to operate the OEM Evap Purge Valve. This means that it would be best to simply hook up the original charcoal canister just the way VW did it with the stock filter valve in place to determine when to purge the canister via the vacuum signal. |
Hey Loogy. Interesting. Makes total sense. And a lot more efficient that using a dummy Ford valve to trick ECU. If that's even possible.
I assume Bostig found a way to interface the stock WBX purge valve to the Zetec TB or other vacuum source. If'n I'm understanding all this correctly. They sure must have done a lot of R&D on their swap! But I digress....
Hopefully the OP has found the solution.
(VW Gas I4)
VE7TBN |
Posted: Fri Feb 26, 2010 1:31 pm Post subject: |
Great, I'm starting to get a better sense of the whats and whyfors about this charcoal cannister stuff. (Thanks guys for all the internal and external links to reading material. I'd like to hook it all up, though have yet to find any simple instructions. Where exactly do I hook up the thin nylon lavender and white lines coming from the cannister that used to hook up somewhere to my 2.1 engine? Special parts needed? What are the specs on the nylon line as I'll need to pick up some more (mine was cut). Any pics available?
Stephen
Posted: Fri Feb 26, 2010 1:35 pm Post subject: |
| Williamtaylor33 wrote: |
You know....the ones that are usually broke off when you get your engine from the yard... Bostig supplies some rubber block offs for these. |
That's what I thought as well. But I've looked at two conversions that just came back from the TEC shop that leave the vacuum nipples untouched. They were both Syncros, does that make a difference?
Stephen
Posted: Fri Feb 26, 2010 1:42 pm Post subject: |
There should be something similar on your Zetec engine. |
I don't think the Bostig gang does anything like this. I don't see a Focus purge valve anywhere.
| Quote: |
| Is it connected? Or did the Bostig guys figure out a way to use the stock WBX valve? |
I don't think it's connected. The WBX doesn't use an electronically controlled purge valve (I think), they use an old-skool one.
| Quote: |
Nothing like this on my crate Focus engine...
Stephen
Posted: Fri Feb 26, 2010 1:49 pm Post subject: |
| loogy wrote: |
| ...This means that it would be best to simply hook up the original charcoal canister just the way VW did it with the stock filter valve in place to determine when to purge the canister via the vacuum signal. |
Yes, so far this sounds like the direction I'd like to go. I'm still stumped as to how that looks out there in the real world. Has anyone with a Bostig done this yet? Pictures? I don't get any help from Bostig themselves as they don't deal with it (if I'm understanding them correctly, which I might not be).
Thanks for all the help so far gang, halfway there...
Stephen
Posted: Fri Feb 26, 2010 6:35 pm Post subject: |
Okay, this is what Bostig recommends me to do...
Take the nylon vacuum line coming out of the Charcoal Filter Valve and feed it back into itself. I'm doing this for now, though it seems like it would be nice for the gas vapour to reenter the fuel area and get recycled somehow. Is it possible that no Bostig converts reading this have done anything with their gas vapour lines?
I do realize that somehow one of the lines is supposed to enter the air line close to the throttle body and the other line is supposed to get hooked up to a vacuum line. Just don't have a clue how or where to do this.
Thanks everybody so far,
Stephen
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10147 Location: Abiquiu, NM, USA
Posted: Sat Feb 27, 2010 9:36 am Post subject: |
I guess that's Jim's idea of a joke. At least I think it's pretty funny.
You ought to set this system up to work instead of sidelining it like that. In order to work with the standard control valve, though, there has to be a throttle vacuum nipple on the engine's throttle body. That means a nipple where there is no vac at idle, but vac comes on as soon as the throttle tips in. It will be on the TB directly in line with the plane of the butterfly when closed. If there is no such thing on the Zetec TB then it will be harder to make work, but not impossible.
Once you find the throttle-vac nipple, connect the top of the EEC control valve to there. Connect the bottom fitting of the valve to intake manifold anywhere after the TB.
Before bothering with that, though, you should test the other parts of the system.
First test the tank venting system: remove the small fuel tank vent line from the top of the canister. Attach a piece of hose to it so you can blow into it, or better yet use a vacuum pump/gauge. Remove the fuel filler cap. You should be able to blow or suck air thru the vent line, or using the vac pump you should not be able to pull a vac on that line with the filler cap removed. With the filler cap replaced, you should not be able to blow air thru it, or using the vac pump you should be able to draw down some vac on it.
Then test the canister: fit your test hose to the open nipple on top of the canister where the vent line attached. You should be able to blow or suck air thru the canister. If you can't the canister is blocked and you'll need to replace it.
Replace the tank venting line to the top of the canister.
To test the control valve it really helps to have a vac pump/gauge. Connect it to the fitting on the top of the valve. Attach a hose to the bottom fitting. Try to suck air thru the bottom hose; you should not be able to. Now apply vacuum to the top fitting; as soon as you do, the valve should open and you can now suck air thru the valve from the bottom line.
If all that checks out, plumb the two vac lines as I described above and it will work. No, you won't notice any difference in how the engine runs one way or another. _________________ Shop for unique and useful Vanagon accessories at the Vanistan shop:
Experience is death to doctrine. |
Posted: Sat Feb 27, 2010 10:54 am Post subject: |
| tencentlife wrote: |
Once you find the throttle-vac nipple, connect the top of the EEC control valve to there. Connect the bottom fitting of the valve to intake manifold anywhere after the TB. |
I just wanted add that the "top" fitting will be the smaller of the two and there is usually a purple hose going to it. Obviously the "bottom" nipple is the larger one and the hose coming from it is usually white.
And just to clarify the operation of the valve, at idle, the valve should be closed and no vacuum should drawing on the "top" hose. When the throttle is tipped in, a vacuum signal is formed on the top hose which opens the valve and allows the vacuum in the intake manifold to draw the vapors out of the canister into the intake tract via the bottom hose on the valve. The valve basically creates a controlled vacuum leak that is used to evacuate the charcoal canister.
I'm not familiar at all with the Zetec throttle body, so unless someone else know for sure which nipple can be used, you will have to experiment using a vacuum gauge and a piece of hose. _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Posted: Sat Feb 27, 2010 12:41 pm Post subject: |
| Vsyevolod wrote: |
| Quote: |
| Quote: |
Stephen
Ah. A crate. Nice. I was thinking from POV of getting engine etc from a donor car. Sorry about suggesting purge valve was on engine. Seems on a Focus, purge valve is on firewall. But that's all moot. You're dealing with the Vanagon EVAP system and from Loogys post, it seems that Bostig has adapted whatever ECU they're using so that the Ford purge valve won't be missed. Still, you need something.
For sure. The WBX is vacuum type.
Yup. On the firewall. (upper LH)
(VW Gas I4)
VE7TBN |
sanfordphoto Samba Member
Posted: Fri Mar 26, 2010 11:59 pm Post subject: |
Hey Stephen, did you ever get this figured out? I'm in the middle of my conversion and should be bolting up my tranny and Zetec Saturday.
Thanks, Sanford
| Vsyevolod wrote: |
| loogy wrote: |
Stephen
