High Output Alternator Subagon. External Voltage regulator
Honuak
Honuak is offline
PostPosted: Tue Mar 16, 2010 3:10 am    Post subject: High Output Alternator Subagon. External Voltage regulator Reply with quote
I'm all over Samba like a rash....
Ok all you electrical gurus, I am putting my electircal system together on my westy and I'm in way over my head as usual. I am using a battery isolator (Yandina 160) and a high output (140 AMP) alternator on my Subie 2.5. I'm fairly sure the alternator has a built in voltage regulator but a boat guy I know thinks an external voltage regulator is a good idea. I am going to be running an inverter, isotherm 12 fridge, amplifier, stereo, powered sub, coffee grinder...etc. My plan is to get separate house and starting batteries. A decent marine grade voltage regulator is big bucks. Anyone have thougths on this one?
Cheers
Honuak
presslab
presslab is offline
PostPosted: Tue Mar 16, 2010 7:29 am    Post subject: Reply with quote
I shoehorned a CS144 large case Delco alternator onto my EJ22. It has a 200A stator and an overdrive pulley. I'm just using the stock Delco (internal) regulator, it works fine. As long as you have a large wire going to the aux batt (I have 1/0 AWG) there won't be a significant voltage drop so the internal regulator is fine.
1986 Vanagon Westfalia EJ25
1988 Subaru GL-10 EJ20G --- 2000 Honda XR650L
2010 Titus El Guapo --- 2011 On-One 456 Ti
Honuak
Honuak is offline
PostPosted: Tue Mar 16, 2010 8:11 am    Post subject: Reply with quote
Thanks. Great news....
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Mar 16, 2010 9:42 am    Post subject: Reply with quote
What is the magic to make that fine piece of hardware fit?
(Somewhere I recall seeing something to the effect: A post with out pictures is not worth a ....... I normally think content is the best, but in this case a picture or two would really help to see just how shoe horned in it is. PLEASE?)
TIA,
Walt...
presslab
presslab is offline
PostPosted: Tue Mar 16, 2010 2:44 pm    Post subject: Reply with quote
TIA,
Walt...
Sorry for the hijack Honuak.
Honuak
Honuak is offline
PostPosted: Tue Mar 16, 2010 7:22 pm    Post subject: Hijack away Reply with quote
Thats frikkin sweet! Do you need to put a little extra tension on the belt for the higher output?
presslab
presslab is offline
PostPosted: Tue Mar 16, 2010 7:32 pm    Post subject: Re: Hijack away Reply with quote
Thanks! Oh yes, the tension is pretty tight! Or else, squeeeeeeal...
I read on alternatorparts.com (where I bought the stator, diodes, etc.) that having too loose of a belt will cause it to slip and heat things up. Eventually the heat will burn up the front bearing in the alternator. So I keep it tight - no problems so far, I'd had this alternator on there for a couple years.
r39o
Samba Polizei
r39o is offline
PostPosted: Tue Mar 16, 2010 7:49 pm    Post subject: Reply with quote
OK this is going to get "sticky." Can you illuminate all the stuff that has to happen to put one in, please? Are those brackets modified stock or a kit? It is just too sweet. I want my house golf cart batteries to be kept happy!
VisPacem
VisPacem is offline
PostPosted: Tue Mar 16, 2010 9:33 pm    Post subject: Reply with quote
Hi , could you indicate *which* CS144 you used. I found this site with a dozen or so CS144 for various applications.
http://www.alternatorparts.com/category_cs144.html
Just in case, that, was my solution
http://www.maniacelectricmotors.com/hiou135ampal.html
LG aka VisPacemPB, *The* party Pooper
No Regrets (Nothing to do with Vanagons)
Rhinoculips
Rhinoculips is offline
PostPosted: Tue Mar 16, 2010 10:33 pm    Post subject: Reply with quote
Did you run a second (4 gauge) wire from alternator to battery, as they suggested?
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
targis58
targis58 is offline
PostPosted: Tue Mar 16, 2010 11:47 pm    Post subject: Reply with quote
Is this going to be a solution to the battery indicating light coming on on dash in a westy with freezer?
90 westy 2wd w/ TBD
VisPacem
VisPacem is offline
PostPosted: Wed Mar 17, 2010 1:53 am    Post subject: Reply with quote
I did not and everything so far so good. However I will do just that. I am not certain I am getting full benefit of this alternator and I am also concerned with overloading my present wiring.
Yes I should Smile
VisPacem
VisPacem is offline
PostPosted: Wed Mar 17, 2010 1:54 am    Post subject: Reply with quote
I would not know I sold my Westy long long time ago...
Rhinoculips
PostPosted: Wed Mar 17, 2010 6:53 am    Post subject: Reply with quote
No. The solution to fix the light problem is behind the fuse panel and the relay. Visit the subaruvanagon yahoo group. There is a write up on how to do it there.
Click to view image
presslab
presslab is offline
PostPosted: Wed Mar 17, 2010 8:31 am    Post subject: Reply with quote
My alternator was from a Camero, and is the "six-twelve mount" style. I got that on eBay. Here are the parts I purchased from alternatorparts.com:
241257 5-groove pulley.
41010782 200 amp heavy duty stator.
DR5180PF Transpo rectifier.
D1C120 Wiring repair harness.
I measured 111A at idle and 190A at speed. Goodyear 4050340 belt.
The brackets are custom made. The aluminum bracket for the PS pump and stock alternator was modified by cutting off the stock alternator mount. The pics show the parts I made - the slotted adjuster bracket and the two adapter brackets on the AC compressor side. The slotted part has a little offset in it at the bottom.
This mod could be reversed with a new PS pump aluminum bracket.
For the wiring I basically hooked the L (lamp) lead through a 470 ohm 1/2W resistor to switched 12V from the stock alternator wiring. This resistor is located in the harness. I also hooked the L lead to the alternator lamp so the dash lamp works. The reason I needed the resistor is because the Vanagon alternator lamp does not draw enough current to get the alternator going.
