jed81 Samba Member
Joined: March 24, 2010 Posts: 10 Location: huntington beach
Posted: Wed Mar 24, 2010 10:27 pm Post subject: brake booster problems 71 vw bus |
| I have a 71 vw bus. I recently put a rebuilt brake booster as well as new vacuum lines and a master cylinder.I used the strongest vacuum lines i could find for them. my problem now is everytime i start my bus the brakes lock up and I cant even move. I am new to VWs please help!!! |
Desertbusman Samba Member
Posted: Wed Mar 24, 2010 10:46 pm Post subject: |
New to VW's and have you gotten the service manual yet? You need it for the work you did plus any other tasks you do. And aalso welcome to the Samba. But offhand it sounds like the pushrod from the brake arm to the booster might be way out of adjustment. _________________ 71 Superbug
71 Westy |
jed81 Samba Member
Posted: Wed Mar 24, 2010 10:58 pm Post subject: |
| i have 2 books. Ive been reading the hell out of em when i work on my bus but, they dont say much about the booster. from reading other posts i was thinking it was the same thing. |
VDubTech Samba Member
Joined: December 29, 2002 Posts: 9157 Location: Syracuse, NY
Posted: Wed Mar 24, 2010 11:22 pm Post subject: |
| jed81 wrote: |
| i have 2 books. |
If one of them doesn't say "Bentley" on the front of it, you aren't done buying manuals yet. That's the only one that counts. _________________ First Trip in the RustyBus:
http://www.thesamba.com/vw/forum/viewtopic.php?t=279077&highlight=
| borninabus wrote: |
| a measurement of your rod would be extremely useful. |
| notchboy wrote: |
| my dad wasnt a belittling cock when he tought me how to wrench on cars. |
| EverettB wrote: |
One photo = good for reference.
10 photos = douchebaggery |
Posted: Wed Mar 24, 2010 11:25 pm Post subject: |
You might have books that arn't specifically for Bay window busses. Such as the How to Keep your VW Alive book by Muir. That one just has sort of general information for all VWs and little specific for late busses. It's more of a general get aquainted laugh at the pictures type of book. The Bentley service manual for '68-'79 busses (the green one) is the one you need. The adjustable pushrod should not be exerting pressure on the booster when the pedal is fully retracted. That's probably your problem but get the right manual because there are other things involved. BTW, congrats on a '71. That's the good one. _________________ 71 Superbug
71 Westy |
Posted: Thu Mar 25, 2010 12:00 am Post subject: |
| As others have said the push rod between the master and booster is probably adjusted incorrectly. Dirt in the master or lines can also act as a check valve causing the brakes to lock up, as can old internally failing brake hoses. |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17784 Location: San Diego, California
Posted: Thu Mar 25, 2010 10:22 am Post subject: |
Well you've done some of the work to rebuild your brake system but you still might have either bad front calipers which can freeze and lock the wheels as well as you might have bad rubber brake lines that have failed internally not allowing the brake pressure to return and the calipers to release. Let me ask you this... if you jacked the front off the ground, would the front wheels spin? Then, if you started the bus would they lock up or do they only lock up after you hit the brakes once? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
jed81 Samba Member
Posted: Thu Mar 25, 2010 2:32 pm Post subject: |
| They lock up imediatly when starting the bus. the brake pedal also pulls to the floor on its own with out touching it. If i pull the check valve and block the vacuum line going to the booster i get some brakes witout using the booster at all |
germansupplyscott Samba Member
Posted: Thu Mar 25, 2010 2:41 pm Post subject: |
is the one-way valve installed? _________________ SL |
Posted: Thu Mar 25, 2010 3:35 pm Post subject: |
you do have the vacuum line connected correctly to the BACK side of the booster drum, right? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
jed81 Samba Member
Posted: Thu Mar 25, 2010 4:56 pm Post subject: |
| Everything is hooked up propoerly as far as vacuum lines. the check valve is the same thing as the oneway valve. |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53256 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Thu Mar 25, 2010 5:31 pm Post subject: |
OK so the next thing to check is pedal freeplay (pushrod adjustment), when you push the pedal gently with a single finger is there a little tiny bit of movement before the load changes?
If there is indeed a tiny bit of play the only thing left is the booster, crap in the atmosphere valve will activate it even with no pedal application, send it to HR or find another working used one. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jed81 Samba Member
Posted: Thu Mar 25, 2010 6:30 pm Post subject: |
I dont know if this helps out at all, but i put new brake pads up front, shoes and wheel cylinders(brazilian) in the back, new mastercylinder (brazilian). USED brake booster) and all new vacuum lines. the bus was sitting for 23 years prior to my ownership. been a long proccess with the restoration but this is my final step.
IS THE PUSHROD THE ROD THAT CONECTS THE BRAKE PEDAL TO THE BOOSTER? |
Posted: Thu Mar 25, 2010 6:36 pm Post subject: |
A pad change could cause this, but it would only matter if the brakes didn't change if the engine was running or not, if Aeromech's test with spinning the wheels running or shut off exposes different circumstances the booster is likely to blame. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
jed81 Samba Member
Posted: Thu Mar 25, 2010 7:37 pm Post subject: |
Like i said earlyer if i bypass the booster by turning the check valve backwards, or pluging the vacuum line out of the mannifold the brakes stop somewhat, just off of the master cylinder with no booster. no locking of the brakes or anything. brakes lock up only when the check valve is the right dirrection and vacuum is going to the booster.
Probably bad booster in your best opinion? |
Posted: Thu Mar 25, 2010 8:14 pm Post subject: |
From what you have said it doesn't seem like it could be anything other than pushrod adjustment problem or bad booster.
Since you have done all the other brake system work go thru it all again once you get the service manual to refer to. _________________ 71 Superbug
71 Westy |
Posted: Thu Mar 25, 2010 8:21 pm Post subject: |
| I have heard of these symptoms for a bad booster. Some orifice must get plugged, or something, that keeps the boost on full even with no pedal effort. |
jed81 Samba Member
Posted: Thu Mar 25, 2010 9:29 pm Post subject: |
Only one way to find out if the booster is bad. tommorow im gonna buy a rebuilt one and return the used one i bought to the vw dissmantling yard i got it from and start over with a new fresh rebuilt booster.
Ill let you all know how it goes. Thankyou everyone for all the help.
THIS WEBSITE IS GREAT!!!!! |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Mar 26, 2010 6:44 am Post subject: |
| jed81 wrote: |
You might should check with this place first. They may be able to repair the booster you got from the wrecking yard cheaper than you can return it and find another from other vendor's.
H & R Automotive Parts
10328 Oakwood Dr
Dallas, TX 75217
972-286-5516 |
Jody '71 Samba Member
Joined: July 16, 2005 Posts: 2842 Location: Manassas VA
Posted: Fri Mar 26, 2010 7:19 am Post subject: |
Could it be the air connection on the front of the booster is clogged up? _________________ '66 Beetle
2011 Hyundai Elantra Touring |
