VW emblem
vwbrewer
vwbrewer is offline
PostPosted: Tue Mar 30, 2010 4:16 am    Post subject: VW emblem Reply with quote
Do you guys put anything between the VW emblem and the top of the hood?
1957 Oval Rag
RareAir
RareAir is offline
PostPosted: Tue Mar 30, 2010 4:40 pm    Post subject: Reply with quote
No. But Volkswagen put some sort of gummie residue on the backside of the hood where the emblem tabs are bent over to help seal the luggage area
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
D. Haviland
D. Haviland is offline
PostPosted: Tue Mar 30, 2010 7:36 pm    Post subject: Reply with quote
My 57 has the little gobs of gum and my 52 zwitter has the little round discs with the sawtooth pattern like split runningboard material and the buffer stuff under the back seat. Don't know when they stopped with the discs.
Dave
RareAir
RareAir is offline
PostPosted: Tue Mar 30, 2010 9:08 pm    Post subject: Reply with quote
Like this:
Part #113853611
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
D. Haviland
PostPosted: Wed Mar 31, 2010 6:52 am    Post subject: Reply with quote
Those would be the ones.
billmetric
billmetric is offline
PostPosted: Thu Apr 01, 2010 8:11 am    Post subject: Reply with quote
here is a factory untouched hood emblem from a '54, the little rubber circles have white putty under them, it is still soft after over 50 years, this is what they looked like, if you make it look any nicer you are doing it wrong Wink
There is an idea of a Billmetric; some kind of abstraction. But there is no real me: only an entity, something illusory. And though I can hide my cold gaze, and you can shake my hand and feel flesh gripping yours and maybe you can even sense our lifestyles are probably comparable... I simply am not there...
schunacher
schunacher is offline
PostPosted: Thu Apr 01, 2010 10:34 am    Post subject: Reply with quote
billmetric wrote:
... if you make it look any nicer you are doing it wrong Wink
So you mean powder coated dipsticks and 8 layer laquer jack handles are wrong too? Laughing
stale air
stale air is offline
PostPosted: Thu Apr 01, 2010 10:49 am    Post subject: Reply with quote
RareAir wrote:
Like this:
Part #113853611
Those are also the same ones they use on the hood crest. Smile
johnshenry
johnshenry is offline
PostPosted: Thu Apr 01, 2010 11:09 am    Post subject: Reply with quote
For the putty, you can use a bit of gum eraser, available at craft/art stores.
John Henry
'57 Deluxe
'56 Single Cab
stale air
PostPosted: Thu Apr 01, 2010 11:23 am    Post subject: Reply with quote
This is what we use here at work, 3M strip calk, aka dumb dumb.
johnshenry
PostPosted: Thu Apr 01, 2010 12:08 pm    Post subject: Reply with quote
Good stuff too.....!
John Henry
'57 Deluxe
'56 Single Cab
D. Haviland
PostPosted: Fri Apr 02, 2010 7:04 pm    Post subject: Reply with quote
Like this:
Part #113853611[/quote]
Those are also the same ones they use on the hood crest. Smile[/quote]
Yes. The hood crest too. There are repros. Mine were NOS.
D. Haviland
PostPosted: Fri Apr 02, 2010 7:05 pm    Post subject: Reply with quote
Like this:
modelac
modelac is offline
PostPosted: Sat Jan 08, 2011 4:30 pm    Post subject: Reply with quote
What is the correct way of bending the tabs on the emblem? Since my hood was missing the emblem, I am not sure how to complete this.
drscope
drscope is offline
PostPosted: Sat Jan 08, 2011 10:16 pm    Post subject: Reply with quote
Any body shop supply house will have a product called Dum Dum for this purpose.
It works better then the above mentioned rubber seals.
Chuck Fryer
Chuck Fryer is offline
PostPosted: Sat Jan 15, 2011 12:23 am    Post subject: Reply with quote
Just use a pinch of the dumb dumb on each post from below.
