Alternator / Idiot light NOT lighting up!
brice
brice is offline
PostPosted: Mon Mar 29, 2010 5:21 pm    Post subject: Alternator / Idiot light NOT lighting up! Reply with quote
Summary: idiot light lights up when connected to ground, does NOT light up when connected to D+ post of alternator. blown alt?
My generator light is *not lighting* up when I turn the key -- and I know that both the oil pressure + gen light are supposed to come on, and the alternator will not send a charge if the idiot light is dysfunctional... Once I had a battery die because I forgot to hookup the blue "idiot wire" after changing the speedo cable!
I have a 1974 SB with a newer Bosch AL82 internally regulated alternator. When I installed it a few years back I removed the old external regulator, and spliced the green (alternator D+ wire) to the blue (idiot light wire) to accomodate for the internal regulated alternator (according to schematic here: http://www.thesamba.com/vw/forum/viewtopic.php?t=383271&highlight=idiot+light) The car has been a more or less reliable daily driver for 4+ years...
Here's what I've done:
1. I opened the engine and removed speedometer from dash so I can access.
2. I removed green/red oil pressure light wire from bulb (known working) and hooked the blue idiot wire to it -- still no light.
3. I ran a long wire directly from the D+ post of the alternator to the idiot light -- still no light.
4. I touched the end of this direct wire to the ground on the alternator -- it LIT UP.
So; the idiot builb lights up when connected to ground, and does NOT light up when connected to the D+ post of the alternator. Does this indicate a blown alternator? Any fix?
Many thanks as ever!
lytnbug
lytnbug is offline
PostPosted: Mon Mar 29, 2010 5:29 pm    Post subject: Reply with quote
Which idiot light wire are touching to ground? I guess you know that one side of the bulb that is NOT the blue wire SHOULD be grounded. The blue wire is what causes it to come on with + volts from alternator/regulator circuit.
'73 Fat Super Beetle
'78 Super 'Vert
'62 Std. Beetle
brice
brice is offline
PostPosted: Mon Mar 29, 2010 7:08 pm    Post subject: Reply with quote
The engine compartment end of the blue wire. Basically I ran a wire from the D+ post of the alternator to the GEN ("idiot") light to take the [above mentioned] splice out of the equation.
When the engine compartment end of this wire is on the D+ post (as it was hooked up for a long time while the car was working), the GEN light does not turn on. It does light up when the the engine compartment end is removed from the D+ post and connected to the alternator ground/case.
I am trying to get both my GEN and OIL lights to light up when the ignition is turned on, but the engine not running.
lytnbug
lytnbug is offline
PostPosted: Mon Mar 29, 2010 7:32 pm    Post subject: Reply with quote
First off, I got that all screwed up & backwards. I have to come back at this tomorrow. The ground actually has to come through the alternator/reg end... just opposite of what I had said. Sorry
'78 Super 'Vert
'62 Std. Beetle
lytnbug
lytnbug is offline
PostPosted: Tue Mar 30, 2010 5:23 am    Post subject: Reply with quote
Lets try this again. The idiot light gets the (now missing) ground through the regulator in the alternator. Not 100% sure if it goes through the brushes to ground or that side circuit, since I cannot see the internals of the regulator. Though this schematic is for an external regulator, I believe the only difference is that you would have to picture the regulator to the left of the D+ connection.
So, also, the reason you have to have a functioning idiot light circuit is that that is where the alternator gets its field voltage. Looks like you need to pull the alternator and have it tested. Whatever the cause, I'm 99% sure it's the alternator. Sad Hope I helped more than I confused. I apologize for the mis-information of last night.
'78 Super 'Vert
'62 Std. Beetle
lytnbug
lytnbug is offline
PostPosted: Tue Mar 30, 2010 5:48 am    Post subject: Reply with quote
I never stop. Ha. I found some more info and the path for the idiot light should go through the regulator AND the field coil. So, it could something as simple as bad brush(es).
'78 Super 'Vert
'62 Std. Beetle
brice
brice is offline
PostPosted: Tue Mar 30, 2010 2:08 pm    Post subject: Reply with quote
lytnbug,
Thank you very much for helping with this problem! Pulling the alternator is a pain, but I guess something I need to do if necessary. Do you know if it's possible to pull out the brushes / internal regulator without removing the alternator? It is a new (@ 4 year old) Bosch AL82N.
Many thanks!
~ Brice
lytnbug
lytnbug is offline
PostPosted: Tue Mar 30, 2010 3:51 pm    Post subject: Reply with quote
The brushes should be under the plate where the D+ plugs.
Not sure on the regulator. If it is like a domestic, it is usually mounted inside on one of the end plates for heat dissipation.
'78 Super 'Vert
'62 Std. Beetle
lytnbug
lytnbug is offline
PostPosted: Tue Mar 30, 2010 4:04 pm    Post subject: Reply with quote
I was looking at a picture of the brushes on partsgeek and they look to be a PITA to get to with the alternator installed and intact. But at least they sell these things. http://www.partsgeek.com/gbproducts/WC/17324-01023...oogle+Base Usually can't find these at regular VW parts outlets/stores.
'78 Super 'Vert
'62 Std. Beetle
lytnbug
lytnbug is offline
PostPosted: Tue Mar 30, 2010 4:19 pm    Post subject: Reply with quote
Wow, I'm finding parts I didn't know existed (I have an alternator in the attic that just needs brushes). Anyway, I went out to RockAuto.com and they sell regulators & brushes. They differ somewhat, depending on what the alternator # is. But I found one picture that shows the regulator to be part of an assembly that holds the brushes.
I randomly chose a 1976 Beetle, which has the internal reg, and this one is only $11+ dollars, if you choose the wholesaler closeout (limited supply). Hope I'm not wearing this all out, but I keep finding this stuff. Very Happy
'78 Super 'Vert
'62 Std. Beetle
brice
brice is offline
PostPosted: Thu Apr 01, 2010 8:40 pm    Post subject: Reply with quote
Thanks so much for the info. I went ahead and pulled the brush holder which has the D+ post on top. Here's what I found;
The brush holder has springs which push the brushes down onto revolving metal in the alternator (I assume this is what generates/transfers voltage). 2 wires inside the alternator attach to the brush holder -- a red and a blue -- seen here:
When I touch the GEN/"idiot light" wire [that normally connects to the D+ post] to the BLUE wire in the alternator, it lights up. It also lights up if it touches ground [anywhere on the alternator case]. It does NOT light up if I touch it against the red wire in the alternator OR any of metal that the brushes rub against.
I made sure all connections were good and pressed the D+ "brush holder" (pictured below) back into its spot on the alternator. Still to GEN light.
I began to experiment & noticed that the GEN light comes on when the D+ post "brush holder" is rocked slightly towards you (so that the side towards the front of the car is up). I hear a clicking when it gets into this position, as if the [front?] brush spring engages or is lifted off the metal.
Is this "brush holder" (yes, I know it's the wrong word?) bad -- or maybe the regulator? It doesn't seem that this piece is doing the regulating -- and I don't seem to be able to get to the [internal] regulator (where I assume the red + blue wires are attaching).
Many thanks for your input! Here's pics of my "brush holder";
lytnbug
lytnbug is offline
PostPosted: Fri Apr 02, 2010 8:46 pm    Post subject: Reply with quote
One possibility, and I had this happen to one of my alternators, is that the brushes get worn down so far that they don't make good contact with the commutator rings. I would sure try replacing the brushes first, especially since we know where you can buy them. If it were the regulator, rocking the assembly would not have the affect that it does.
'78 Super 'Vert
'62 Std. Beetle
brice
brice is offline
PostPosted: Mon Apr 05, 2010 12:28 pm    Post subject: Reply with quote
Lytnbug,
I'll try buying brushes for this & replacing. Thanks for the advice! It's strange, as this is only 4 years old, and I've heard that alternator brushes supposedly have 100,000+ mileage in their life (I've *maybe* put on 30?)
Interesting point. My guess is that the rear-brush may be making better contact when I rock it forward... that or something else (the metal clip?) is touching ground on the alternator casing.
lytnbug
lytnbug is offline
PostPosted: Mon Apr 05, 2010 1:37 pm    Post subject: Reply with quote
brice wrote:
Lytnbug,
You have a point. Those 2 wires should be to and from the regulator; one hooking to the bottom side of the D+ terminal and the other hooking to the other spade on that assembly. So the latter one follows to that brush, to the ring, through the coils, back to the other ring, to the other brush, and from there you SHOULD have a GROUND source. I can't see how/where it is grounded in the pictures. But likely, it runs to one of the mounting screws for that plate. Maybe, concentrate on that area (?).
'78 Super 'Vert
'62 Std. Beetle
brice
brice is offline
PostPosted: Tue Apr 06, 2010 6:04 pm    Post subject: Reply with quote
The mounting screws appear to only anchor the plastic brush holder in place. I don't see any wire or path connected to them that would give the circuit ground. My fear is that something is blown in the interior regulator (which I cannot get to w/o taking the alternator apart)?? I am guessing that the blue & red wires that attach to the brushes go there?
Do my brushes look very worn down? I couldn't find anything at rockauto.com that resembled them. Does anyone else have photos of theirs (Bosch AL82N)?
Thanks!
lytnbug
lytnbug is offline
PostPosted: Wed Apr 07, 2010 6:50 am    Post subject: Reply with quote
Thanks!
I may have my assumptions wrong on the path, but if I follow the circuit example one of the brushes should have a ground source from its top (opposite end from the ring). Yes, the other piece of the assumption is that the red and blue wires go to-and-from the regulator. So the regulator is always a possibility. If a person was real careful and could put things back together, all wired internally and everything, and include a little jumper at the brush block between the red and blue wire ends; if the regulator is the culprit, your light should come on in this scenario. But if you are uncomfortable with that, don't risk smoking something.
re: Brushes
I can't tell by looking in the photos. If you were in the Rockauto.com catalog, under Volkswagen, select 1976, Beetle, and then Electrical, the second item is Alternator Brushes with pix. There are 4 of them listed.
However, in the 3rd photo you provided, there appears to be a piece of metal on the left side of the picture. I am wondering if that is what is to make contact with metal ground.
'78 Super 'Vert
'62 Std. Beetle
brice
brice is offline
PostPosted: Wed Apr 07, 2010 7:23 am    Post subject: Reply with quote
lyntnbug,
I somehow stumbled across this post last night:
http://www.thesamba.com/vw/forum/viewtopic.php?p=4506592
It strongly suggests that it's an Internal Regulator. The author was kind enough to point to where he bought his ($14.95 at autohaus AZ).
I'm going to re-examine the brush holder to make sure all solder points are intact. There's a metal clip that sticks out of the brush holder & contacts a thin piece of metal on the alternator case... but touching the idiot light D+ wire to its contact point does not light it up / give it ground? That seems to be the only feasible point. I'll supply more pics when I get back.
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Wed Aug 06, 2014 9:06 pm    Post subject: Reply with quote
Curious if you got the issue resolved, and what fixed it.
Four years later...
Popcorn
Robert in Memphis
Engine rebuild thread
