Exterior 'Party' Lights?
Page: 1, 2, 3  Next
Scary Mc
Scary Mc is offline
PostPosted: Sat Apr 24, 2010 10:33 am    Post subject: Exterior 'Party' Lights? Reply with quote
Does anyone know of a source for exterior rope/tiki lights that I can plug into the 12-v power outlet and hang from my vans awning?
I've searched to no avail.....
syncrodoka
syncrodoka is offline
PostPosted: Sat Apr 24, 2010 10:47 am    Post subject: Reply with quote
Try looking at those RV stores. Good luck
pioneer1
pioneer1 is offline
PostPosted: Sat Apr 24, 2010 1:09 pm    Post subject: lights Reply with quote
Hey: regular xmas lights (l.e.d probably best) will plug into an inverter to make your van standout,attract mating subjects,guide ufo's,etc. Wink
"Always waiting for tomorrow ruined everything"
'85 Porsche 911 Targa
'76 Westfalia project
ohlott
ohlott is offline
PostPosted: Sat Apr 24, 2010 1:17 pm    Post subject: Reply with quote
I bought some of these they work pretty well.
http://cgi.ebay.com/ICE-FISHING-12-VOLT-battery-po...2eac80379d
83.5 westy 2.2 subi
Williamtaylor33
Williamtaylor33 is offline
PostPosted: Sat Apr 24, 2010 1:22 pm    Post subject: Reply with quote
Look up the lighting that Rocky Mountain Westy sells.
89 Bostig powered syncro westy
attydog
attydog is offline
PostPosted: Tue Apr 27, 2010 10:42 am    Post subject: Reply with quote
check out this web site. I haven't used them, but it looks like what you might need.
www.superbrightleds.com
joetiger Premium Member
joetiger is offline
PostPosted: Tue Apr 27, 2010 11:22 am    Post subject: Reply with quote
This thread
http://www.thesamba.com/vw/forum/viewtopic.php?t=408332&highlight=camping+lights
has some good ideas. I just ordered a set of these, thanks to a post from the aforementioned thread:
http://www.christmas-light-source.com/12-Volt-LED-Light-Set-Warm-White-Green-Wire_p_1566.html
They plug into a cigarette lighter outlet. I'll report back when they arrive and I get a chance to use them.
Joe T.
'02 Baja-ish Beetle "Bubbles"
PDXWesty
PDXWesty is offline
PostPosted: Tue Apr 27, 2010 11:38 am    Post subject: Reply with quote
Amazon has some interesting ones. Smile
http://www.amazon.com/gp/search/ref=sr_nr_i_1?rh=i...1272392694
Here's some christmas style 12v lights.
http://www.imaginarycolours.com/Merchant2/merchant.mvc?Screen=CTGY&Category_Code=12vStrings
Search for "12 volt string lights" on the web and a lot comes up.
89 Westy 2.1 Auto
kevinbassplayer
kevinbassplayer is offline
PostPosted: Tue Apr 27, 2010 4:26 pm    Post subject: Reply with quote
Google up "World Aglow", I buy all my Burning Man lighting from them, lot's of 12 Volt stuff
kenmag
kenmag is offline
PostPosted: Tue Apr 27, 2010 4:43 pm    Post subject: Reply with quote
We just used off-the-shelf LED christmas lights plugged into an inverter. Very little power draw... No UFO's took notice though Wink
87GL Westy/suby ej22
87GL tintop/suby ej22
05 Golf TDI
95 jetta GLX
joetiger is offline
PostPosted: Wed May 19, 2010 8:31 am    Post subject: Reply with quote
These came in last week; very fast shipping:
They give off a yellowish glow and are pretty bright. They appear to be well-made and the plug actually fits well in the original accessory outlet under the passenger's seat (the one on all Wolfsburg Westies.) I've had problems plugging in a few other accessories, namely phone chargers and and inverter, due to that outlet being more shallow than the one on the dash.
I bought two sets. Each set comes with a 15-foot removable extension before the lighted part begins. They're set up so that you can use one extension and run multiple lines of lights plugged in together in series.
I haven't used them anywhere other than my driveway yet, but at this point, they appear to be a good purchase. After I've beaten them to death over the summer, I'll let y'all know if they're still standing.
Joe T.
Orbitald
Orbitald is offline
PostPosted: Wed May 19, 2010 9:31 am    Post subject: Reply with quote
I installed LED Christmas lights in my van a bit ago. Here is what I did.
I used warm white C6 LED string lights like these:
http://spectrumsuperstore.com/browse.ihtml?pid=744502&step=5&prodstoreid=9363
These strings lights come with a removable 12V DC cigarette lighter adapter. By removing the adapter you can plug them together end-to-end to form a longer string and using the cig adapter on the last string to power them all.
I made magnetic holders which can be moved around if need be but are strong enough to syncro around Hollister:
The clips are for LED rope lights and they are epoxied to a magnet:
Clips:
http://www.orangetreetrade.com/shop/2-wire-3/8%22/38heavy-duty-mounting-clips-screws-p-371.html
Magnets are 1/2" x 1/8" x 1/4" Ring where the hole is 1/8" and I got mine off ebay from magnet4us (you might need to special order them but mine were 20pcs for $10 plus $7.50sh):
The screws are just there so the epoxy has something to grab onto.
The magnetic clips grab the C6 LED lights nicely and are strong enough to mount in many, but not all, areas of the ceiling and any other ferrous materials:
I also used a 12V dimmer:
Kick KR6 dimmer these guys:
http://www.kicklighting.com/PWM-dimmer-switch-for-LED.htm
Mounted in the ashtray space:
I have about three strings which use between 6-362ma (4.34W max) from most dim to fully on.
I like that this system does not screw into the van itself and that they are not only movable but I can add on another string or two outside by just plugging them in. Hope that gives others some ideas.
'87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing
snowesty
snowesty is offline
PostPosted: Wed May 19, 2010 3:12 pm    Post subject: Reply with quote
I just purchased (literally 20 min. ago) 60 cool white led's, set up as a stand alone solar unit. Can be used anywhere, and moved around easily. $25 from home hardware no less! Should be just the thing, I'm going to set it all up with magnetic mounts, so it can go all over the interior, or stuck to the outside of the van as well.....
and no, I did'n steal the magnet idea from the previous post. I have EVERYTHING on magnets! Nothing you can't do with hot glue and magnets... Surprised
pics to come....
Fritz - '86 Syncro Tintop, Camper interior
Toaster - '91 Multivan Westy, 4sp.
DAIZEE
DAIZEE is offline
PostPosted: Wed May 19, 2010 3:56 pm    Post subject: Reply with quote
I had an 84 Westy Wolfsburg but I didn't have a 2nd 12V outlet. Interesting.
'09 2.5L Jetta 5 cylinder, 5 spd, super turbo, see thread in H2O Cooled Jetta, etc...
84 Vanagon GL Wolfsburg Westy WBX 4 speed (sold)
Orbitald
Orbitald is offline
PostPosted: Thu Jun 24, 2010 5:12 pm    Post subject: Reply with quote
I don't think these light clips are UV rated as they have all broken in less than a month. I'm looking for nylon replacements.
Timwhy
Timwhy is offline
PostPosted: Thu Jun 24, 2010 5:58 pm    Post subject: Reply with quote
The wife bought me two strings of the 12v christmas LED's for fathers day and they work great!!
I got a chance to try them out this week and though you wouldn't read
by them the certainly gave off enough light to brighten the campsite.
'15 Audi A3 Quattro
'09 VW Tiguan (dead)
'87 VW Westy
'91 Tin Top
'90 Cabby
populuxe59
populuxe59 is offline
PostPosted: Thu Jun 24, 2010 6:23 pm    Post subject: Reply with quote
What would happen if you plug the household LED string lights directly into a 12 volt socket? Or regular incandescents? I have a few strings but my wife won't like it if I clip the AC plug off for experimentation.
kenmag
kenmag is offline
PostPosted: Thu Jun 24, 2010 6:27 pm    Post subject: Reply with quote
You probably need the 12V inverted to 120V for the household lights to work.
05 Golf TDI
95 jetta GLX
populuxe59
PostPosted: Thu Jun 24, 2010 6:50 pm    Post subject: Reply with quote
I just tried a 12 volt jumper pack with some test leads. It won't light a normal 50 light set at all, and an 8-light tiki set just barely glows(both incandescent). I forgot about the shunts in the bulbs as well if that matters.
I won't even dream of going into the garage attic and looking for a string of LED's. I think they would have resistors wired in. I'd like to take a look but they are stored away. 12 vDC should be plenty to get a string of them going.
VanWilder
VanWilder is offline
PostPosted: Thu Jun 24, 2010 10:21 pm    Post subject: Reply with quote
Party what?
Ikea $19.99
VW
________________________
"83.5" Vanagon GL Air cooled "VanWilder"
VanWilder has given back to me more then I could ever put into it September 22, 2010
Malama Ka `Aina—"Respect the Land"
Page: 1, 2, 3  Next
