25hp barrels and pistons....
RichOakley
RichOakley is offline
PostPosted: Tue May 11, 2010 11:35 am    Post subject: 25hp barrels and pistons.... Reply with quote
I need some advice please!
I have stripped down my '47 engine and the barrels are worn beyond the specified tolerances. My options are as follows:
1. Find a set of good, used pre-1949 25bhp barrels. Difficult!
2. Find a set of good, used 1949-53 25bhp barrels. Easier, but they won't look 100% correct.
3. A couple of people have mentioned to me that you can use watercooled pistons from (I assume) am 1100cc VW Polo/Audi 50/Golf/Rabbit, which are slightly oversize and will require the original cylinders to be bored out.
I guess my questions are as follows:
a) does anybody have a decent set of pre-1949 barrels (preferably in Europe due to cost and time!!)? Or failing that, a good or NOS set of 49-53 barrels?
b) perhaps more interestingly, has anybody had experience with fitting watercooled pistons to these early barrels? If so, which parts were used? Would any extra work be required on the piston skirts where the gudgeon pin fits through, or would anything else need to be considered such as raised/decreased compression?
I'm half tempted to start stripping down the engine in my wife's '77 Polo, but seeing as it's her daily driver, she would not be overly happy.
johnshenry
johnshenry is offline
PostPosted: Tue May 11, 2010 12:24 pm    Post subject: Reply with quote
Not sure I can help you Rich, but what is the difference between the early and late(r) 25hp cylinders? Is it the fin design? Are the early ones the kind where the studs don't go through complete holes in the fins, rather cutouts? I might have 1 or 2 of those early ones.
You wouldn't be able to see them with the engine tin on anyway, right? (I know, but you wouldn't sleep well....)
John Henry
'57 Deluxe
'56 Single Cab
Richard Hartel
Richard Hartel is offline
PostPosted: Tue May 11, 2010 12:36 pm    Post subject: Reply with quote
You have the early cast iron kdf style cylinders like I do. You can bore them .10 over and get a set of over size pistons and then get the oversize rings from Grant Piston Rings in Anahiem California for not much and retain the look but boost your hp to maybe 27hp!!
RichOakley
PostPosted: Tue May 11, 2010 12:51 pm    Post subject: Reply with quote
Correct John, those are the ones, just like kdf ones. Damn these early cars!! Twisted Evil
RichOakley
PostPosted: Tue May 11, 2010 12:52 pm    Post subject: Reply with quote
Thanks Richard, but where would you get the oversized pistons from?
52HoffmanSplit
52HoffmanSplit is offline
PostPosted: Tue May 11, 2010 1:37 pm    Post subject: Reply with quote
Here is what looks like a nice set that are 1 over and are the early style. Many of the OE Makers still used this "Open fin style" all the way to 1952 and beyond... Good Price Too!!
http://www.thesamba.com/vw/classifieds/detail.php?id=960498
Stick some oversize Deves rings on these and I will wager you are in business.
DB
11/1966 Porsche 912
7/1968 Type 265 Double Cab
4/1955 Type 117 - 3 Fold
RichOakley
PostPosted: Tue May 11, 2010 1:44 pm    Post subject: Reply with quote
Well spotted, thanks! Have enquired.
RareAir
RareAir is offline
PostPosted: Tue May 11, 2010 5:10 pm    Post subject: Reply with quote
You've got a PM Wink
1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241
[email protected]
jmp@ncounty.net is offline
PostPosted: Tue May 11, 2010 11:25 pm    Post subject: Reply with quote
My 47's og engine was running for years with 36 hp pistons in the org bored out cyliners. I talked the man that onced owned my 47 form the early 50's up into the early 70's. He is now in his 90's and remebers the car well. He told me that he bored out the jugs and ran it that way for years up to the time he sold it still running.
RichOakley
PostPosted: Wed May 12, 2010 12:20 am    Post subject: Reply with quote
Hi. No PM received. I can be emailed at: richardoakley1(AT)btconnect.com
Thanks,
Rich.
RichOakley
PostPosted: Wed May 12, 2010 12:22 am    Post subject: Reply with quote
Thanks- another idea!
Was the previous owner who you spoke to Paul Norman or the owner before him?
oval56
oval56 is offline
PostPosted: Wed May 12, 2010 3:53 am    Post subject: Reply with quote
how thich is the cylinder at the botom ( outer diameter?)
if the have 80mm outside normaly machine it to 77mm 30hp pistons ond ready...old barels kept, improvement on the torque and power Laughing the start of vintage speed Wink
www.oval56.com
1956 Oval, 2364ccm typ4
1957 Oval Ragtop 1584ccm singel port modified
1950 Hebmüller, 1584ccm okrasa modified
DBK Germany!!!!!!!!!!
www.dbkvw.com
RichOakley
PostPosted: Wed May 12, 2010 8:49 am    Post subject: Reply with quote
Gentlemen.
Thank you all for your help and advice. I have been lucky today and have found a complete set of NOS barrels and pistons just down the road from where I live. Very convenient! So that's now sorted out.
One other question....
The old cylinders off the engine were worn excessively in a horizonal direction with far less wear in a vertical plane. To me, this would point at a worn crank/main bearings, but there is absolutely no end float in the crank whatsoever. I can only assume that these 'worn' cylinders must have been taken off another well-used engine at some point.
Does anybody have any other thoughts on this horizonal 'wear' issue?
virtanen
virtanen is offline
PostPosted: Wed May 12, 2010 9:28 am    Post subject: Reply with quote
My proposal: twisted connecting rods. 25hp rods are twisted very easily if piston pins removed wrongly, VW has a tool to measure and straighten them.
RichOakley
PostPosted: Wed May 12, 2010 9:40 am    Post subject: Reply with quote
Interesting thought Mika, although all four cylinders seem to have suffered the same amount of wear and I would guess that it's unlikely that all 4 con-rods have been damaged in the same way.
rod_vw
rod_vw is offline
PostPosted: Fri May 14, 2010 1:04 pm    Post subject: Reply with quote
For anyone looking for genuine 2nd oversize rings I have the following...
Piston Ring Set for 25bhp 1131cc
Part number SP109A (111 198 255) 2nd oversize for 76mm bore
These are New In Box comprising...
4 x 111 107 309 Piston ring, upper
4 x 111 107 319A Piston ring, lower (narrow face contact)
4 x 111 107 329 Scraper ring
£25 plus shipping.
Rod,
Please visit http://www.historicvws.org.uk
https://www.facebook.com/historicvwclub/
1946 Beetle (Back on the road after over 50 years! Last major outing - Hessisch Oldendorf 2022)
LWB MAN TGE Camper.
splitjunkie
splitjunkie is offline
PostPosted: Fri May 14, 2010 1:59 pm    Post subject: Reply with quote
How bad is the wear?
Crank flex will cause the wear you describe.
Chris
kiwisteve
kiwisteve is offline
PostPosted: Mon May 17, 2010 4:32 am    Post subject: Reply with quote
Rich, sounds like you need to talk to Ian C at WPS about all things engine related! nothing like an oldie to throw you a few curve balls!
