thummmper Samba Member
Joined: November 25, 2009 Posts: 2015 Location: Meadow Valley, California Republic
Posted: Wed May 19, 2010 4:16 pm Post subject: |
mike at gwr is right about water conductivity and mineral content.
I used to wash trucks and rinse them with deionized water. the sensor that reports purity works exactly opposite to the burp tank water sensor.
if I ran absolutely pure water from a process similar to what sparklets deems too pure,[ adding minerals back in to add taste,] would the coolant level sensor work at all? It would fail to sense conductivity
hypothetically, that is, without the antifreeze solution added.
maybe the antifreeze has conducive properties... a built-in irony?
I have clouded the subject further. all I know is that older vans had rotten steel pipes. the pvc pipes crack eventually. would it be cool to get a magnesium coating inside the ss tubes?
impractical but different. that's how I roll |
240Gordy Samba Member
Joined: May 15, 2008 Posts: 2354 Location: Vancouver, BC
Posted: Wed May 19, 2010 4:35 pm Post subject: |
| thummmper wrote: |
yes, the coolant must be conductive for the coolant sensor to work. _________________ Tencentlife said,
"So, now that you know what you're doing, go to town."
2010 GOLF TRENDLINE 2.5
1985 GL now with more! a 2.1L
H&R SPORT(RED) Springs FRONT , SLAM SPECIALTIES RE6 AIRBAGS REAR |
rotaecho Samba Member
Posted: Thu Dec 25, 2014 10:40 pm Post subject: 1982 Diesel Stainless Coolant Pipes? |
I'm looking to upgrade my 1982 1.6na diesel Westy engine to a 1.9na.
However, I need to upgrade the radiator first, and I was thinking I might as well update the coolant lines at the same time. I'm leaning towards Stainless Steel, just because it's more durable for protection against elements hitting the line from underneath.
I've looking at RMW, BD, VC, GoWesty, and TK's websites regarding pipes to use on the 82 diesel.
Only BD mentions fitting a 82/83 diesel pipes with reference part: 251121397FPR
http://www.busdepot.com/251121397fpr
The single pipes sound more appealing since there's no center leak spot, but I'm not seeing compatible mention of those with he 82. I'm hoping to avoid removal of the gas tank.
Thanks for any insight to any others with a 82 diesel with an upgraded radiator. I'd love to hear what / how you decided to do on your 82 diesel.
Thanks! _________________ -Will
1982 Westfalia mTDI (50deg) aka Betsy Bertha
http://www.tdivanagons.com |
Terry Kay Banned
Posted: Fri Dec 26, 2014 10:39 am Post subject: |
The biggest issue here is the shipping costs of the continuous length pipes, plus with the two piece you can install the tubes without completely dropping the tank.
The slice in the middle of the two piece pipes in my application is only 1/16th" wide, so the danger of losing the splice connection is real small.
Especially if you chose to use the silicone splice hoses.
You'd have a heck of a time shaking that connection loose. _________________ T.K. |
insyncro Banned
Posted: Fri Dec 26, 2014 11:01 am Post subject: |
I have lost count of the total number of stainless and aluminium pipes I have installed.
Not one set has had any issues at the center junction when properly tightened band clamps are used and Loctite 518 was used to seal the mating surfaces. |
Terry Kay Banned
Posted: Fri Dec 26, 2014 4:02 pm Post subject: |
The silicone hose splices are very much like Chinese finger handcuffs.
Once they are on, it's real difficult to work them loose, compounded by the bead roll, I haven't had any reason to seal this area with anything.
Pretty much a bullet proof union.
Perhaps with the plain old rubber hose union the loctite sealer would be a good idea. _________________ T.K. |
Tomasz Samba Member
Joined: September 08, 2005 Posts: 1097 Location: in a van down by the river
Posted: Fri Dec 26, 2014 5:54 pm Post subject: Re: 1982 Diesel Stainless Coolant Pipes? |
For ease of fit (and installation) go with two piece construction over the one piece, which being made out of steel does not have any flex/give and unless manufactured perfectly to match replacement pipes while installed (not likely) will not fit in exact spots/brackets.
| rotaecho wrote: |
Thanks! |
_________________ '56 - Wolfsburg Kombi (1200)
'74 - Type 181 (1600)
'85 - Westy Mosaik Joker Hightop (1.6 TD)
'87 - 16" Syncro High Top (1.9 TD)
'88 - Westy (EJ25)
'14 - Jetta Sportswagen (2.0 TDI) |
insyncro Banned
Posted: Sat Dec 27, 2014 7:47 am Post subject: |
TK, I prefer the silicone unions.
I use silicone in many different locations now, cooling system, intake and vacuum lines.
I like your description of the finger trap, they really do hold on tight when sized properly.
I use the Loctite 518 as it will allow the hoses to be spun during installation to get them seated just right and it creates an excellent seal for added protection, just incase the clamps loosen a tad. |
Terry Kay Banned
Posted: Sat Dec 27, 2014 9:00 am Post subject: |
Makes sense for that tad of extra gripation --no fouls on this being careful move.
"A Little Dab Will Do Ya"
The silicone hoses are plenty tight though---I can't see them wiggling loose on at the most a 16th inch gap--
Yea they could leak if a guy didn't tighten the clamps down. _________________ T.K. |
kalispell365 Samba Member
Posted: Sat Dec 27, 2014 3:51 pm Post subject: Re: 1982 Diesel Stainless Coolant Pipes? |
| Tomasz wrote: |
I have to say, Terry sells pipes that actually fit in the mounting brackets properly, I don't think anyone else who makes them is as accurate...this is why I chose his, they fit correct and exact.
Great product Terry! _________________ 1983 Diesel Vanagon Westfalia chassis with Subaru 2.2l |
GMByers Samba Member
Joined: December 07, 2008 Posts: 642 Location: Retired in NW PA
Posted: Sat Dec 27, 2014 6:31 pm Post subject: |
I have a TK 2 piece stainless kit we bought a few years ago. Installed by a local garage in Pennsylvania while I was living in Texas. The original wire holders were reused with no issues. Oh and as expected, no leaks. _________________ And then there were two...downsized to 83 Doka &
74 Thing.
Terry Kay Banned
Posted: Sat Dec 27, 2014 9:06 pm Post subject: |
Thanks guys for the thumbs up on the fit.
I take the original pipes and make pretty sure the duplicates are as close as possible so they will fit back into the hangers.
I don't know where or how the other pipes are made that the other purveyors are selling so they won't fit as was mentioned in a prior post.
That seems pretty strange to me, you would think they should fit. _________________ T.K. |
insyncro Banned
Posted: Sat Dec 27, 2014 10:46 pm Post subject: |
TKs are very close to an exact copy.
I have been able to get "other" vendors pipes to fit into the the factory metal clips, BUT the middle junctions do not line up perfectly and put pressure on the silicone junctions.
One of the "others" also labels the pipes wrong so if you dont know better you will be trying to get them to fit in the wrong orientation. |
BlueNorthWesty Samba Member
Joined: October 24, 2014 Posts: 348 Location: Calgary
Posted: Mon Dec 29, 2014 9:03 pm Post subject: |
I recently started a rebuild of an '84 Camper and removed my old steel pipes last week.
They were in great shape on the inside, but rusty on the outside from where they entered the engine bay to about 1/3 the total length of the pipes:
If I had known how good the steel ones were I might have reconsidered the stainless purchase. However I ordered the SS pipes months ago with the Subaru conversion kit from RMW. They fit very well and will be a good compliment to the new engine. I have to fabricate a couple of hangars but that's easy stuff.
I'm not concerned about interaction between dissimilar metals. I understand the concept, but the effect of adding these pipes has not been proven to cause adverse effects in the Vanagon. Poor grounding is more likely to cause corrosion and premature head gasket failure than the composition of the coolant pipes. |
