Gauge mounts
62dcw
62dcw is offline
PostPosted: Wed Jun 16, 2010 4:28 pm    Post subject: Gauge mounts Reply with quote
After Chico builds my 1835 motor, I like to install a tach, oil pressure and oil temp. guage on my 62' Bug. Are there any dash mounts for these? Where do you guys mount your gauges?
Randy in Maine
Randy in Maine is offline
PostPosted: Wed Jun 16, 2010 5:43 pm    Post subject: Reply with quote
Been here?
http://www.aircooled.net/new-bin/viewproductdetail.php?keyword2=ISD0016&cartid=0613201087740651
http://www.egauges.com/vdo_acce.asp?Subgroup=VW_Beetle_Panel
oldskoolbug
oldskoolbug is offline
PostPosted: Wed Jun 16, 2010 5:44 pm    Post subject: Re: Gauge mounts Reply with quote
I mounted a 5" tach w/ shift light on the radio block off plate using a custom billet bracket. As for the oil pressure and temperature gauges, those I mounted on a center console along with my cd player. Works for me! Smile
P.S. never mind the spring attached to the gas pedal! Smile I was having some issues with my linkage return springs, and thats the only thing I could wip up to get me on the road. lol
62dcw
62dcw is offline
PostPosted: Thu Jun 17, 2010 4:23 am    Post subject: gauge mounts Reply with quote
I know this may sound dumb, but after you mount the gauges. How are you routing the wires to the gauges from the engine compartment? I've never hooked up guages before?
Ragman
The Sambinator
Ragman is offline
PostPosted: Thu Jun 17, 2010 8:01 am    Post subject: Re: gauge mounts Reply with quote
I run them under the carpet, under the backseat, through the battery cable/starter cable hole into the engine bay.
Hotrodvw
Hotrodvw is offline
PostPosted: Thu Jun 17, 2010 9:29 am    Post subject: Reply with quote
Fast-Fab tach mount:
Custom gauge pod made by a fellow member here on the Samba:
'67 Sunroof
Eric
78x94 with IDA's....oober fun
Horsepower is an addiction........Addictions cost
lots of money!
Hose & Fittings
donmurray
donmurray is offline
PostPosted: Thu Jun 17, 2010 9:47 am    Post subject: Reply with quote
I mounted 3 gauges in the dash slot that did house a radio receiver. Cut an aluminum plate to cover the receiver slot and attached it to the dash with 8 small brass machine screws. Gauge holes in the alum plate were cut using a hole saw. Looks pretty good and didn't make a big mess of the dash. Installed two more gauges centered just under the dash using a standard gauge mount. All gauges were 2 1/8" Dakota Digital. Tach, CHT, oil pres, oil temp, volts.
Except for the CHT, all wires were run under the drivers side door sill cover next to the original front to rear wiring. Have to remove the drivers side back pack panel to get them pulled through. CHT gauge wire is not supposed to be closer than 12" to any wire carrying current, so it is routed through the firewall near #3 cylinder, along the lower inside of the firewall over to the passenger side. Then forward under the passenger side door sill cover and then up under carpet through a hole near the gauge.
74 Ghia, with 2110 engine
62dcw
62dcw is offline
PostPosted: Thu Jun 17, 2010 5:37 pm    Post subject: Gauge Mounts Reply with quote
Hotrodvw, Do you know who made the custom mounts under the dash and how to get a hold of them? It looks like most of you run your gauge wires under the carpet and door sills once it leaves the engine compartment. What gauge of wire do you use?
donmurray
PostPosted: Thu Jun 17, 2010 6:04 pm    Post subject: Reply with quote
I considered mounting mine on a tunnel mounted console, but decided the viewing angle and distance was not right for old eyes.
neil68
neil68 is offline
PostPosted: Thu Jun 17, 2010 7:28 pm    Post subject: guage mounts... Reply with quote
I have oil temp & oil pressure gauges installed to the right of the speedo, using an aftermarket gauge panel.
Also, have a tach mounted under the ashtray. All gauges, mounts and senders are VDO.
Neil.
Der Kleiner Rennwagens
‘68 Beetle 2332 cc, 204 WHP
12.5 seconds @ 108 mph
Dynojet Test: https://www.youtube.com/watch?v=M9B_H3eklAo
marekv8
marekv8 is offline
PostPosted: Thu Jun 17, 2010 8:22 pm    Post subject: Reply with quote
Had these machined from aluminum in order to countersink the gauge bezels. Started with a wide variety of modern and vintage VDO gauges and had North Hollywood Speedometer reface them cohesively to appear relatively stock.
Hotrodvw
Hotrodvw is offline
PostPosted: Thu Jun 17, 2010 10:39 pm    Post subject: Re: Gauge Mounts Reply with quote
Kiwi (Dylan Worsley) makes them. Here's a pic of mine in his ad. Hit him up! He made my breather box too! His craftsmanship is very nice, and you can't beat the price for a custom gauge pod.
http://www.thesamba.com/vw/classifieds/detail.php?id=889144
'67 Sunroof
Eric
lots of money!
Hose & Fittings
Jordan16
Jordan16 is offline
PostPosted: Sun Jun 22, 2014 11:15 am    Post subject: Reply with quote
In my 71 I have a pod that fits 2 dials and placed it up side down and attached it under the glovebox. Smile
1971 1300 beetle
57 Rag
57 Rag is offline
PostPosted: Sun Jun 22, 2014 11:48 am    Post subject: Reply with quote
Got the same one Hotrod has from Dylan. Real nice and solid piece. Mounted mine dead center under dash above shifter. Looks great. Gotta get a pic up.
57 Ragtop
84x94 86C
IDAs
W1K1
W1K1 is offline
PostPosted: Sun Jun 22, 2014 4:24 pm    Post subject: Reply with quote
I have a plate sandwiched under the rear view mirror for my mini monster tach
http://www.thesamba.com/vw/archives/manuals/jim_martin_engine_build.php
1973 super
1965 squareback 1500E
1971 bay window westy- subi swap
smkn_vw
smkn_vw is offline
PostPosted: Sun Jun 22, 2014 5:27 pm    Post subject: Reply with quote
I run wires through the ceiling/roof cavity past the interior light using fish tape to pull it through. I left a pull string inside incase I need to pull more wires. Gauges down below are harder to read but I chose not to cut this one up. My tach is held down to the steering column by a home made bracket and those stainless steel hose clamps you see everywhere. Tach is not very stable when you punch it but acceptable.
"So didja?" -Bob Hoover
madmack
madmack is offline
PostPosted: Sun Jun 22, 2014 7:07 pm    Post subject: Reply with quote
I went with a AirKewld Column mount and a north hollywood 5000 RPM tach " also comes in 6000 and 8000 RPM"
1972 Tintop Westfalia 2.0 091
1966 Bahama Blue Type 1 2017
SgtSamy wrote:
Drive slow and enjoy the ride, what is the hurry, we all reach the same destination at the end. Laughing
Volkswagens are not just a vehicle to drive. Its hobby to love and invest time into.
A work of art has no importance whatever to society. It is only important to the individual.
Vladimir Nabokov
esde
esde is offline
PostPosted: Sun Jun 22, 2014 9:12 pm    Post subject: Reply with quote
terrible pic, but you get the idea..
Anvil
Anvil is offline
PostPosted: Sun Jun 22, 2014 10:22 pm    Post subject: Reply with quote
Went with a Porsche theme here:
A man with any character at all must have enemies and places he is not welcome—in the end we are not only defined by our friends, but those aligned against us.
Jordan16
Jordan16 is offline
PostPosted: Mon Jun 23, 2014 3:10 am    Post subject: Reply with quote
These are the dials I have under the dash, there an oil pressure and oil temperature. I only have the power and earth connected at the moment. The pod isn't the best it's dipped carbon fibre.
There are a couple more in the gallery
1971 1300 beetle
