Dauntae Samba Member
Joined: June 16, 2007 Posts: 11 Location: British Columbia
Posted: Sat Jun 19, 2010 9:05 pm Post subject: Westy: Rear seat won't unlatch |
I have a 1989 Westfalia camper and after returning from a recent camping trip, I now cannot open the latch to get access to the storage compartment under the rear bench seat. Something is preventing the exterior pull handle from coming out far enough to release the hook in the storage compartment.
Any suggestions as to what has happened?
I need to get it opened since I have my Bentley manual, tools, battery cables and other necessities in there.
Thanks |
Rhinoculips Samba Member
Joined: August 08, 2005 Posts: 918 Location: Keystone, Colorado
Posted: Sat Jun 19, 2010 10:31 pm Post subject: |
I had this happen once. It ended up that I put something under the bench that was slightly to high and added enough pressure on the latch to add resistance. This was a few years ago. IIRC, I either pushed or pulled on the lower bench forward/backward. After that, I disabled the latch. Couldn't figure out a reason to have it anyway. No mo probs now.
If that doesn't work, would unscrewing the mounts over the engine compartment help???? _________________ “May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image |
BushChicken Samba Member
Joined: March 11, 2010 Posts: 250 Location: California
Posted: Sun Jun 20, 2010 10:21 am Post subject: |
While pulling on the latch, push on the 'wall' and pull on the bench seat.
It also sometimes helps to push down on the bench seat.
It's easy if you have seven hands  |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10319 Location: Mt Lemmon, AZ
Posted: Sun Jun 20, 2010 10:53 am Post subject: Re: Access to the storage compartment under the rear bench s |
| westywong wrote: |
| ...Something is preventing the exterior pull handle from coming out far enough to release the hook... |
Maybe I'm losing it (I'd be the last to know) but my recollection is that I pull UP on that handle, not OUT.
Perhaps we're talking about the same action and just have a different POV and (as suggested) something is jammed under there causing the works to bind.
Interesting idea about removing the latch altogether, I agree is hardly seems necessary. |
ashafer Samba Member
Joined: May 01, 2010 Posts: 78 Location: Denver, CO 80205
Posted: Sun Jun 20, 2010 2:59 pm Post subject: |
| I remember this happening too. I had it crammed full of stuff. Take your rear cushion out (over the engine compartment) and there should be a space big enough to get your hand in under the bench seat. I think at the time a had one of the tables under there and it had jammed the locking mechanism. I just reached in there and rearranged some stuff as best I could and it opened just fine after that. |
Posted: Sun Jun 20, 2010 4:19 pm Post subject: Access to the storage compartment under the rear bench seat |
| Thanks everyone! I used the suggested technique from BushChicken to get it open. I have since removed the latch to prevent it from happening again. |
Belladonna30c Samba Member
Joined: April 23, 2008 Posts: 206 Location: San Diego, CA
Posted: Sun Jun 20, 2010 8:59 pm Post subject: |
My technique for a similar problem that has nothing to do with how much stuff is in the compartment is to sit on the center portion of the bench seat and then pull on the latch to release it. _________________ 1986 Weekender, automatic, 2nd owner
"A picture is worth a 1,000 words..."
"An ounce of prevention is worth a pound of cure." |
gchristensen Samba Member
Joined: October 09, 2012 Posts: 86 Location: Sacramento Ca.
Posted: Wed Nov 27, 2013 10:32 am Post subject: bench latch. |
I know this is an old thread but here is a solution that I have found. I have found that if you adjust the depth of the latch. By this if you bend the catch to adjust the point that the latch engages it will become trouble free. I had this problam when I made a new face out of 3/4 ply instead of the original. _________________ Joining now is our new 1982 diesel. This is an ongoing project under construction. |
Paulbeard Samba Member
Posted: Tue Jul 14, 2015 11:22 am Post subject: Opposite problem: seat doesn't latch |
There is something misaligned but without getting inside, I can't see what it is. The latch will close and the pull knob sits flush until I drop the seat, then the knob pops out. The seat seems to sit on the base fine. Not sure if this is a common problem with known solution, nothing turned up in a search. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
OldSpice Samba Member
Joined: June 10, 2015 Posts: 178 Location: 87 syncro westfalia Subaru ez30
Posted: Wed Mar 03, 2021 11:26 pm Post subject: |
| BushChicken wrote: |
TY. I had too much stuff in my
Bench and I couldn’t figure out the right recipe of angles to get this out... defeated at 1 am and tired AF I found this thread through google search and now I’m peacefully laying horizontal. |
