best electronic ignition system?
patban82
patban82 is offline
PostPosted: Fri Jul 09, 2010 3:31 pm    Post subject: best electronic ignition system? Reply with quote
im looking to replace the points on my bosch 009. i seen some accufire, comp fire and pertronix ignition system. but i dont know anything about them. anyone with experiance with these please post comments.
thanks
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Jul 09, 2010 4:15 pm    Post subject: Reply with quote
Can't help you. Never used one, never needed it. Points rock.
Wink
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Fri Jul 09, 2010 4:18 pm    Post subject: Reply with quote
Pertronix seem the most popular but that's because they advertise more.
I've seen all brands fail... and then you walk home.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Russ Wolfe
Russ Wolfe is offline
PostPosted: Fri Jul 09, 2010 4:26 pm    Post subject: Reply with quote
I have never had to walk home using a set of points.
Gary: OK. Ima poop.
gtixpress
gtixpress is offline
I've used both Pertronix and Compufire. Both worked well and the only reason I got replaced the Pertronix is I managed to hook it up wrong and fried it. doh!
I really want to attempt an EDIS install, but the trigger wheel mounting is what stumps me.
Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible
Chim
Chim is offline
PostPosted: Fri Jul 09, 2010 5:48 pm    Post subject: Reply with quote
I'm not sure the brand really matters.. get some.. I have them.. Most people on this forum are purist and will talk trash.. points can fail just like these can.. so be smart in either situation.. carry a spare!
www.infowars.com
Mr. 010
Glenn is offline
PostPosted: Fri Jul 09, 2010 6:57 pm    Post subject: Reply with quote
There's been talk of the rotor disc not fitting tight and causing the timing to bounce around.
Let's not debate points vs electronic... there's already a topic for they. Just answer the question.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
JSMskater
Samba Grease Gorilla
JSMskater is offline
PostPosted: Sat Jul 10, 2010 12:12 am    Post subject: Reply with quote
my personal preference, after trying three different units (compufire, pertronix, and EMPI's "hot spark") is the compufire. they all work the same and seemed to hold up just fine, but the compufire is by far the best design in my opinion, and their fitment was definitely better than pertronix's unit, though the pertronix LOOKED like a better unit. Don't let the supple wires and sleek plastic sleeve fool you -- the magnetic sleeve just doesn't fit right on the T3, and the unit with the swivel plate for vacuum advance raises the unit to high to consistently pick up the magnetic signal - at least in my experience. By contrast, compufire uses a round plastic disk with the magnets clearly visible and evenly spaced, and fits properly and evenly on the rotor shaft.
performance wise, the Pertronix was the most spotty but only due to its piss poor fitment. I have one in my 009 in my ghia and it runs awesome, never had any problems or performance issues, because its the regular kind that fits right.
as for the hot spark... its cheap, it works, but it's a piece of shit. just shoddy chinese craftsmanship and I probably got the ONE that actually works. I have serious doubts just about whether the unit will hold up to heat and vibration. it just feels chintzy and light in your hand, while the others are hefty and solid feeling.
71 Squareback-FI -- 73 Bay (subaru powered)
TOOB Member #3
I make D-jet FI connectors
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Sat Jul 10, 2010 2:56 am    Post subject: Reply with quote
Pertronix points replacement in my 019 -- been there for three years in the frankensquare...
in fact, it was Glenn that installed it when he rebuilt the distributor...
additionally, the OP may want to reconsider the title of the thread, since all you are asking about is a points-replacement-unit, not a true electronic ignition...
póg mo thóin
Certified DHS Technician
Samba Member # 24517
JSMskater
PostPosted: Sat Jul 10, 2010 8:29 am    Post subject: Reply with quote
good point.
also, IIRC the unit that pertonix sells for the 009 is the same that you'd be running in the 019, since its purely mech. advance right? I think the fitment is better on those units than the 1 size fits all (and it doesnt) vac advance version they sell.
TOOB Member #3
Mr. 010
Glenn is offline
PostPosted: Sat Jul 10, 2010 8:37 am    Post subject: Reply with quote
Wrong.. the 019 uses the 1844 and the 009 uses the 1847A.
And for the past year or so i've had to enlarge the hole in the mounting plate lays flat on the contact plate. I reported it to Pertronix tech support and they confirmed that the hole is too small. That was last summer and there's still been no change... have since stopped offering to install them on my rebuilds.
I've also found a number of the Pertronix has the magnets not exactly 90 degrees apart which alters the timing from cylinder to cylinder.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
JSMskater
PostPosted: Sat Jul 10, 2010 9:40 am    Post subject: Reply with quote
this is what I was trying to convey earlier-- something in their manufacturing of that sleeve doesn't seem as tightly controlled as say in the compufire system, which uses a round flat plastic plate that rides under the rotor. The magnets on the compufire are clearly visible so a quick eyeball check will tell you if the thing wasn't made right. The Pertronix sleeve? only way to know is pass another magnet and find them embedded in the plastic.
TOOB Member #3
Tram
Samba Socialist
Tram is offline
PostPosted: Sat Jul 10, 2010 9:53 am    Post subject: Reply with quote
Last I checked, points were electronic also. Very Happy
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
Mr. 010
Glenn is offline
PostPosted: Sat Jul 10, 2010 2:17 pm    Post subject: Reply with quote
Only if you consider a light switch "electronic".
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Tram
Samba Socialist
Tram is offline
PostPosted: Sat Jul 10, 2010 2:18 pm    Post subject: Reply with quote
Well, of course! It's all about directing electricity to perform a task.
Bryan67 wrote:
Those who can- do.
Mr. 010
Glenn is offline
PostPosted: Sat Jul 10, 2010 2:21 pm    Post subject: Reply with quote
I consider switches, relays and transformers "electrical". Electronic implies some sort of transistor, resistor or thing like that.
Or definitions differ.
Let's just call them "points replacements" since that's all they are.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
raygreenwood
raygreenwood is offline
PostPosted: Sat Jul 10, 2010 3:26 pm    Post subject: Reply with quote
I have used them both. The compufire doesn't look as nice as the Pertronix....but what makes them different is important. The wiring and insulation is poor on the compufire. That being said, its dirt simple to fix the poor fit of the grommit and insulation and add an insulating sleeve to stop abrasion on the wires.
As for module quality, they are about the same. They both work fine. I have found teh machien work to teh moduel bidy on the compufire to be slightly crappier...but just some light filing helps.
The fit and bottom flatness of the Pertronix bracket and the size of the locating lug for the breaker plate...were of better quality than compufire for the vacuum advance distibutors of my type 4's.
I have not found the 90* issue for the magnets...but with all of the other problems with the magnetic discs...I have no doubt of it.
Thr magnetic rotors of both brands suck as far as fit goes. This is on the minor side...due to variances in molding. Thats maybe 10-15% of the fault. About 85-90% of the fault is due to the wide range of distributor shaft sizing and machine work treatments. I have at least three differnt shaft top designes laying on my workbench just within the 905 205P D-jet distributors I have.
I have found all of the magnetic discs to be iffy in shaft fit and height above the pickup unit.
I use this method to fix this
(1) I take an old auxiliary air regulator from D jet (type 3 or 4) and pull out the barrel valve and slice a ring of metal off the end. Sand lightly. It makes a perfect bushing for the space on the bottom side of the disc...and spaces it slightly higher above the pick-up
(2) I then clean everything, lightly grease the shaft of the dizzy and the outside of the metal ring bushing.....and spoon in a small amount of high temo epoxy in the space on the underside of the magnetic disc. JB wled works well...but there are better high temp epoxies. Install the disc...make sure its straight....wipe up any excess...let it dry overnight. This is a permanet fix.
I have found both brands require sanding about .060" off the bottom of the rotor for correct fit in my type 4 D-jet distributors.
With a little care....both brands can be made perfect. Its kind of hard to make a universal part with all of the tiny difference in the dizzy.
I buy the Pertronix lately because even with all of the other minor fit issues...it has a nicer harness. Ray
blankmange
Type 3 Darksider
PostPosted: Sat Jul 10, 2010 7:20 pm    Post subject: Reply with quote
didn't I say that?
póg mo thóin
Mr. 010
Glenn is offline
PostPosted: Sat Jul 10, 2010 7:22 pm    Post subject: Reply with quote
didn't I say that?
Why yes you did, but some would disagree.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Tram
Samba Socialist
Tram is offline
PostPosted: Sat Jul 10, 2010 7:36 pm    Post subject: Reply with quote
didn't I say that?
Glenn- Why don't you just can that toy of yours, buy a real VW, and join the Type 3 crowd? You deserve better than a Beetle. Very Happy
Bryan67 wrote:
Those who can- do.
