venting system/gas cap for 74 bus
ldeckinga
ldeckinga is offline
PostPosted: Tue Jul 13, 2010 3:39 pm    Post subject: venting system/gas cap for 74 bus Reply with quote
I've had my '74 bus for about a month, the first one I've had. Newbie alert. When I bought it there was a locking gas cap on it that I didn't have the key for, so I had to take it off. I temporarily closed the tank with a rag and some tape so no debris would get into the tank while I was driving. Two days later the fuel pump dies. The mechanic I took it to said it may have died because air wasn't getting into the tank through the makeshift cap. I found a vented cap, not specifically for a vw bus, but the size was close enough that it worked, replaced the fuel pump and everything seems to be fine.
Now I've left the gas cap at a gas station and am trying to find a replacement but can't find a vented cap anywhere. I know there is a venting system, which is why I'm finding only non-vented caps. So... here are my several questions:
1) Did I actually destroy my fuel pump by plugging the gas tank, or was that a coincidence and my fuel pump was on its last leg and just waiting to go?
2) If I did kill my fuel pump does that mean that the venting system isn't working?
3) Is it possible that my venting system works fine and I should just buy a non-vented cap and not worry about it? How can I check that without destroying another fuel pump?
Thanks for the help.
LDeckinga
RatCamper
RatCamper is offline
PostPosted: Tue Jul 13, 2010 4:32 pm    Post subject: Reply with quote
Unless I am drastically mistaken, your bus should have a tank vent system already.
I don't think you need a vented cap. I don't have one. I have a smooth chrome or maybe stainless thing the PO put on it. He put it on because of an issue with someone prying the cap off and syphoning. this thing fits snug enough that there would be no leverage against the side of the inset. It also seems to have a way of changing the number of cork shims to space the seal correctly. He probably just got it from a parts store.
Even if your tank was airtight apart from the filler, how mad did you go with the tape? Unless you got waterproof canvas and rammed it in there with a pipe, air still should have gotten through. I say something else killed your fuel pump.
patayres
patayres is offline
PostPosted: Tue Jul 13, 2010 5:02 pm    Post subject: Reply with quote
http://www.bus-boys.com/
Scroll down the left side to Gas Caps. You want this one:
B. 211-201-551R Gas Cap, Locking, Black, 1974 to 1979 $29.70
Put your gas cap key on the keyring with your bus key & you are unlikely to ever forget that cap again.
I would also suggest finding a different mechanic that knows air-cooled VW buses... surely some Samba member here can suggest a good place in the bay area. Better yet, buy a Bentley manual, ask questions here, and learn to work on the bus yourself.
Finally, congrats on the new bus. We like pictures. Now is a perfect time to change your fuel lines and fuel tank vent line connections. Look here http://www.ratwell.com/technical/FuelHoses.html
Pay particular attention to this diagram...
1975 Westfalia Helsinki - 1800 EFI w/ Pertronix
1965 Singlecab - 1600dp
yuthi'so'coro
ldeckinga
PostPosted: Tue Jul 13, 2010 7:15 pm    Post subject: Reply with quote
If anyone knows of a good mechanic in the Oakland/Berkeley area for the repairs I can't do myself that would be great.
I bought the bus in NY and drove it to CA. The mechanic I took the bus to was in Pennsylvania, so I won't be seeing him again regardless. I bought the Bentley manual in Colorado and have done a handful of repairs already.
1973Riviera
1973Riviera is offline
PostPosted: Mon Jun 03, 2013 2:13 pm    Post subject: Fuel Vents Reply with quote
I have a 1973 bus with an issue with gas leaking when I have a full tank. I pulled the panel and there are no signs of leaking fuel anywhere. When I run the vehicle with a FULL tank I see gas leaking from behing both rear wheel wells. I assume it has something to do with the vent lines but why? If I fill up 3/4ths I do not have this issue. Any idea? How would I resolve this??
pb24ss
Location: sitting around the fire with the bluegrass band - colorado
pb24ss is offline
PostPosted: Mon Jun 03, 2013 2:39 pm    Post subject: Reply with quote
Get a locking gas cap from bus depot or one of the other vendors. Leave your key in it when you fill up. You can't drive off without putting the cap back on, or at least without removing your keys first.
fusername
fusername is offline
PostPosted: Mon Jun 03, 2013 5:50 pm    Post subject: Reply with quote
all bus fuel tanks are vented thru the intake. so yeah, just coincidence on the failure there.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
