1600 dual port single relief Custom T25 turbo set up
t8017e
t8017e is offline
PostPosted: Wed Jul 21, 2010 10:29 am    Post subject: 1600 dual port single relief Custom T25 turbo set up Reply with quote
Well I gathered all the parts and fabed up everything I needed to put the turbo on my car now I need to know how hi can I rev it till it blows apart, or will t blow apart.
It was pretty easy for my first turbo set up got a Weber Progressive 32/36 and a new T25 Garret and installed a carbon seal and it runs need a little tuning still, it stumbles a little.
[/img]
kbwakesk8
kbwakesk8 is offline
PostPosted: Wed Jul 21, 2010 12:05 pm    Post subject: Reply with quote
that will be fun it will make a big difference.
By kbwakesk8 at 2009-05-27
mine didn't last long no carbon seal
7lb on a stock motor is all i pushed and 4500 rpm is all i felt safe doing.
adams77
adams77 is offline
PostPosted: Wed Jul 21, 2010 6:17 pm    Post subject: Reply with quote
I want a turbo.
Any writeups on homemade turbo's I tried the search but had toooooo many hits.
Looking for a good parts list and possible donor cars.
If Stupidity got us into this mess, then why can't it get us out? ....Will Rogers
po7g
po7g is offline
PostPosted: Wed Jul 21, 2010 7:30 pm    Post subject: Reply with quote
well I heard stock motor cooling fans shouldn't be reved passed 5k rpm and you should change the header to the style that kbwakesk8 cause you will have leaks were the pipes come in and that will have you lose performance
shred625
shred625 is offline
PostPosted: Thu Jul 22, 2010 7:13 am    Post subject: Reply with quote
Turbo charging a 1600 is like wearing a raincoat in the shower Laughing
“It takes a big man to cry, but it takes a bigger man to laugh at that man.”
~ Jack Handey
t8017e
t8017e is offline
PostPosted: Thu Jul 22, 2010 10:03 am    Post subject: Reply with quote
adams77 wrote:
I want a turbo.
Check out this link ind of what I used as a base.
http://www.smbaker.com/sand-rail/manx/monster-turbocharged-volkswagen-manx
