Aux Battery ACR - Wiring and Fuses
Franklll
Franklll is offline
PostPosted: Thu Aug 19, 2010 6:03 pm    Post subject: Aux Battery ACR - Wiring and Fuses Reply with quote
I have spent many hours researching all of the threads about these setups. I think I have decided what to do with my 78 Westy(with a little help from Scott@German Supply) There have been a few specifics I am having trouble locating....What size wire and fuses do i need? Does the ACR need to be fused? also, do i need to hook up the SI on the ACR?
Cheers,
Frank
WhirledTraveller
WhirledTraveller is offline
PostPosted: Thu Aug 19, 2010 6:16 pm    Post subject: Reply with quote
No fuse on the ACR.
Fuses in your fuse box should be sized appropriately to the expected load. 15 amp fuses will cover a lighter/stereo/etc pretty well.
I wouldn't bother with the Starter Isolation circuit. Unnecessary in this application. It will isolate automatically anyway because the voltage will be below 13 volts during starting.
1977 Westy, Automatic. Big Valve heads, CS Cam.
Franklll
Franklll is offline
PostPosted: Thu Aug 19, 2010 6:23 pm    Post subject: Reply with quote
Thanks for the help
If i use 4-15 amp fuses in the aux fuse box does my main fuse @ the battery have to be 60A? that seems really big. does the volmeter need to be fused?
germansupplyscott
germansupplyscott is offline
PostPosted: Thu Aug 19, 2010 6:53 pm    Post subject: Reply with quote
the ACR we sell has a fused ground.
SL
aeromech
aeromech is offline
PostPosted: Fri Aug 20, 2010 7:58 am    Post subject: Reply with quote
Frank,
It looks to me like you're making this a lot harder than it really is. I've installed 3 or 4 aux batt systems in bay window buses and I used components purchased from West Marine. They have several articles on their web site with descriptions, drawings, and advice. Here's some links:
http://www.westmarine.com/webapp/wcs/stores/servle...nd-Battery
http://www.westmarine.com/webapp/wcs/stores/servle...ers-Relays
http://www.westmarine.com/webapp/wcs/stores/servle...ge-Battery
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
germansupplyscott
PostPosted: Fri Aug 20, 2010 8:14 am    Post subject: Reply with quote
aeromech wrote:
Frank,
frank asks a lot of questions. my inbox is full of them. i guess it's always better to ask questions before plunging in, i ask lots of questions too before doing things i haven't done before.
SL
aeromech
aeromech is offline
PostPosted: Fri Aug 20, 2010 8:35 am    Post subject: Reply with quote
germansupplyscott wrote:
aeromech wrote:
Frank,
Right, I do to. Best to do your homework when attacking a new project. I didn't mean to criticize but more to let him know that the job's easier than he thinks.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Franklll
Franklll is offline
PostPosted: Fri Aug 20, 2010 10:16 am    Post subject: Reply with quote
Aeromech,
Maybe you are right, as this is my first shot at it i will simplify. I am going to drop the whole voltmeter idea and just get the aux battery running. I'll run extra wires to the front in case i want to add it later.
So the only question i have left is the fuse/wire size @ the battery for the aux fuse box? I understand it depends on my load but, unfortunately my brain only works in the ac world.
Looking at some pictures it looks like guys are using around a #8AWG. What have you guys used in the past?
Thanks for all of the help
Cheers
telford dorr
telford dorr is offline
PostPosted: Fri Aug 20, 2010 10:39 am    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
- For control signal wiring (voltmeter, etc.), 18 gauge or larger is fine. It has more to do with physical constraints - ability to secure a crimp terminal to the wire, bundling, etc. than current capacity.
- 12 gauge on fused loads is good.
- I'd fuse (1 amp inline) both sense wires from the batteries to the voltmeter switch, unless you can guarantee that there is no possibility of a short. Batteries have no sense of humor...
- For the aux battery feeder to the fuse block, you can get 60 amp self-resetting circuit breakers at your FLAPS. Locate it as close to the battery as possible. Or use a fusible link for the groundstrap.
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
aeromech
aeromech is offline
PostPosted: Fri Aug 20, 2010 10:49 am    Post subject: Reply with quote
I used a 6 gauge wire from the aux battery to a 30 or so amp fuse in the engine compartment and from there up to the front of the bus where I located the aux fuse block under the dash. I think bigger is better. I installed inline fuses between the batteries and the ACR. These were big fuses but I don't the size but at least 75 amp. The wires I used for that were around 1/0 awg welding cable. Like I said bigger is better. Here's some pics.
And here's a different bus
And here's a third one
and a fourth
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Franklll
Franklll is offline
PostPosted: Thu Apr 03, 2014 7:43 pm    Post subject: Act not working Reply with quote
. I borrowed this pic but it's exactly like mine. Bluesea Automatic Charging Relay
I have had my second battery working for a few years and now I'm putting the batteries back in after winter and the second battery isn't charging. The Acr green light is flashing("combining" I believe it says) it's only showing about 5 volts when the van is running.
Does anyone have any ideas what might be wrong?
aeromech
aeromech is offline
PostPosted: Fri Apr 04, 2014 6:31 am    Post subject: Reply with quote
You'll need to read the literature on the ACR but as I recall the green combine light stays illuminated when closed (combined). It flashes when there's a problem. Your problem is probably that one of your batteries has too low of voltage. You'll need to put a charger on it and bring it up to around 10 volts before the ACR will close.
The reason for this is safety. Let's say you're out at sea in your boat with several scantily clad babes in small bathing suits listening to music and having a fantastic time. Now one of your batteries gets an internal short. If the ACR was allowed to close then your remaining good battery would be connected to a dead short (the other bad battery) and you wouldn't be able to start the engine.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Mal evolent
Mal evolent is offline
PostPosted: Fri Apr 04, 2014 6:43 am    Post subject: Reply with quote
you got a part number and a source for scantily clad babes in small bathing suits?
73 Beetle Baja, Ghia front brakes, Type 3 rear brakes, 2220 ( 94 X 80 ), Weber Progressive, Bosch SVDA, '97 Mustang seats
Baja Bugs for Volkswagen Virgins: Index
Koeppler
Koeppler is offline
PostPosted: Sun Feb 20, 2022 1:40 pm    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
I’ve seen a lot of these Blue Sea ACR and battery switch installations on The Samba where both pieces are stuck to the battery somehow. So what’s the secret? I see screws and stuff but I know no one is actually screwing into their battery.
Can anybody help a guy out and explain how these bits get adhered to the battery?
aeromech
aeromech is offline
PostPosted: Sun Feb 20, 2022 3:04 pm    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
The top pic is mine. Here’s what I do.
Buy a battery hold down from Blue Sea. Take a piece of lexan plastic. Drill, countersink, and mount the appliances. Then sandwich the lexan between the top and bottom of the battery holder. Be sure to secure the battery tray to the vehicle so the battery can’t move.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Koeppler
Koeppler is offline
PostPosted: Mon Feb 21, 2022 7:03 am    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
Thanks a bunch for this! I knew it was less complicated than I was making it out to be.
mikedjames
mikedjames is offline
PostPosted: Mon Feb 21, 2022 1:51 pm    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
Your fuses go at the battery or power supply end to protect the wire from overheating when you short it, so the max fuse rating is defined by the wire gauge.
But if you know a wire is never going to need to provide a large current, then fitting smaller fuses than the wire gauge maximum is a good idea, it keeps voltage drops down, and protects against damaging other smaller gauge wires that might come into contact with the heavy wire.
It potentially stops loads/ equipment at the far end from completely self-destructing when it develops a fault too, although well designed kit should have its own correctly rated input fuses too.
Ancient vehicles and vessels
aeromech
aeromech is offline
PostPosted: Sun Feb 11, 2024 10:14 pm    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
Here’s my latest aux battery installation into a 1972 camper. Just completed 2/10/24
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
sodbuster
sodbuster is offline
PostPosted: Mon Feb 12, 2024 6:52 am    Post subject: Reply with quote
Franklll wrote:
Aeromech,
Cheers
I use my volt gauge for both systems, Main / aux. I tap into each side and add a momentary swich on the aux battery side, and a diode on the 12volt keyed side.
It works as a regular volt gauge while driving then you can just press the momentary button to read the voltage of the aux system.
A = Aux system.
K = 12 volt keyd hot.
I = Dash illumination.
aeromech
aeromech is offline
PostPosted: Mon Feb 12, 2024 8:18 am    Post subject: Re: Aux Battery ACR - Wiring and Fuses Reply with quote
That’s awesome
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
