redcanoe Samba Member
Posted: Sun Aug 29, 2010 8:54 pm Post subject: collapsible pushrod tubes |
What sort of success is being had with replacing pushrod tubes with the collapsible type. I had to replace one of the stock tubes. Two shops have each had a try (2 tubes and installs) and both times an oil leak has developed at the telescoping part shortly after. I'd like to stop this leak but hesitate to try a third ($$)......but the only alternative is to pull the head.
Third time lucky ? |
Gauche1968 Samba Member
Posted: Sun Aug 29, 2010 9:26 pm Post subject: |
Replaced all 8 tubes with collapsible 4 years ago and haven't seen a leak since. _________________ 1984 Vanagon GL
1984 Vanagon Westy |
insyncro Banned
Posted: Mon Aug 30, 2010 7:09 am Post subject: |
I only use the collaspe type tubes on my boxers.
No issues at all over the years.
dylan |
andy syncro-nutz Samba Member
Joined: August 22, 2010 Posts: 539 Location: Upper Ottawa Valley
Posted: Mon Aug 30, 2010 3:05 pm Post subject: |
Never had a problem with good quality tubes  |
morymob Samba Member
Posted: Mon Aug 30, 2010 5:40 pm Post subject: |
I'm satisfied with mine, over a yr now. Don't try the cheap(made only, not the price) ones ,they all leak. Use at least double o ringed ones. |
Mathew Zelezen Samba Member
Joined: November 04, 2004 Posts: 547 Location: Graeagle, CA
Posted: Mon Aug 30, 2010 6:10 pm Post subject: |
Mine only leaked when I accidentally pinched one of those white rubber seals... and be sure you're applying a film of oil on the mating surfaces before installation.
3 Times a Lady! _________________ 87 Syncro Tintop
~Rocky J Motor
~Steedle Trans
Of all sad words of tongue or pen, the saddest are these: It might have been. |
OilNBolts Samba Member
Posted: Mon Aug 30, 2010 6:55 pm Post subject: |
I've had a set of Jay Cee's in one of my vans now for well over a year with not a drop of oil to be seen. They are type 1 tubes, but are installed backwards in a WBX.
And they do look the deal!
http://www.cbperformance.com/catalog.asp?ProductID=1395 _________________ Current fleet: Vanagons, two '88 GLs and an 89 Bluestar. Beetles, '63, '64, '72 convertible. Plus, four Subarus and three Prius. Too many cars. |
Posted: Mon Aug 30, 2010 7:03 pm Post subject: |
Well that is good news. Collapsibles can indeed work. Bad news is that after two "pro" attempts I'm still leaking. One said "oh well" when I called about continued leak. I'm in Canada and do believe that the tubes used were "vw" ( read here once that those are "guaranteed to leak"). The third shop I'm experimenting with will get a shot at this, along with a timesert, next month. I will check on what brand they are using. cb performance seems to get thumbs up on theSamba.
Further input always welcome and I'll keep you posted.
Randy |
captdave Samba Member
Joined: May 05, 2008 Posts: 87 Location: Prince Rupert, Canada
Posted: Tue Aug 31, 2010 2:16 pm Post subject: |
I replaced my push rod tubes myself, no leaks. I did smear a little high heat sealing compound around the ends. Just be real careful you have the push rods seated in the lifters before bolting up. |
speedygeorge Samba Member
Joined: November 28, 2009 Posts: 282 Location: Victoria, BC
Posted: Tue Aug 31, 2010 4:38 pm Post subject: Re: collapsible pushrod tubes |
I had 2 PRTs replaced at Hogg's on the Malahat a few months ago, no leaks so far and he only charged my $65 hour and I believe he doesn't have a problem with you bringing in your own parts. |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12167 Location: Port Manteau
Posted: Sat Oct 08, 2011 9:34 am Post subject: |
My WBX is still running its original tubes, and the van is easily the least drippy vehicle in my fleet. I've never used the spring-loaded tubes, but I really like them in theory. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10355 Location: N. Idaho
Posted: Sat Oct 08, 2011 9:48 am Post subject: |
A vote for the Van Cafe collapsible tubes. Multiple O rings, easy to figure out and easy to use. No leaks. I used grease to seat the seals as others pointed out, and while installing I carefully hand pushed each end into its seat, and rotated a bit to help fully seat. I suspect if you simply let the spring pressure (mild) do the seating it may not end up with proper seal pressure. In other words, just a small amount of care in install - as if its your own vehicle, for instance - and they work fine.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1993 Toyota LandCruiser, 2002 BMW 325iX, 1982 Toyota Sunrader |
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7194 Location: Honolulu,Hawaii and France
insyncro Banned
Posted: Fri Apr 04, 2014 8:17 am Post subject: |
I would love to hear some feedback on the aluminum ones.
New to me.
Thanks Alika  |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1797 Location: Boise, Idaho
Posted: Fri Apr 04, 2014 9:11 am Post subject: |
There is a lot of info out there on Jaycee pushrod tubes. They are the highest quality out there. |
insyncro Banned
Posted: Fri Apr 04, 2014 9:14 am Post subject: |
Steve Arndt wrote: |
Do they aluminum ones fit a 2.1 WBX? |
Posted: Fri Apr 04, 2014 10:12 am Post subject: |
insyncro wrote: |
Yes, I'd like to know that too
I know about the quality, that's why I wanna buy them,even if a little trimming is required. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
insyncro Banned
Posted: Fri Apr 04, 2014 10:19 am Post subject: |
ALIKA T3 wrote: |
insyncro wrote: |
I know about the quality, that's why I wanna buy them,even if a little trimming is required. |
They look like they are too large in diameter, but I'm only going by the picture. |
Posted: Fri Apr 04, 2014 10:21 am Post subject: |
I looked at the push rod seal 113109345A
And they fit:
Bus (Type 2)
1960-1971 View Fit Details
Karmann Ghia
1961-1974
Beetle
1961-1978 View Fit Details
Type 3 (Squareback/Fastback)
1966-1973 View Fit Details
Super Beetle
1971-1979
Thing
1973-1974 View Fit Details
Vanagon
Air Cooled : 1983
Diesel : 1983-1984 View Fit Details
1.9 Liter : 1983-1985 View Fit Details
2.1 Liter : 1986-1991 View Fit Details
Syncro : 1986-1991 View Fit Details
Although this part number is also given for a Vanagon only : 070109345
From the picture,just the outer edge of the seal differs, so I believe the push rods are the same diameter. The aluminum tube with the nuts should fit if there is enough thread to adjust. The length from Aircooled to watercooled must not differ much, does it? _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
Posted: Fri Apr 04, 2014 10:23 am Post subject: |
insyncro wrote: |
ALIKA T3 wrote: |
insyncro wrote: |
I didn't think about that… I never tore a VW WBX apart before  _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
