How to keep a Bus stock and all stock height questions
Page: 1, 2, 3 ... 18, 19, 20  Next
luca
luca is offline
PostPosted: Mon Oct 11, 2010 11:51 am    Post subject: How to keep a Bus stock and all stock height questions Reply with quote
..... and why lowering questions need to become sticky .... Question Laughing
dawerks
dawerks is offline
PostPosted: Mon Oct 11, 2010 11:53 am    Post subject: Reply with quote
I see what you did there!
Question; how do you get rid of the RGB whine though??
williamblanda
Don't Disgrace The Eddy!
williamblanda is offline
PostPosted: Mon Oct 11, 2010 11:55 am    Post subject: Reply with quote
Ear plugs.
Next!
dawerks
dawerks is offline
PostPosted: Mon Oct 11, 2010 2:34 pm    Post subject: Reply with quote
williamblanda wrote:
Ear plugs.
Next!
Smile But they are illegal here (no ear obstructions including ear plugs, headphones, etc) allowed.
I was thinking of sound deadening, but that noise carries all the way forward through the metal.
On a more serious note, if you follow Porsche 356 engineering and logic; the front of a rear engine vehicle SHOULD be higher than the back for better handling and response. I think on a 356 this is easily shown by the old race photos. And on a bus, I've noticed that a stock bus seems to have a really light, easy steering too it. Whereas the same buses, lowered, need considerably more force on the wheel.
williamblanda
PostPosted: Mon Oct 11, 2010 3:02 pm    Post subject: Reply with quote
I actually like RGB whine. It's one of those perks that make driving a stock height split great.
dubstar
dubstar is offline
PostPosted: Mon Oct 11, 2010 3:22 pm    Post subject: Reply with quote
1963 Type II Kombi
1977 Type I Fuel Injection
http://instagram.com/john_aka_dubstar/
http://web.stagram.com/n/john_aka_dubstar/
"you could transport really tall things too, like a giraffe"
cdennisg
cdennisg is offline
PostPosted: Mon Oct 11, 2010 6:37 pm    Post subject: Reply with quote
Ear plugs.
Next!
The RGB whine is a result of straight cut gears. It will always sound that way, and only gets worse with wear. I use ear plugs when I drive long distances, but mostly for wind noise. At highway speeds the wind is louder than the engine/trans. Look for Hearos ear plugs, they come in a tan color that is barely noticeable to the fuzz.
Low buses have heavier steering because they generally use a wider, low profile tire on the front. Depending on what was done to lower the front, the steering geometry can be affected and cause steering issues. Stock height buses that have low weight rating passenger tires also have a heavy steering feel.
Not sure about the nose high attitude and whether it helps with handling on a rear engined car. Have you read anything that describes this? I would be interested to read the science behind it.
mr white
mr white is offline
PostPosted: Tue Oct 12, 2010 8:02 pm    Post subject: Reply with quote
The tallest radial tires you can fit to keep your old bird up:P225 75 R15. Unless you have a barndoor,the same but R16. Hang em high! Watch em drive!
obus Premium Member
obus is offline
PostPosted: Tue Oct 12, 2010 8:25 pm    Post subject: Reply with quote
no radio and will keep it that way. If i need music ill just put in the portable ipod boombox and use that
oarse
oarse is offline
PostPosted: Tue Oct 12, 2010 9:19 pm    Post subject: Reply with quote
Does this cause your speedometer to read slower than you're actually going? Very interesting. Wink
mr white
mr white is offline
PostPosted: Tue Oct 12, 2010 10:30 pm    Post subject: Reply with quote
A very good question. Typically with originall bias-plys the speedometer was and is accurate. With the radials the error margin is 2-6 mph. Slower than actual. These vehicles being "ancient" actual speedo readings differ. Us the hobbyist-bus lover's should have our speedo's caliberated. If not with these tall radial's keep in cosideration,2-6mph error. Reason being,they are wider. Keep driving. Enjoy. Drive em high!
mightymouse
mightymouse is offline
PostPosted: Wed Oct 13, 2010 4:51 am    Post subject: Reply with quote
most epic thread ever. Smile
Mr white... just run bias plys. The bus will be happier and you can enjoy that 50s experience. my speedo is dead on with 670-15". We checked with GPS, and every speed trap trailer I go by, my speedo matches it.
Cool
Nothing can stop the man with the right mental attitude from achieving his goal; nothing on earth can help the man with the wrong mental attitude.
Thomas Jefferson
Note to EVERYONE.
Know your ZDDP levels or you WILL lose a cam and lifters.
Andrew
Andrew is offline
PostPosted: Wed Oct 13, 2010 5:43 am    Post subject: Reply with quote
How much rake the vehicle has is exactly why the steering seems lighter on a stock height bus. Stock height buses are almost always level or a little bit higher in the front, whereas lowered buses are almost always lower in the front than in the back. It's all an issue of caster. Buses were setup from the factory with zero caster angle built into the beam and having a saggy rear end will turn that into a positive caster angle, giving it a lighter steering feel. When somebody lowers the bus without building more caster into the beam and lowers the front more than the back, they end up with negative caster, giving the bus a heavier feeling steering.
-Andrew
rustybug3
rustybug3 is offline
PostPosted: Sun Oct 17, 2010 4:44 pm    Post subject: getting it up Reply with quote
Every body seems to be lowering their buses and putting beetle trannies under them. How do you take it back to stock height?
cdennisg
cdennisg is offline
PostPosted: Sun Oct 17, 2010 5:37 pm    Post subject: Re: getting it up Reply with quote
Get some stock spindles (and a stock beam if it's been modified) and an RGB trans to fit your bus. Install, and drive.
rustybug3
PostPosted: Mon Oct 18, 2010 8:52 am    Post subject: Reply with quote
You don't need to weld anything back in? Thanks for your input.
williamblanda
PostPosted: Mon Oct 18, 2010 9:41 am    Post subject: Reply with quote
No. If that's all that was done to the bus, installing the correct drive train should do ya'.
Mikee
Samba A.D.D. Boy
Mikee is offline
PostPosted: Mon Oct 18, 2010 10:34 am    Post subject: Reply with quote
so what should the ground clearance be from your steering box? Laughing
localboymark wrote:
One man's "patina" is another man's cancer.
bugnut68 wrote:
I would have kicked the guy right in the dick, balls, ass and face and destroyed his weed. Hippies suck.
mightymouse
PostPosted: Mon Oct 18, 2010 7:44 pm    Post subject: Reply with quote
Im showin 12.5" from the lowest part of the steering box to the pave.....
Laughing
Thomas Jefferson
Note to EVERYONE.
EmpiGT
EmpiGT is offline
PostPosted: Mon Oct 18, 2010 7:53 pm    Post subject: Reply with quote
With all the raising back to stock height going on, this will put a few companies on here out of business, with the flood of used drop spindles and axle/spring plate kits hitting the market. Laughing
Gather all the stock suspension stuff that you can!
Page 1 of 20
